- To:
- Subject: Re: [cgal-discuss] Implicit domain + sharp features
- Date: Wed, 19 Oct 2011 09:30:15 +0200
No it is not possible to get accurately the one and zero dimensional features
of the domain if you don't describe them explicitly through
the traits class.
You may still run the meshing algorithm
without an explicit description of sharp features.
Then you will get a mesh in which those sharp features
will be rather poorely represented.
Le 18/10/11 11:05, Oleg a écrit :
Hi! I'm new to CGAL and am just figuring out how it works, so please don't
beat me up for asking probably a silly question. I've tried the example
mesh_two_implicit_spheres_with_balls.cpp from the 3D Mesh Generation
chapter, and it worked fine for me. Here is the question: it is possible to
get the same sharp intersection of the spheres without explicitly describing
the intersection line? I'm going to use the mesh in deformation problems, so
the boundary will somewhat evolve and I won't be able to describe it always
as a function. I tried the facet_topology criteria, but they didn't produce
any visible result. Is this possible at all, and if yes, how? Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Implicit-domain-sharp-features-tp3914667p3914667.html
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- [cgal-discuss] Implicit domain + sharp features, Oleg, 10/18/2011
- Re: [cgal-discuss] Implicit domain + sharp features, Mariette Yvinec, 10/19/2011
- [cgal-discuss] Re: Implicit domain + sharp features, Oleg, 10/19/2011
