- To:
- Subject: [cgal-discuss] nef polygons with Microsoft's Parallel Patterns Library
- Date: Wed, 26 Oct 2011 14:19:08 -0700
Hello,
Can nef polygons be used with Microsoft's PPL? The following code (CGAL 3.8) crashes during construction of either nef_polygon, even with CGAL_HAS_THREADS defined:
#include <cstdio>
#include <ppl.h>
#include <concurrent_vector.h>
#include <CGAL/Extended_cartesian.h>
#include <CGAL/CORE_Expr.h>
#include <CGAL/Nef_polyhedron_2.h>
typedef CORE::Expr NT;
typedef CGAL::Extended_cartesian<NT> K;
typedef CGAL::Nef_polyhedron_2<K> nef_polygon;
int main() {
Concurrency::parallel_invoke(([]() { nef_polygon p; }), ([]() { nef_polygon q; }));
printf("success\n");
return 0;
If this doesn't work, are nef polygons otherwise concurrency-safe? (i.e. should using them with boost::thread, for example, work?)
Cody
- [cgal-discuss] nef polygons with Microsoft's Parallel Patterns Library, Cody Rose, 10/26/2011
- Re: [cgal-discuss] nef polygons with Microsoft's Parallel Patterns Library, Sebastien Loriot (GeometryFactory), 10/27/2011
- Re: [cgal-discuss] nef polygons with Microsoft's Parallel Patterns Library, Cody Rose, 10/27/2011
