- To: "" <>
- Subject: Re: [cgal-discuss] How to use B-Rep
- Date: Fri, 6 Jan 2012 22:44:54 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=4AC7m8keidAQSHAPkHgHo1nZtLiY4YFUwfyxMQHUhv1+g7l1PMy+ae16SzZu3voGgIpLFcoEyYe8UC6t2diYWenTJeJ1up/WfV9kLTP/LaJ7uWUtMCsqkAv1OlgQgyzGAK44m4ze6BqeKfSrA9JwL2Yy4iFpu+Tk7psLKDgIK9Q=;
Thank you Sebastien.
I am studying the following links.
My goal is that I have .txt file storing building footprints,
Firstly, I have to read this file and store the points in such a way that it should be Topologically Consistent.
Then I have to use that Topologically consistent dataset to extrude Buildings which should be topologically as well geometrically consistent.
Please I'm looking forward for your
help.
Thank you!
To:
Sent: Wednesday, 4 January 2012, 15:42
What is the goal and the desired output?
I mean, it looks like there is no difficulty if your footprints
do not intersect.
If this is just a matter of storing data, you can use the Polyhedron_3
class:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html
with the incremental builder:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_incremental_builder_3.html
Sebastien.
sahermurad wrote:
> Hi,
> I am new to CGAl and i want to use B-Rep to extrude building blocks from
> building footprints.
> I have a .txt file that stores the footprints as follow:
> Start
> 5,10
> 15,10
> 15,20
> 5,20
> Height
> 12
> End
> Start
> 15,10
> 25,10
> 35,10
> 45,10
> 45,20
> 15,20
> Height
> 15
> End
> Please let me know how i can use B-Rep??
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/How-to-use-B-Rep-tp4260757p4260757.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] How to use B-Rep, sahermurad, 01/04/2012
- Re: [cgal-discuss] How to use B-Rep, Sebastien Loriot (GeometryFactory), 01/04/2012
- Re: [cgal-discuss] How to use B-Rep, saher murad, 01/07/2012
