cgal-discuss - Re: [cgal-discuss] endless loop in create_new_outer_cycle (in Minkowski_sum_3)
  • To:
  • Subject: Re: [cgal-discuss] endless loop in create_new_outer_cycle (in Minkowski_sum_3)
  • Date: Mon, 26 Dec 2011 15:31:23 +0100
It would be easier to precisely answer if you could provide a minimal
example showing the problem.
In any case, in this section:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Minkowski_sum_3/Chapter_main.html#sectionMinkowskiSum_3Restrictions
you can read about the limitation of the current implementation.
Sebastien.
johnzjq wrote:
Hi,
when I tried to extent some models using Minkowski_sum_3 with the kernel of
Simple_cartesian<CGAL::Gmpq>, the program seems to be trapped in the
function of create_new_outer_cycle in the file "Single_wall_creator.h".
I would like to know what might be the causes? Most of my models can be
processed successfully and all of them are closed 2-manifold.
Thanks for your hints!
John
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/endless-loop-in-create-new-outer-cycle-in-Minkowski-sum-3-tp4234786p4234786.html
