- To:
- Subject: Re: [cgal-discuss] Arrangement_2 multiple vertex
- Date: Sat, 10 Dec 2011 10:18:09 +0200
It is impossible to have an edge with the same source and target points, as the geometric embeddings of the edges are x-monotone.
Quoting "cyril bordreuil"
Hi everybody
I have segments that i want to connect. Sometimes my segments are totally connected
and sometimes it is an open contour.
I tried to use Arrangement_2 class to find the contour. I build my arrangement from segments and
when i am travelling the halfedges, i have some halfedges with same source and target vertex.
Is it possible? and is it possible to remove this kind of halfedges at construction?
Thank you very much
Cyril
- [cgal-discuss] Arrangement_2 multiple vertex, cyril bordreuil, 12/09/2011
- Re: [cgal-discuss] Arrangement_2 multiple vertex, efif, 12/10/2011
