cgal-discuss - Re: [cgal-discuss] error while compiling Point_set_processing_3_
  • To:
  • Subject: Re: [cgal-discuss] error while compiling Point_set_processing_3_
  • Date: Tue, 11 Oct 2011 14:41:41 +0200
On mardi 11 octobre 2011 11:27:05 Subhasree M wrote:
> Hello,
> When I compile Point_set_processing_3_
> example.sln, I get the following message:
[MSVC build log]
> 6>LINK : fatal error LNK1104: cannot open file 'libcblas.lib'
> I am using Windows 7 and the following :
> 1) Visual Studio(9) 2008
> 2)Boost 1.46.1
> 3) CMake 2.6.4
> 4) CGAL 3.8
> 5) QT 4.7.1
> I downloaded all the LAPACK from
> http://www.netlib.org/clapack/LIB_WINDOWS/prebuilt_libraries_windows.html.,
> but couldn't get
> 'libcblas.lib'.
Probably you did not setup the CMake configuration correctly.
If you want to avoid to do that yourself, you can relaunch the CGAL Windows
installer, and ask it to download our precompiled LAPACK/BLAS/TAUCS
libraries.
Then re-run cmake for Point_set_processing_3 from an empty cache. That time
it
will find BLAS automatically.
If you really want to use the binaries from netlib.org, then you probably
need
to define BLAS_INC_DIR and BLAS_LIB_DIR in your environment variables.
Laurent Rineau, PhD
