cgal-discuss - Re: [cgal-discuss] Re: VC compiler issue: static filter in cgal 3.8
  • To:
  • Subject: Re: [cgal-discuss] Re: VC compiler issue: static filter in cgal 3.8
  • Date: Fri, 16 Dec 2011 11:29:01 +0100
Hi Hamid,
This should be the fix.
The file must go into
include/CGAL/internal/Static_filters/
I took it from an internal latest release
but it shouldwork with the public one.
Best regards,
andreas
On 16/12/2011 11:21, Hamid G wrote:
Laurent Rineau (GeometryFactory) wrote
Our test machine got upgraded to VC2010sp1 too (it was a security update).
Tonight the nighly testsuite of CGAL will be using the CGAL-3.8 branch,
and
tomorrow I will be able to tell you if we reproduced your issue.
Hello,
I am getting the same error while compiling my code using /O2 option:
c:\users\hamid\local\cgal\3.8-vc10-w64\include\cgal\internal\static_filters\power_test_3.h(178):
fatal error C1001: An internal error has occurred in the compiler.
2> (compiler file
'f:\dd\vctools\compiler\utc\src\p2\main.c[0x5C45B0D8:0x00000028]', line 183)
Have you guys been able to reproduce this?
thanks,
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/VC-compiler-issue-static-filter-in-cgal-3-8-tp3465534p4203993.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
// Copyright (c) 2009 INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/features/Power_test_3-VC_64bit-GF/Triangulation_3/include/CGAL/internal/Static_filters/Power_test_3.h
// $Id: Power_test_3.h 65898 2011-10-14 13:04:06Z afabri $
// Author(s) : Sebastien Loriot
// This predicates was generated using the fpg tool written by Andreas Meyer.
#ifndef CGAL_INTERNAL_STATIC_FILTERS_POWER_TEST_3_H
#define CGAL_INTERNAL_STATIC_FILTERS_POWER_TEST_3_H
#include <CGAL/Profile_counter.h>
#include <CGAL/internal/Static_filters/Static_filter_error.h>
#include <cmath>
namespace CGAL { namespace internal { namespace Static_filters_predicates {
template <typename K_base>
class Power_test_3:
public K_base::Power_test_3
typedef typename K_base::Weighted_point_3 Weighted_point_3;
typedef typename K_base::FT FT;
typedef typename K_base::Power_test_3 Base;
public:
typedef typename Base::result_type result_type;
#ifndef CGAL_CFG_MATCHING_BUG_6
using Base::operator();
#else
result_type
operator()(const Weighted_point_3& p, const Weighted_point_3& q) const
return Base::operator()(p,q);
#endif
void
msvc_workaround(double& max1, double& max2, double& max3, double& max4,
double& max5, double& RT_tmp_result,
double px, double py, double pz, double pwt,
double qx, double qy, double qz, double qwt,
double rx, double ry, double rz, double rwt,
double sx, double sy, double sz, double swt,
double tx, double ty, double tz, double twt) const
double dpx = (px - tx);
double dpy = (py - ty);
double dpz = (pz - tz);
double twt_pwt = (twt - pwt);
double dpt = (((square( dpx ) + square( dpy )) + square( dpz )) +
twt_pwt);
double dqx = (qx - tx);
double dqy = (qy - ty);
double dqz = (qz - tz);
double twt_qwt = (twt - qwt);
double dqt = (((square( dqx ) + square( dqy )) + square( dqz )) +
twt_qwt);
double drx = (rx - tx);
double dry = (ry - ty);
double drz = (rz - tz);
double twt_rwt = (twt - rwt);
double drt = (((square( drx ) + square( dry )) + square( drz )) +
twt_rwt);
double dsx = (sx - tx);
double dsy = (sy - ty);
double dsz = (sz - tz);
double twt_swt = (twt - swt);
double dst = (((square( dsx ) + square( dsy )) + square( dsz )) +
twt_swt);
// double
RT_tmp_result = CGAL::determinant( dpx, dpy, dpz, dpt, dqx, dqy, dqz,
dqt, drx, dry, drz, drt, dsx, dsy, dsz, dst );
// double
max2 = CGAL::abs(dpx);
double adqx = CGAL::abs(dqx);
double adqy = CGAL::abs(dqy);
double adqz = CGAL::abs(dqz);
double adrx = CGAL::abs(drx);
double adry = CGAL::abs(dry);
double adrz = CGAL::abs(drz);
double adsx = CGAL::abs(dsx);
double adsy = CGAL::abs(dsy);
double adsz = CGAL::abs(dsz);
double atwt_qwt = CGAL::abs(twt_qwt);
double atwt_rwt = CGAL::abs(twt_rwt);
double atwt_swt = CGAL::abs(twt_swt);
if( (max2 < adqx) ) max2 = adqx;
if( (max2 < adrx) ) max2 = adrx;
if( (max2 < adsx) ) max2 = adsx;
max1 = max2;
max3 = CGAL::abs(dpy);
if( (max3 < adqy) ) max3 = adqy;
if( (max3 < adry) ) max3 = adry;
if( (max3 < adsy) ) max3 = adsy;
if( (max1 < max3) ) max1 = max3;
max4 = CGAL::abs(dpz);
if( (max4 < adqz) ) max4 = adqz;
if( (max4 < adrz) ) max4 = adrz;
if( (max4 < adsz) ) max4 = adsz;
if( (max1 < max4) ) max1 = max4;
max5 = CGAL::abs(twt_pwt);
if( (max5 < atwt_qwt) ) max5 = atwt_qwt;
if( (max5 < atwt_rwt) ) max5 = atwt_rwt;
if( (max5 < atwt_swt) ) max5 = atwt_swt;
result_type operator() ( const Weighted_point_3 & p,
const Weighted_point_3 & q,
const Weighted_point_3 & r,
const Weighted_point_3 & s,
const Weighted_point_3 & t) const
CGAL_BRANCH_PROFILER_3("semi-static failures/attempts/calls to :
Power_test_3 with 4+1 wpoints", tmp);
double px, py, pz, pwt, qx, qy, qz, qwt, rx, ry, rz, rwt, sx, sy, sz,
swt, tx, ty, tz, twt;
if( fit_in_double(p.x(), px) && fit_in_double(p.y(), py) &&
fit_in_double(p.z(), pz) && fit_in_double(p.weight(), pwt) &&
fit_in_double(q.x(), qx) && fit_in_double(q.y(), qy) &&
fit_in_double(q.z(), qz) && fit_in_double(q.weight(), qwt) &&
fit_in_double(r.x(), rx) && fit_in_double(r.y(), ry) &&
fit_in_double(r.z(), rz) && fit_in_double(r.weight(), rwt) &&
fit_in_double(s.x(), sx) && fit_in_double(s.y(), sy) &&
fit_in_double(s.z(), sz) && fit_in_double(s.weight(), swt) &&
fit_in_double(t.x(), tx) && fit_in_double(t.y(), ty) &&
fit_in_double(t.z(), tz) && fit_in_double(t.weight(), twt)
CGAL_BRANCH_PROFILER_BRANCH_1(tmp);
// We split the operator as we get an ICE with VC9 and VC10
// when we compile 64 bit code
#if defined (BOOST_MSVC) && defined ( _WIN64)
double max1,max2,max3,max4,max5;
double RT_tmp_result;
msvc_workaround(max1,max2,max3,max4,max5, RT_tmp_result,
px, py, pz, pwt,
qx, qy, qz, qwt,
rx, ry, rz, rwt,
sx, sy, sz, swt,
tx, ty, tz, twt);
#else
twt_pwt);
twt_qwt);
twt_rwt);
twt_swt);
double RT_tmp_result = CGAL::determinant( dpx, dpy, dpz, dpt, dqx,
dqy, dqz, dqt, drx, dry, drz, drt, dsx, dsy, dsz, dst );
double max2 = CGAL::abs(dpx);
double max1 = max2;
double max3 = CGAL::abs(dpy);
double max4 = CGAL::abs(dpz);
double max5 = CGAL::abs(twt_pwt);
#endif
double lower_bound_1 = max1;
double upper_bound_1 = max1;
if( (max2 < lower_bound_1) ) lower_bound_1 = max2;
if( (max3 < lower_bound_1) ) lower_bound_1 = max3;
if( (max4 < lower_bound_1) ) lower_bound_1 = max4;
//handwritten workaround to handle case where all weights are equal
//if( ((lower_bound_1 < 1.05893684636332247212e-59) || (max5 <
1.12134724458589890404e-118)) )
1.12134724458589890404e-118 && max5!=0)) )
CGAL_BRANCH_PROFILER_BRANCH_2(tmp);
return Base::operator()(p,q,r,s,t);
else
if( ((upper_bound_1 > 3.21387608851797948065e+60) || (max5 >
1.03289995123476274781e+121)) )
result_type int_tmp_result;
double eps = (1.67106803095990471147e-13 * (((max2 * max3) *
max4) * (CGAL::max) ( max5, (max1 * max1) )));
if( (RT_tmp_result > eps) )
int_tmp_result = NEGATIVE;
else
if( (RT_tmp_result < -eps) )
int_tmp_result = POSITIVE;
else
return int_tmp_result;
else
Power_test_3 with 3+1 wpoints", tmp);
double px, py, pz, pwt, qx, qy, qz, qwt, rx, ry, rz, rwt, tx, ty, tz,
twt;
twt_pwt);
twt_qwt);
twt_rwt);
int cmp;
int int_tmp_result;
double eps;
double RT_tmp_result = CGAL::determinant( dpx, dpy, dpt, dqx, dqy,
dqt, drx, dry, drt );
double max7 = CGAL::abs(dpz);
if( (max7 < adqz) ) max7 = adqz;
if( (max7 < adrz) ) max7 = adrz;
double max1 = max7;
if( (max1 < max2) ) max1 = max2;
double max4 = CGAL::abs(twt_pwt);
if( (max4 < atwt_qwt) ) max4 = atwt_qwt;
if( (max4 < atwt_rwt) ) max4 = atwt_rwt;
double lower_bound_1;
double upper_bound_1;
//if( ((lower_bound_1 < 2.92391967062015793913e-74) || (max4 <
8.54930624023949352313e-148)) )
8.54930624023949352313e-148 && max4!=0)) )
return Base::operator()(p,q,r,t);
else
if( ((upper_bound_1 > 7.23700557733225980357e+75) || (max4 >
5.23742497263382350320e+151)) )
double eps = (3.04426660386257731823e-14 * ((max2 * max3) *
(CGAL::max)( max4, (max1 * max1) )));
int_tmp_result = 1;
else
int_tmp_result = -1;
else
cmp = int_tmp_result;
double px_rx = (px - rx);
double qy_ry = (qy - ry);
double qx_rx = (qx - rx);
double py_ry = (py - ry);
double max5 = CGAL::abs(px_rx);
double aqx_rx =CGAL::abs(qx_rx);
double apy_ry =CGAL::abs(py_ry);
if( max5 < aqx_rx ) max5 = aqx_rx;
double max6 = CGAL::abs(qy_ry);
if( max6 < apy_ry ) max6 = apy_ry;
if( (cmp != 0) )
int int_tmp_result_FFWKCAA;
double double_tmp_result;
double_tmp_result = ((px_rx * qy_ry) - (qx_rx * py_ry));
lower_bound_1 = max5;
upper_bound_1 = max5;
if( (max6 < lower_bound_1) ) lower_bound_1 = max6;
else
if( (max6 > upper_bound_1) ) upper_bound_1 = max6;
if( (lower_bound_1 < 5.00368081960964690982e-147) )
else
if( (upper_bound_1 > 7.23700557733225980357e+75) )
double eps = (8.88720573725927976811e-16 * (max5 * max6));
if( (double_tmp_result > eps) ) int_tmp_result_FFWKCAA = 1;
else
if( (double_tmp_result < -eps) )
int_tmp_result_FFWKCAA = -1;
else
return static_cast<result_type>(cmp * int_tmp_result_FFWKCAA);
int int_tmp_result_k60Ocge;
double RT_tmp_result_3SPBwDj = CGAL::determinant( dpx, dpz, dpt, dqx,
dqz, dqt, drx, drz, drt );
if( (max7 < lower_bound_1) ) lower_bound_1 = max7;
else
eps = (3.04426660386257731823e-14 * ((max2 * max7) * (CGAL::max)(
if( (RT_tmp_result_3SPBwDj > eps) )
int_tmp_result_k60Ocge = 1;
else
if( (RT_tmp_result_3SPBwDj < -eps) )
int_tmp_result_k60Ocge = -1;
else
cmp = int_tmp_result_k60Ocge;
double qz_rz = (qz - rz);
double pz_rz = (pz - rz);
double max8 = CGAL::abs(qz_rz);
double apz_rz = CGAL::abs(pz_rz);
if( max8 < apz_rz ) max8 = apz_rz;
if( (cmp != 0) )
int int_tmp_result_k3Lzf6g;
double double_tmp_result_Gx4H;
double_tmp_result_Gx4H = ((px_rx * qz_rz) - (qx_rx * pz_rz));
if( (max8 < lower_bound_1) ) lower_bound_1 = max8;
else
if( (max8 > upper_bound_1) ) upper_bound_1 = max8;
else
eps = (8.88720573725927976811e-16 * (max5 * max8));
if( (double_tmp_result_Gx4H > eps) )
int_tmp_result_k3Lzf6g = 1;
else
if( (double_tmp_result_Gx4H < -eps) )
int_tmp_result_k3Lzf6g = -1;
else
return static_cast<result_type>(cmp * int_tmp_result_k3Lzf6g);
int int_tmp_result_AvrrXBP;
double RT_tmp_result_feLwnHn = CGAL::determinant( dpy, dpz, dpt, dqy,
dqz, dqt, dry, drz, drt );
else
eps = (3.04426660386257731823e-14 * ((max3 * max7) * (CGAL::max)(
if( (RT_tmp_result_feLwnHn > eps) )
int_tmp_result_AvrrXBP = 1;
else
if( (RT_tmp_result_feLwnHn < -eps) )
int_tmp_result_AvrrXBP = -1;
else
cmp = int_tmp_result_AvrrXBP;
int int_tmp_result_agX3WsT;
double double_tmp_result_Dw20Kqh = ((py_ry * qz_rz) - (qy_ry *
pz_rz));
else
else
eps = (8.88720573725927976811e-16 * (max6 * max8));
if( (double_tmp_result_Dw20Kqh > eps) )
int_tmp_result_agX3WsT = 1;
else
if( (double_tmp_result_Dw20Kqh < -eps) )
int_tmp_result_agX3WsT = -1;
else
return static_cast<result_type>(cmp * int_tmp_result_agX3WsT);
else
Power_test_3 with 2+1 wpoints", tmp);
double px, py, pz, pwt, qx, qy, qz, qwt, tx, ty, tz, twt;
twt_pwt);
twt_qwt);
int cmp = ((px > qx) ? 1 : ((px < qx) ? -1 : 0));
double eps;
double max1;
double max4 = CGAL::abs(dpy);
if( max4 < adqy ) max4 = adqy;
max1 = max4;
double max5 = CGAL::abs(dpz);
if( max5 < adqz ) max5 = adqz;
if( max1 < max5 ) max1 = max5;
if( max2 < adqx ) max2 = adqx;
if( max1 < max2 ) max1 = max2;
double max3 = CGAL::abs(twt_pwt);
if( max3 < atwt_qwt ) max3 = atwt_qwt;
if( (cmp != 0) )
int int_tmp_result;
double_tmp_result = ((dpx * dqt) - (dqx * dpt));
equal
//if( ((lower_bound_1 < 4.89808663633813414271e-98) || (max3 <
2.39912526970742181620e-195)) )
2.39912526970742181620e-195 && max3!=0)) )
return Base::operator()(p,q,t);
else
if( ((upper_bound_1 > 5.59936185544450928309e+101) || (max3 >
3.13528531882069776730e+203)) )
eps = (6.88858782307641768480e-15 * (max2 * (CGAL::max)(
max3, (max1 * max1) )));
int_tmp_result = 1;
else
else
return static_cast<result_type>(cmp * int_tmp_result);
cmp = ((py > qy) ? 1 : ((py < qy) ? -1 : 0));
if( (cmp != 0) )
double double_tmp_result_k60Ocge;
double_tmp_result_k60Ocge = ((dpy * dqt) - (dqy * dpt));
else
eps = (6.88858782307641768480e-15 * (max4 * (CGAL::max)( max3,
(max1 * max1) )));
if( (double_tmp_result_k60Ocge > eps) )
else
if( (double_tmp_result_k60Ocge < -eps) )
else
cmp = ((pz > qz) ? 1 : ((pz < qz) ? -1 : 0));
int int_tmp_result_3SPBwDj;
double double_tmp_result_k3Lzf6g = ((dpz * dqt) - (dqz * dpt));
if( (max5 < lower_bound_1) )
else
eps = (6.88858782307641768480e-15 * (max5 * (CGAL::max)( max3,
(max1 * max1) )));
if( (double_tmp_result_k3Lzf6g > eps) )
int_tmp_result_3SPBwDj = 1;
else
if( (double_tmp_result_k3Lzf6g < -eps) )
int_tmp_result_3SPBwDj = -1;
else
return static_cast<result_type>(cmp * int_tmp_result_3SPBwDj);
else
} } }//namespace CGAL::internal::Static_filters_predicates
#endif //CGAL_INTERNAL_STATIC_FILTERS_POWER_TEST_3_H
