- To:
- Subject: [cgal-discuss] CGAL::Assertion_exception
- Date: Sat, 24 Sep 2011 09:07:16 -0700 (PDT)
Hello,
I am using CGAL 3.8 under Windows XP/Visual Studio 2008. I have first been
using the Exact_predicates_inexact_constructions_kernel Kernel with the
double number type but I the realized that some of my geometry operations
returned wrong results. So I switched to the exact kernel
CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Quotient<CGAL::MP_Float>>>.
For this to be possible, I had to modify some of my own code to use the CGAL
exact number type (in this case
CGAL::Lazy_exact_nt<CGAL::Quotient<CGAL::MP_Float>>) instead of
double. Part of this code is a vertex class and a matrix class that I use
for some computations. For exemple the operator * for multiplying a matrix
with a vertex looks like this:
template<class NumberType,class OperationsType>
CVertex3Base<NumberType,OperationsType> operator* (
CVertex3Base<NumberType,OperationsType>& oVertex,
CMatrix4x4Base<NumberType,OperationsType>& oMatrix )
CVertex3Base<NumberType,OperationsType> oVertex3dRet;
for ( int i = 0; i < 3; i++ ) {
oVertex3dRet[i] = 0.0;
for ( int j = 0; j < 3; j++ ) {
oVertex3dRet[i] += oMatrix(j,i)*oVertex[j];
return oVertex3dRet;
However, my program crashes on an "CGAL::Assertion_exception" at the first
place I perform an arithmetic operation on the CGAL number type, in this
case in the code
Somewhere in my stacktrace I got
" Variable used before being initialized (or CGAL bug)"
Could anyone tell me what I am doing wrong?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Assertion-exception-tp3839613p3839613.html
- [cgal-discuss] CGAL::Assertion_exception, wendsomde, 09/24/2011
- Re: [cgal-discuss] CGAL::Assertion_exception, Sebastien Loriot (GeometryFactory), 09/27/2011
