cgal-discuss - Re: Fwd: [cgal-discuss] best way to find extreme points from a set of points in high-dimension
  • To: "Cassio P. de Campos" <>
  • Cc:
  • Subject: Re: Fwd: [cgal-discuss] best way to find extreme points from a set of points in high-dimension
  • Date: Tue, 25 Oct 2011 23:56:16 +0200 (CEST)
On Tue, 25 Oct 2011, Cassio P. de Campos wrote:
Thanks for the fast reply, and sorry for insisting, but I'm really in
need of the best possible solution and I might be very well missing
something.
Please correct if I am wrong: the linear programs you mention might
take time O(n^3), n number of points (let's suppose n ~ d, d is the
dimension), just to check a single point (so it would take O(n^4) to
solve the problem I described). On the other hand,
http://cgm.cs.mcgill.ca/%7Eavis/doc/avis/Av98a.pdf mentions O(n d) <
O(n^2) for simple polyhedra and O(n^2 d) otherwise, for each extreme
point. That's mainly because it is like if we executed a single linear
program run (and doing the reverse search) while keeping the extremes
that are found while pivoting. Am I missing something?
I never looked into the details, so I may be wrong. Here is a recent cgal-related work on the subject:
http://e-collection.library.ethz.ch/view/eth:2225
I am not sending this email to the list because the question might be
too detailed, anyway I don't know if that's the proper think to do.
Rule of thumb: never send personal replies.
Marc Glisse
