- To:
- Subject: Re: [cgal-discuss] how do you seed the random number generator?
- Date: Sat, 10 Dec 2011 19:28:41 +0100
Edoardo Milotti
writes:
> I am developing a program where the order of vertices of a Delaunay
> triangulation matters, and I wish to obtain the same sequence of vertices
> in repeated runs. Thus I need to set the seed of the CGAL random number
> generator. Does anybody know how to do it in the current version of CGAL?
> Thank you.
CGAL::Random takes an unsigned int as its seed argument and the
generator constructors take a CGAL::Random as an argument (which
defaults to a default constructed CGAL::Random).
See:
http://www.cgal.org/Manual/3.8/doc_html/cgal_manual/Generator_ref/Class_Random.html
and
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Generator_ref/Concept_PointGenerator.html
HTH,
Philipp
- [cgal-discuss] how do you seed the random number generator?, Edoardo Milotti, 12/10/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] how do you seed the random number generator?, Philipp Moeller, 12/10/2011
- Re: [cgal-discuss] how do you seed the random number generator?, Edoardo Milotti, 12/10/2011
