- To:
- Subject: Re: [cgal-discuss] How to change Kd-Tree Point extra info
- Date: Thu, 05 Jan 2012 08:04:40 +0100
After fixing compiling errors in your code it was working fine on my
machine with CGAL 3.9 (see the attached code).
Did you have a look at this section where you can attach info to points stored in the tree by using property maps?
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_60.3.6
Sebastien.
wrote:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_3 Point3;
struct Point:public Point3
Point(double dx,double dy,double dz):Point_3(dx,dy,dz)
bUsed = false;
AcDbObjectId id;
bool bUsed;
struct Construct_coord_iterator
// Get an iterator for the approximate coordinates. const Point::Cartesian_const_iterator operator() (const Point&
nnp) const
return (nnp.cartesian_begin());
//Get a past-the-end iterator for the approximate coordinates. const Point::Cartesian_const_iterator operator() (const Point&
nnp, int) const
return (nnp.cartesian_end());
typedef CGAL::Search_traits<K::FT, Point, const
double*,Construct_coord_iterator> Traits;
typedef CGAL::Orthogonal_incremental_neighbor_search<Traits>
NN_incremental_search;
typedef NN_incremental_search::iterator NN_iterator;
typedef NN_incremental_search::Tree Tree;
struct point_not_used{
bool operator()(const NN_iterator& it)
{ return (((*it).first).bUsed);
//return true;
// An iterator that only enumerates dD points with positive
x-coordinate
typedef CGAL::Filter_iterator<NN_iterator,point_not_used>
NN_positive_x_iterator;
.... //init a Tree ojbect and do the below seach.
NN_incremental_search NN(tree,query);
it(NN.end(),point_not_used(),NN.begin()),end(NN.end(),point_not_used());
for (int j=0;(j<nK)&&(it!=end);++j,++it)
const Point& p = (*it).first;
Point& pp = const_cast<Point&>(p);
pp.bUsed = true;// why can this line not change the
tree's point extra info "bUsed".
idArr_Res.append(p.id);
acutPrintf(_T("\nsquard
distance=%g"),CGAL::to_double((*it).second));
the code above can be compiled well, but "pp.bUsed = true" did nothing, why
can't change the tree's point extral info.
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Orthogonal_incremental_neighbor_search.h> #include <CGAL/Search_traits.h> typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef K::Point_3 Point3; struct Point:public Point3 { Point(){} Point(double dx,double dy,double dz):Point3(dx,dy,dz) { bUsed = false; } bool bUsed; }; struct Construct_coord_iterator { typedef Point::Cartesian_const_iterator result_type; // Get an iterator for the approximate coordinates. Point::Cartesian_const_iterator operator() (const Point& nnp) const { return (nnp.cartesian_begin()); } //Get a past-the-end iterator for the approximate coordinates. Point::Cartesian_const_iterator operator() (const Point& nnp, int) const { return (nnp.cartesian_end()); } }; typedef CGAL::Search_traits<K::FT, Point, const double*,Construct_coord_iterator> Traits; typedef CGAL::Orthogonal_incremental_neighbor_search<Traits> NN_incremental_search; typedef NN_incremental_search::iterator NN_iterator; typedef NN_incremental_search::Tree Tree; struct point_not_used{ bool operator()(const NN_iterator& it) { return (((*it).first).bUsed); //return true; } }; // An iterator that only enumerates dD points with positive x-coordinate typedef CGAL::Filter_iterator<NN_iterator,point_not_used> NN_positive_x_iterator; int main(){ Tree tree; std::list<Point> lst; lst.push_back(Point(0,0,0)); lst.back().bUsed=true; lst.push_back(Point(0,0,1)); lst.back().bUsed=true; lst.push_back(Point(0,1,1)); lst.push_back(Point(1,1,1)); lst.push_back(Point(2,1,1)); lst.push_back(Point(2,2,3)); lst.push_back(Point(2,2,2)); tree.insert(lst.begin(),lst.end()); int nK=2; Point query(0,0,0.1); NN_incremental_search NN(tree,query); std::cout << NN.begin()->first.bUsed << std::endl; std::cout << (++NN.begin())->first.bUsed << std::endl; NN_positive_x_iterator it(NN.end(),point_not_used(),NN.begin()),end(NN.end(),point_not_used()); for (int j=0;(j<nK)&&(it!=end);++j,++it) { const Point& p = (*it).first; Point& pp = const_cast<Point&>(p); pp.bUsed = false;// why can this line not change the tree's point extra info "bUsed". } std::cout << NN.begin()->first.bUsed << std::endl; std::cout << (++NN.begin())->first.bUsed << std::endl; }
- [cgal-discuss] How to change Kd-Tree Point extra info, 421232206, 01/05/2012
- Re: [cgal-discuss] How to change Kd-Tree Point extra info, Sebastien Loriot (GeometryFactory), 01/05/2012
- [cgal-discuss] Re: How to change Kd-Tree Point extra info, cnng0315, 01/05/2012
- Re: [cgal-discuss] Re: How to change Kd-Tree Point extra info, Sebastien Loriot (GeometryFactory), 01/05/2012
- [cgal-discuss] Re: How to change Kd-Tree Point extra info, cnng0315, 01/06/2012
