- To:
- Subject: Re: [cgal-discuss] I still have problems with Alpha_Shape_3
- Date: Fri, 18 Nov 2011 10:32:50 +0100
Le jeudi 17 novembre 2011 12:53:09 Juan Carlos Lopez Alfonso a écrit :
> Hi:
> Well, I am following in details the examples and the documentation, but
> without lucky. I have used the input data of the examples in order to find
> more simplicity. My input set of points is "bunny_5000" and when I use the
> Alpha_Shape_3 class I dont see any desired results. Please see the
> following images:
> http://dl.dropbox.com/u/2516160/bunny1.png
> http://dl.dropbox.com/u/2516160/bunny2.png
> I have followed the first example in the charapter of Alpha_Shape_3 and for
> this reason my code is very simple.
> http://dl.dropbox.com/u/2516160/code.txt
Let me quote your code:
> void Export2OFF(char * filedir, const Alpha_shape_3 &T, const
> std::map<Vertex_handle, int> &Vertices, const std::list<Cell_handle>
> &cells) {
> ofstream myfile (filedir);
> if (myfile.is_open())
> myfile << "OFF" << "\n";
> myfile << Vertices.size() << ' ' << cells.size() << ' ' << 0
> << "\n";
> std::map<Vertex_handle, int>::const_iterator vit;
> for (vit = Vertices.begin(); vit != Vertices.end(); vit++)
> myfile << vit->first->point().x() << ' ' <<
> vit->first->point().y()
> << ' ' << vit->first->point().z() << "\n";>
> std::list<Cell_handle>::const_iterator itr;
> for (itr = cells.begin(); itr != cells.end(); itr++)
> Cell_handle cit = *itr;
> myfile << 4 << ' ' <<
> Vertices.find(cit->vertex(0))->second-1 << ' '
> << Vertices.find(cit->vertex(1))->second-1 << ' ' <<
> Vertices.find(cit->vertex(2))->second-1 << ' ' <<
> Vertices.find(cit->vertex(3))->second-1 << "\n";
The OFF format is for polygonal faces only. "4" does not mean that the lines
is a tetrahedron. Here you put in the OFF file some non planar faces with 4
vertices. I am not surprised that you OFF viewer display non-sense.
Laurent Rineau, PhD
- [cgal-discuss] I still have problems with Alpha_Shape_3, Juan Carlos Lopez Alfonso, 11/17/2011
- Re: [cgal-discuss] I still have problems with Alpha_Shape_3, Daniel Duque, 11/17/2011
- Re: [cgal-discuss] I still have problems with Alpha_Shape_3, Juan Carlos Lopez Alfonso, 11/18/2011
- Re: [cgal-discuss] I still have problems with Alpha_Shape_3, Sebastien Loriot (GeometryFactory), 11/18/2011
- Re: [cgal-discuss] I still have problems with Alpha_Shape_3, Laurent Rineau (GeometryFactory), 11/18/2011
