- To:
- Subject: Re: [cgal-discuss] Accessing vertices and simplex information
- Date: Tue, 06 Dec 2011 13:35:51 +0100
The function
template <class C2t3>
bool output_surface_facets_to_off (std::ostream& os,
const C2t3& c2t3,
int options =
Surface_mesher::IO_ORIENT_SURFACE)
available in file
CGAL/IO/complex_2_in_triangulation_3_file_writer.h
should do more or less what you want
Le 06/12/11 11:32, phdprav a écrit :
Dear cgal community,
I am new to CGAL and this should hopefully be a rather simple question. I am
trying to obtain the vertices and corresponding simplex for a 3D surface
defined implicitely as a level set function. My starting point is the
example program mesh_an_implicit_function.cpp
I'd like to modify this program so that it outputs a file with a format
similar to the one shown below:
VERTEX // Coordinates of the vertices
1 0 1 // vertex 0
0 -1 0 // vertex 1
1 0 0 // vertex 2
1 0 -1
-1 0 0
0 1 0
SIMPLEX
0 1 2 // triangle 0 made up of vertex 0, 1, 2.
1 3 2
1 4 3
4 5 0
0 1 4
4 5 3
0 5 2
5 3 2
So basically all I want is to access the vertices, and to know which
vertices form which elements, of a given mesh generated by the example code
mesh_an_implicit_function.cpp. Any advice on how I should go about doing
this? Thank you.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Accessing-vertices-and-simplex-information-tp4164177p4164177.html
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- [cgal-discuss] Accessing vertices and simplex information, phdprav, 12/06/2011
- Re: [cgal-discuss] Accessing vertices and simplex information, Mariette Yvinec, 12/06/2011
