cgal-discuss - Re: [cgal-discuss] using C3T3::Facet_iterator with AABB_Tree
  • To:
  • Subject: Re: [cgal-discuss] using C3T3::Facet_iterator with AABB_Tree
  • Date: Tue, 27 Sep 2011 17:52:50 +0200
You should use C3t3::Triangulation::Facet as Id type. The type Facet is
mutable.
On mardi 27 septembre 2011 17:28:23 Frankie Li wrote:
> template< class C3T3, class AABB_Kernel >
> class AABB_mesh_3_triangle_primitive
> public:
> typedef typename C3T3::Triangulation Triangulation;
> /// AABBPrimitive types
> typedef AABB_Kernel GeomTraits;
> typedef typename GeomTraits::Point_3 Point;
> typedef typename GeomTraits::Triangle_3 Datum;
> typedef typename C3T3::Facet_iterator Id;
Here, replace with
typedef typename C3t3::Facet_iterator Facet_iterator;
typedef typename C3t3::Triangulation::Facet Id;
> AABB_mesh_3_triangle_primitive(Id handle)
> : m_facet_handle( handle )
Here replace with:
AABB_mesh_3_triangle_primitive(Facet_iterator fit)
: m_facet_handle( *fit )
And rename m_facet_handle to m_facet.
Laurent Rineau, PhD
