- To:
- Subject: Fwd: [cgal-discuss] warnings in kds and polynomial_kernel testsuite
- Date: Wed, 26 Oct 2011 10:36:27 +0200
Hello,
I posted to the wrong list, but at least it shows
that we have testsuites, and that we continuously
work towards a better library ===:>-
best regards,
andreas
-------- Original Message --------
Subject: [cgal-discuss] warnings in kds and polynomial_kernel testsuite
Date: Wed, 26 Oct 2011 10:23:37 +0200
Reply-To:
To: Daniel Russel
Hi Daniel,
In your testsuites you issue warnings at runtime.
____________________________________________
KDS:
Using 50 degree 5 points.
WARNING: objects (27) and (26) are out of order.
0.0519388187919+0.157807128577*t+0.99999357108*t^2+0.204328610657*t^3+0.889955644445*t^4+0.125468475803*t^5
and
0.0699063977552+0.204655086251*t+0.461420473392*t^2+0.819677280178*t^3+0.573318628396*t^4+0.755580835396*t^5
Time is 0.354115
WARNING: order is Sort:
(27) with event (Never.)
(26) with event (Never.)
(20) with event (((20)X(3) out of failures))
(3) with event (((3)X(8) out of failures))
Polynomial_kernel
Polynomial:
-4365900-5040*t+1274073*t^2+72979*t^3-87647*t^4-1045*t^5+2275*t^6-79*t^7-17*t^8+1*t^9
Window: [-4, 7)
Solution: <-3> <-3> <2>
Solver: <-3> <-3> <2> <7>
WARNING Extra 7
Can you comment on this.
- Why are they there?
- Are they serious?
- Wwhat could be done to get rid of them?
- Do you have an estimate on how much
work this is?
best regards,
andreas
- [cgal-discuss] warnings in kds and polynomial_kernel testsuite, Andreas Fabri, 10/26/2011
- Fwd: [cgal-discuss] warnings in kds and polynomial_kernel testsuite, Andreas Fabri, 10/26/2011
- [cgal-discuss] A question about driving many Ansoft Maxwell programs on many machines, Zhanghong Tang, 10/27/2011
