- To:
- Subject: Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3
- Date: Thu, 24 Nov 2011 10:59:14 +0200
Le 11/24/11 10:29 AM, Juan Carlos Lopez Alfonso a écrit :
Hello Andreas,could you compress it ?
Thank you for your answers.
Andreas Fabri this is the link with my set of points: http://dl.dropbox.com/u/2516160/ALLtreatmentPoints.txt
it seems that your points are non only in parallel planes but are actually taken
from a grid.
In such a case you will have many cospherical (and even cocircular) points
which create a lot of calls to the exact arithmetic.
Notice that computing the Delaunay triangulation of a (full) grid is quite easy
and should not be done using a standard Delaunay algorithm.
Thus if your data set contains pieces of grid, and you know it,
you may triangulate these parts "by hand"
Olivier
- [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Juan Carlos Lopez Alfonso, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Monique Teillaud, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Juan Carlos Lopez Alfonso, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Olivier Devillers, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Andreas Fabri, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Daniel Duque, 11/25/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Louis Lavery, 11/25/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Andreas Fabri, 11/25/2011
