- To:
- Subject: Re: [cgal-discuss] Using Qt with CGAL
- Date: Mon, 9 Jan 2012 16:24:33 +0530
My Linux distribution is Ubuntu 11.04.
Where can I find these variables?
Apurv Verma
B. Tech.(CSE)
IIT- Ropar
thanks and regards,
Apurv Verma
B. Tech.(CSE)
IIT- Ropar
On Mon, Jan 9, 2012 at 2:53 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le lundi 09 janvier 2012 05:14:25 Apurv Verma a écrit :
> Hello,> *-- NOTICE: This demo requires QGLViewer, Qt4, and will not be compiled.*
> I am working on building a "Robot Localization Visualizer" using CGAL and
> Qt. I already installed Qt using the Synaptic package manager.
> The examples given in the examples directory also work fine.
> But the one's given in the demo/ folder don't work. The following is the
> message which I get when I qmake.
> apurv@deepu:~/ProgramFiles/CGAL-3.8/demo/AABB_tree$ cmake .
> -- Build type: Release
> -- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
> -- USING EXEFLAGS = ' '
> -- Targetting Unix Makefiles
> -- Using /usr/bin/c++ compiler.
> -- Configuring doneHave a look at the CMake variables
> -- Generating done
> -- Build files have been written to:
> /home/apurv/ProgramFiles/CGAL-3.8/demo/AABB_tree
> It appears CGAL can't these libraries though I have already installed both
> What settings do I need to do?
- QMAKE_EXECUTABLE (use to find Qt4 files),
- QGLVIEWER_INCLUDE_DIR (path to the header files)
- QGLVIEWER_LIBRARY_RELEASE (full path of the libQGLViewer.so file)
By the way, what is your Linux distribution? Debian? Ubuntu?
Laurent Rineau, PhD
- [cgal-discuss] Using Qt with CGAL, Apurv Verma, 01/09/2012
- Re: [cgal-discuss] Using Qt with CGAL, Laurent Rineau (GeometryFactory), 01/09/2012
- Re: [cgal-discuss] Using Qt with CGAL, Apurv Verma, 01/09/2012
- Re: [cgal-discuss] Using Qt with CGAL, Winnie Hellmann, 01/12/2012
