- To:
- Subject: Re: [cgal-discuss] Voronoi Diagram and NaN
- Date: Tue, 15 Nov 2011 12:22:24 +0100
I didn't look at you code but the best way to do that is
to use the draw_dual member functions.
You can copy for example what is done in
include/CGAL/CGAL_Ipelet_base_v7.h
in draw_dual_in_ipe line 729 which is drawing the dual
of a triangulation restricted to an iso rectangle (you can even simplify
this code to do everything in the stream functor).
Sebastien.
memecs wrote:
Hi,
I am trying to generate a bounded (by a rectangle) voronoi diagram. Here is
my code:
DT dt; dt.insert(points.begin(), points.end());
typedef typename K::Point_2 Point_2; typename K::Ray_2 ray; typename K::Line_2 line; typename K::Segment_2 segment;
vector<Polygon_2> bounded_voronoi_faces;
// Find to which voronoi face the boundary points belong to. list<std::pair<DT::Vertex_handle, Point_2> > nearest_vertices; for(int j = 0; j < 4; ++j) { DT::Vertex_handle nearest =
dt.nearest_vertex(bbox.vertex(j)); nearest_vertices.push_back(std::pair<DT::Vertex_handle,
Point_2>(nearest, bbox.vertex(j))); }
// Iterate over all delaunay vertices. Each vertex is a site of a
voronoi face. unsigned i = 0; for(DT::Finite_vertices_iterator fvit = dt.finite_vertices_begin(); fvit != dt.finite_vertices_end(); ++fvit, ++i) {
// Circulate over all edges incident to the current vertex. vector<Point_2> unique_points; DT::Edge_circulator ec = dt.incident_edges(fvit); do { if(!dt.is_infinite(ec)) { CGAL::Object voronoi_obj, intersection_obj; voronoi_obj = dt.dual(ec); if(CGAL::assign(segment,voronoi_obj)) { intersection_obj =
CGAL::intersection(segment,bbox); } else if(CGAL::assign(ray,voronoi_obj)) { intersection_obj =
CGAL::intersection(ray,bbox); }
else if(CGAL::assign(line,voronoi_obj)) { intersection_obj =
CGAL::intersection(line,bbox); } else { // Something is wrong??? assert(false); } typename K::Segment_2 intersected_segment; Point_2 intersected_point; if(CGAL::assign(intersected_segment,intersection_obj)) { // The object intersected unique_points.push_back(intersected_segment.source()); unique_points.push_back(intersected_segment.target()); } else { // If it's a point or didn't
intersect do nothing... } } } while(++ec != dt.incident_edges(fvit));
The problem is:
sometimes I get voronoi segments with source or target points equals to
NaN.
For example:
if(CGAL::assign(segment,voronoi_obj)) { Delaunay segment: 490 39 495 29 Voronoi segment: 493.5 34.5 -nan -nan }
I really don't understand how is this possible. The input points I use to
construct the delaunay triangulation don't overlap.
Does someone have an idea?
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Voronoi-Diagram-and-NaN-tp4042568p4042568.html
- [cgal-discuss] Voronoi Diagram and NaN, memecs, 11/15/2011
- Re: [cgal-discuss] Voronoi Diagram and NaN, Sebastien Loriot (GeometryFactory), 11/15/2011
- [cgal-discuss] Re: Voronoi Diagram and NaN, memecs, 11/15/2011
- Re: [cgal-discuss] Re: Voronoi Diagram and NaN, Sebastien Loriot (GeometryFactory), 11/15/2011
- Re: [cgal-discuss] Re: Voronoi Diagram and NaN, Sebastien Loriot (GeometryFactory), 11/16/2011
