- To:
- Subject: [cgal-discuss] BUG: Multi-threaded Delaunay_Triangulation_2 crashing...
- Date: Mon, 12 Dec 2011 12:49:05 -0800 (PST)
I tried using a Delaunay_Triangulation_2 in a multithreaded environment. I'm
using arch linux, 64-bit, and CGAL 3.9-2, boost 1.48.0-2
My code is something like this:
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_vertex_base_with_info_2.h>
#include <CGAL/Triangulation_face_base_with_info_2.h>
typedef CGAL::Triangulation_vertex_base_with_info_2<voronoi_data, K> Vb;
typedef CGAL::Triangulation_face_base_with_info_2<face_data, K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<K, Tds> Triangulation;
void GetColor(Triangulation *t, ...) {
Vertex new_v = t->insert(current_point);
t->remove(new_v);
void main() {
#pragma omp parallel for
// Reconstruct image
for (int y = 0; y < height_; y++) {
for (int x = 0; x < width_; x++) {
GetColor(&(ts_[omp_get_thread_num()]), ...);
Here, ts_ is a vector of "Triangulation", where each triangulation is
independently set up. That means, each thread has its OWN cgal objects!
When I run this, I get a segmentation fault. However, using:
#pragma omp critical
t->remove(new_v);
instead, makes it work! That means, the remove function must do something
that is not thread-safe, though every thread operates on its own
triangulation...
Regards
Jan Rüegg
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/BUG-Multi-threaded-Delaunay-Triangulation-2-crashing-tp4187557p4187557.html
- [cgal-discuss] BUG: Multi-threaded Delaunay_Triangulation_2 crashing..., Jan Rüegg, 12/12/2011
- Re: [cgal-discuss] BUG: Multi-threaded Delaunay_Triangulation_2 crashing..., Marc Glisse, 12/12/2011
- Re: [cgal-discuss] BUG: Multi-threaded Delaunay_Triangulation_2 crashing..., Olivier Devillers, 12/13/2011
- [cgal-discuss] Re: BUG: Multi-threaded Delaunay_Triangulation_2 crashing..., Jan Rüegg, 12/13/2011
