- To:
- Subject: [cgal-discuss] Re: Cmake Error while installing CGAL
- Date: Wed, 28 Sep 2011 05:23:29 -0700 (PDT)
Thanks Sebastien for ur reply........I'm still having a problem
The problem is is with boost.thread library.
the error is: The following Boost libraries could not be found:
boost_thread
I have installed boost_1_47 from boostpro computing and environment variable
BOOST_ROOT has also been set to the boost directory.
I read somewhere that this could be because of lack of precompiled libraries
but I dont know much about this.
Any clue on this?
Thanks,
Jiju p
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Cmake-Error-while-installing-CGAL-tp3817613p3850991.html
- [cgal-discuss] Re: Cmake Error while installing CGAL, jiju, 09/25/2011
- Re: [cgal-discuss] Re: Cmake Error while installing CGAL, Sebastien Loriot (GeometryFactory), 09/27/2011
- [cgal-discuss] Re: Cmake Error while installing CGAL, jiju, 09/27/2011
- [cgal-discuss] Re: Cmake Error while installing CGAL, jiju, 09/28/2011
- Re: [cgal-discuss] Re: Cmake Error while installing CGAL, Sebastien Loriot (GeometryFactory), 09/28/2011
- Re: [cgal-discuss] Re: Cmake Error while installing CGAL, Sebastien Loriot (GeometryFactory), 09/29/2011
