cgal-discuss - Re: [cgal-discuss] Point location in tetrahedral meshes
  • To:
  • Subject: Re: [cgal-discuss] Point location in tetrahedral meshes
  • Date: Fri, 09 Dec 2011 09:31:22 +0100
You can embedded your mesh into a Triangulation_3 and then use the
locate function. Note that you need to have a triangulate of the convex
hull of your domain (you can use a Cell type with info to have a
is_in_domain tag). All you need to do must be done at the TDS level. My
advice would be to look at how copy_tds is implemented to see how you
could modify it to import you own triangulation
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_cell_base_with_info_3.html
Another solution is to use CGAL to generate the 3D mesh:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3/Chapter_main.html
Sebastien.
Andreas Puettmann wrote:
Hi all!
For CFD post processing, I want to interpolate Finite Element solutions
from a purely tetrahedral 3D mesh to a new mesh of arbitrary elements.
Hence, I am looking for an algorithm which can efficiently perform a
point location search in 3D on tetrahedral meshes of *non-convex* domains.
I'd appreciate very much, if anyone could point me to either a ready
implementation for that or to how this could be realized with CGAL.
Cheers,
Andreas
Dipl.-Ing. Andreas Puettmann
Institute of Bio- and Geosciences
IBG-1: Biotechnology
Research Center Juelich
Tel +49 2461 61 5541
Fax +49 2461 61 3870
Web www.fz-juelich.de/ibt/modsim
Forschungszentrum Juelich GmbH
52425 Juelich
Sitz der Gesellschaft: Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Vorsitzender des Aufsichtsrats: MinDirig Dr. Karl Eugen Huthmacher
Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Prof. Dr. Sebastian M. Schmidt
