Re: [cgal-discuss] compiling error of "linear_least_squares_fitting_3" under :Exact_predicates_exact_constructions_kernel
- To:
- Subject: Re: [cgal-discuss] compiling error of "linear_least_squares_fitting_3" under :Exact_predicates_exact_constructions_kernel
- Date: Fri, 7 Oct 2011 10:22:38 +0200
On vendredi 07 octobre 2011 03:31:14 Kai WANG wrote:
> Hi Sebastien,
> The reason is illustrated in another post:
> http://cgal-discuss.949826.n4.nabble.com/Issue-on-CGAL-Polygon-2-Intersecti
> on-td3877407.html
> Since I find my program crash when calculating the 2D polygon intersection
> with CGAL::Cartesian<double> as the kernel number type, especially when
> there are more digits after the decimal point.
CGAL::Exact_predicates_inexact_constructions_kernel is a synonym of
CGAL::Filtered_kernel< Simple_cartesian<double> >
That kernel, whose FT is also "double", is very different from
CGAL::Cartesian<double> or CGAL::Simple_cartesian<double>, because it ensures
that predicates will be evaluated exactly (using filtering technics to avoid
extra cost).
Laurent Rineau, PhD
- [cgal-discuss] compiling error of "linear_least_squares_fitting_3" under :Exact_predicates_exact_constructions_kernel, kyewong, 10/06/2011
- Re: [cgal-discuss] compiling error of "linear_least_squares_fitting_3" under :Exact_predicates_exact_constructions_kernel, Sebastien Loriot (GeometryFactory), 10/06/2011
- Re: [cgal-discuss] compiling error of "linear_least_squares_fitting_3" under :Exact_predicates_exact_constructions_kernel, Kai WANG, 10/06/2011
- Re: [cgal-discuss] compiling error of "linear_least_squares_fitting_3" under :Exact_predicates_exact_constructions_kernel, Kai WANG, 10/07/2011
- Re: [cgal-discuss] compiling error of "linear_least_squares_fitting_3" under :Exact_predicates_exact_constructions_kernel, Sebastien Loriot (GeometryFactory), 10/07/2011
- Re: [cgal-discuss] compiling error of "linear_least_squares_fitting_3" under :Exact_predicates_exact_constructions_kernel, Laurent Rineau (GeometryFactory), 10/07/2011
