Re: [cgal-discuss] Constraint Delaunay Triangulation: How to triangulate a set of polygons
- To:
- Subject: Re: [cgal-discuss] Constraint Delaunay Triangulation: How to triangulate a set of polygons
- Date: Wed, 30 Nov 2011 15:09:01 +0100
See this entry:
http://www.cgal.org/FAQ.html#polygon_triangulation
I also joint an example that does that and even handle nested
polygons.
Sebastien.
Graviton wrote:
I have a set of polygons, which, when union together, can form multiple giant
concave or convex polygon(s) with opening.
I want to triangulate these polygons. All the points I have are polygon
points. I don't want to create extra points, which is why I can't use mesh
generation. Instead, I am trying to use constraint delaunay triangulation
for the purpose here.
But now my problem is that, the Constraint Delaunay Triangulation will
return me all the triangles, and some of them will be out of the original
polygon set. How to identify these out-of-original-polygon-set triangles and
discard them?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Constraint-Delaunay-Triangulation-How-to-triangulate-a-set-of-polygons-tp4122741p4122741.html
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Constrained_Delaunay_triangulation_2.h> #include <CGAL/Triangulation_face_base_with_info_2.h> #include <CGAL/Polygon_2.h> #include <boost/next_prior.hpp> #include <iostream> struct FaceInfo2 { FaceInfo2(){} int nesting_level; bool in_domain(){ return nesting_level%2 == 1; } }; typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Triangulation_vertex_base_2<K> Vb; typedef CGAL::Triangulation_face_base_with_info_2<FaceInfo2,K> Fbb; typedef CGAL::Constrained_triangulation_face_base_2<K,Fbb> Fb; typedef CGAL::Triangulation_data_structure_2<Vb,Fb> TDS; typedef CGAL::Exact_predicates_tag Itag; typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS, Itag> CDT; typedef CDT::Point Point; typedef CGAL::Polygon_2<K> Polygon; void mark_domains(CDT& ct, CDT::Face_handle start, int index, std::list<CDT::Edge>& border ) { if(start->info().nesting_level != -1){ return; } std::list<CDT::Face_handle> queue; queue.push_back(start); while(! queue.empty()){ CDT::Face_handle fh = queue.front(); queue.pop_front(); if(fh->info().nesting_level == -1){ fh->info().nesting_level = index; for(int i = 0; i < 3; i++){ CDT::Edge e(fh,i); CDT::Face_handle n = fh->neighbor(i); if(n->info().nesting_level == -1){ if(ct.is_constrained(e)) border.push_back(e); else queue.push_back(n); } } } } } //explore set of facets connected with non constrained edges, //and attribute to each such set a nesting level. //We start from facets incident to the infinite vertex, with a nesting //level of 0. Then we recursively consider the non-explored facets incident //to constrained edges bounding the former set and increase the nesting level by 1. //Facets in the domain are those with an odd nesting level. void mark_domains(CDT& cdt) { for(CDT::All_faces_iterator it = cdt.all_faces_begin(); it != cdt.all_faces_end(); ++it){ it->info().nesting_level = -1; } int index = 0; std::list<CDT::Edge> border; mark_domains(cdt, cdt.infinite_face(), index++, border); while(! border.empty()){ CDT::Edge e = border.front(); border.pop_front(); CDT::Face_handle n = e.first->neighbor(e.second); if(n->info().nesting_level == -1){ mark_domains(cdt, n, e.first->info().nesting_level+1, border); } } } void insert_polygon(CDT& cdt,const Polygon& polygon){ if ( polygon.is_empty() ) return; CDT::Vertex_handle v_prev=cdt.insert(*boost::prior(polygon.vertices_end())); for (Polygon::Vertex_iterator vit=polygon.vertices_begin(); vit!=polygon.vertices_end();++vit) { CDT::Vertex_handle vh=cdt.insert(*vit); cdt.insert_constraint(vh,v_prev); v_prev=vh; } } int main( ) { //construct two non-intersecting nested polygons Polygon polygon1; polygon1.push_back(Point(0,0)); polygon1.push_back(Point(2,0)); polygon1.push_back(Point(2,2)); polygon1.push_back(Point(0,2)); Polygon polygon2; polygon2.push_back(Point(0.5,0.5)); polygon2.push_back(Point(1.5,0.5)); polygon2.push_back(Point(1.5,1.5)); polygon2.push_back(Point(0.5,1.5)); //Insert the polyons into a constrained triangulation CDT cdt; insert_polygon(cdt,polygon1); insert_polygon(cdt,polygon2); //Mark facets that are inside the domain bounded by the polygon mark_domains(cdt); int count=0; for (CDT::Finite_faces_iterator fit=cdt.finite_faces_begin(); fit!=cdt.finite_faces_end();++fit) { if ( fit->info().in_domain() ) ++count; } std::cout << "There are " << count << " facets in the domain." << std::endl; return 0; }
- [cgal-discuss] Constraint Delaunay Triangulation: How to triangulate a set of polygons, Graviton, 11/30/2011
- Re: [cgal-discuss] Constraint Delaunay Triangulation: How to triangulate a set of polygons, Sebastien Loriot (GeometryFactory), 11/30/2011
