Re: [cgal-discuss] Re: Identify each face in an Arrangement if the input is a polygonal mesh?
- To:
- Subject: Re: [cgal-discuss] Re: Identify each face in an Arrangement if the input is a polygonal mesh?
- Date: Fri, 11 Nov 2011 18:48:39 +0200
The observer is used to construct the first 2 arrangements.
Then, while doing the overlay, you need to use the overlay traits.
It's all in the manual.
Quoting Graviton
Hello,
I can't quite see how the observer can keep track of the original face, as
when the time when I input the arrangement, I don't input in the original
face information. Mind to be more explicit about it?
On Tue, Nov 8, 2011 at 6:31 PM, Efraim Fogel [via cgal-discuss] <
wrote:
Extend the cells of the DCEL of the two arrangements [1] and use an
observer [2] to update the additional fields when the arrangements are
constructed. Then, use the overlay traits [3] to update the final
arrangement while performing the overlay operation.
[1]
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html#Section_31.8
[2]
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html#Section_31.7
[3]
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html#Section_31.9
Graviton wrote:
> I have two http://en.wikipedia.org/wiki/Polygon_mesh polygonal mesh
, with
> all the usual properties such as vertex and edge and the faces.
> Now I want to conduct an overlay between the two, so what I do is, I
create
> two arrangements, each for one polygonal mesh, and then use the overlay
> method to come up with the resultant.
> The problem is, how to construct each arrangement, such that for each
face
> in the arrangement, I can trace it back to the original face in the
> polygonal mesh? For each face in the polygonal mesh, there is a unique
> meaning assigned to it, so the arrangement has to know this when it is
> constructed.
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Identify-each-face-in-an-Arrangement-if-the-input-is-a-polygonal-mesh-tp3989865p3989865.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
If you reply to this email, your message will be added to the discussion
below:
http://cgal-discuss.949826.n4.nabble.com/Identify-each-face-in-an-Arrangement-if-the-input-is-a-polygonal-mesh-tp3989865p4015537.html
To unsubscribe from Identify each face in an Arrangement if the input is
a polygonal mesh?, click here<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3989865&code=c29vbmh1aS5uZ3VAZ21haWwuY29tfDM5ODk4NjV8NDk0OTIzNDUy>.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Identify-each-face-in-an-Arrangement-if-the-input-is-a-polygonal-mesh-tp3989865p4031348.html
- [cgal-discuss] Identify each face in an Arrangement if the input is a polygonal mesh?, Graviton, 11/04/2011
- Re: [cgal-discuss] Identify each face in an Arrangement if the input is a polygonal mesh?, Efraim Fogel, 11/08/2011
- [cgal-discuss] Re: Identify each face in an Arrangement if the input is a polygonal mesh?, Graviton, 11/11/2011
- Re: [cgal-discuss] Re: Identify each face in an Arrangement if the input is a polygonal mesh?, efif, 11/11/2011
- Re: [cgal-discuss] Re: Identify each face in an Arrangement if the input is a polygonal mesh?, Ben Supnik, 11/11/2011
