Re: [cgal-discuss] Re: impossible to compiling simple example simple_triangulation_3
- To:
- Subject: Re: [cgal-discuss] Re: impossible to compiling simple example simple_triangulation_3
- Date: Wed, 14 Dec 2011 10:30:25 +0100
pipalapop wrote:
my header file is ok.Your answer is not clear. Did you check or you are saying you did not
I just use files like provide by the Windows'setup.
modify it so it's OK? I asked the question because it happened once to
me that while unzipping CGAL source only one file get changed in a
strangely consistent way (never been able to reproduced it then).
Sebastien.
I tried on a Linux virtual machine and the generation is good.
I think that my problem is linked to my plattform but I have no idea of its
origin.
is there specific files associate to each plattform that can have an
incidence?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/impossible-to-compiling-simple-example-simple-triangulation-3-tp4190897p4194189.html
- [cgal-discuss] impossible to compiling simple example simple_triangulation_3, pipalapop, 12/13/2011
- Re: [cgal-discuss] impossible to compiling simple example simple_triangulation_3, Sebastien Loriot (GeometryFactory), 12/14/2011
- [cgal-discuss] Re: impossible to compiling simple example simple_triangulation_3, pipalapop, 12/14/2011
- Re: [cgal-discuss] Re: impossible to compiling simple example simple_triangulation_3, Sebastien Loriot (GeometryFactory), 12/14/2011
- Re: [cgal-discuss] impossible to compiling simple example simple_triangulation_3, Laurent Rineau (GeometryFactory), 12/14/2011
