cgal-discuss - Re: [cgal-discuss] Smart makefile for C++ at function level
  • To:
  • Subject: Re: [cgal-discuss] Smart makefile for C++ at function level
  • Date: Wed, 12 Oct 2011 00:06:02 +0200
Hi Zohar,
compilation times with template code are a serious problem and the usual argument goes like this: Get a new computer or dedicated build-infrastructure.
Your idea looks cool but comes with some serious problems.
- C++ build systems are already overly complex, hiding a (notoriously complex) C++ parser isn't a good idea (although Boost.Wave comes to mind). You also need to scan for much more than just functions (static, unnamed namespace).
- parsing and building your intermediate files looks error prone and time consuming
- you put a lot of strain on the linker, dunno if this is actually better than putting it on the compiler
Generally this is something more suited for comp.lang.c++.moderated and not for SO or this mailing list. But I'm afraid people there are just going to tell you that you should help pushing the "modules" proposal for C++1x (No, other people aren't that optimistic regarding the time frame ;) ).
Meanwhile there is `extern template` in C++11 to prevent instantiation of templates if you are sure that it will be instantiated in another TU. This could help you already.
Cheers,
Philipp
On 11 October 2011 22:27, Zohar <> wrote:
Hi Guys,
Slow build times especially in .cpp using CGAL inspired my following idea:
http://forums.cgsociety.org/showthread.php?f=89&t=1010489
First I would appreciate your opinion on my idea.
Second I started a discussion with Robert regarding templates, I would
appreciate your comments, since you chose it as your main architecture
design.
You can answer here, and I'll try to relate the stuff to cgtalk.
Zohar
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Smart-makefile-for-C-at-function-level-tp3895883p3895883.html
