- To: CGAL discussion list <>
- Subject: [cgal-discuss] 3D Triangulation with extra info
- Date: Mon, 28 Nov 2011 15:11:48 +0000
hi,
I'm computing a 3D Triangulation, adding an unsigned integer to each
vertex (that integer identifies each vertex at another structure).
Computing it with a Delaunay triangulation I'm able to do it with:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K> Vb;
typedef CGAL::Triangulation_data_structure_3<Vb> Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds> Triangulation;
typedef Triangulation::Point
Point;
typedef std::pair<Point,unsigned> point_x;
/* and later computing it with: */
std::vector<point_x> points;
/* fill points array with std::make_pair(...), and */
T.insert(points.begin(), points.end());
but with the simple 3D triangulation, the above scheme does not work.
That is: just exchanging
with
typedef CGAL::Triangulation_3<K, Tds> Triangulation;
All I get is a lot of compile errors, linked to the
line.
The work-around I found (here at cgal-discuss) is to mimic the
T.insert(), assigning the extra info (the unsigned integer) after
creating each vertex.
My question is: is there any way to create a simple 3D triangulation
with extra info like in the Delaunay example?
Thanks,
Joao Dinis
- [cgal-discuss] 3D Triangulation with extra info, Joao Dinis, 11/28/2011
- Re: [cgal-discuss] 3D Triangulation with extra info, Sebastien Loriot (GeometryFactory), 11/28/2011
