- To:
- Subject: Re: [cgal-discuss] Check which mesh element is inside the original polygons
- Date: Tue, 06 Dec 2011 08:32:00 +0100
For each polygon, insert each edges in the CDT by first inserting the endpoints and then constraining the edge using the corresponding vertex_handle.
You have then two choices:
*if you have your polygons consistently oriented (says counterclockwise for example), associate into a map, the ordered pair of vertex_handle
to the polygon id.
*otherwise, sort the vertex_handle pair and associate the pair into a multimap the polygon id.
The final step is to mark each face in the CDT (either use a map or a face type with info). Reconstruct each polygon by using maximal connected component of faces connected with non-constrained edges by starting from faces incident to the infinite vertex.
(see this for example: https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2011-11/msg00150.html).
The id of the polygon is given by the id of the edge crossed given by the map or multimap.
Sebastien.
Graviton wrote:
I have a set of non-overlapping polygons. These polygons can share nodes,
edges, but strictly no overlapping.
Now, I am going to mesh them using Constrainted Delaunay Triangulation (CDT)
technique. I can get the mesh without problem.
My problem is, after the mesh, I want to know which mesh element belongs to
which original polygon. MY current approach is to compute the centroid for
each mesh element, and check which of the original polygon this centroid
falls into. But I don't like this approach as it is very computationally
intensive.
Is there any efficient ways to do this ( in terms of Big O the runtime)? My
projects involve tens of thousands of polygons and I don't want the speed to
slow down.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Check-which-mesh-element-is-inside-the-original-polygons-tp4163729p4163729.html
- [cgal-discuss] Check which mesh element is inside the original polygons, Graviton, 12/06/2011
- Re: [cgal-discuss] Check which mesh element is inside the original polygons, Sebastien Loriot (GeometryFactory), 12/06/2011
