- To:
- Subject: Re: [cgal-discuss] convex hull, indices of extreme points
- Date: Sun, 30 Oct 2011 07:14:39 +0100
Sure of course - thanks Andreas for the Ideas!
Best,
Thomas
On Sat, Oct 29, 2011 at 23:16, Andreas Fabri
wrote:
> On 29/10/2011 22:20,
> wrote:
>> Dear CGAL community,
>> following
>> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Convex_hull_2/Chapter_main.html#Section_15.3
>> to perform a convec hull computation was quite simple and straight forward
>> thank you very much.
>> Starting from there: Is it possible to receive the indices of the
>> resulting
>> extreme points in the original set of points?
>> Thanks a lot,
>> Thomas
> The traits classes are all about this kind of plumbing.
> Instead of the transform iterator you could have first
> created a container with point/index pairs.
> See the attached code.
> best regards,
> andreas
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] convex hull, indices of extreme points, mail, 10/29/2011
- Re: [cgal-discuss] convex hull, indices of extreme points, Andreas Fabri, 10/29/2011
- Re: [cgal-discuss] convex hull, indices of extreme points, Thomas Ruland, 10/30/2011
