- To:
- Subject: Re: [cgal-discuss] Re: Error in VisualStudio 2008
- Date: Tue, 17 Jan 2012 12:45:03 +0100
Le mardi 17 janvier 2012 03:31:35 mysmax a écrit :
> sir File: examples/Triangulation_2/voronoi.cpp, I runned successfully the
> program I got this result as below
> The Voronoi diagram has 0 finite edges and 0 rays
> is this a correct answer to the program? also which other file I can make
> use as input?
Make sure you run the example from the source directory itself, and not from
a
sub-directory named Release or Debug.
Laurent Rineau, PhD
- [cgal-discuss] Error in VisualStudio 2008, mysmax, 01/17/2012
- Re: [cgal-discuss] Error in VisualStudio 2008, Laurent Rineau (GeometryFactory), 01/17/2012
- [cgal-discuss] Re: Error in VisualStudio 2008, mysmax, 01/17/2012
- Re: [cgal-discuss] Re: Error in VisualStudio 2008, Laurent Rineau (GeometryFactory), 01/17/2012
