- To:
- Subject: [cgal-discuss] Converting pair<Point,Vector> to Point_with_normal
- Date: Tue, 17 Jan 2012 16:04:50 +0100
Hi there,
Recently discovered CGAL : amazing library !
I'm currently trying to reconstruct some meshes based on a xyz point set without normals.
Managed to do it with normal_estimation and poisson_reconstruction examples, but I'd like to merge them in a single binary for a starter.
I'm a newbie to CGAL so the answer might seem obvious... It seems that normal_estimation outputs a vector <Point, Vector> whereas poisson_reconstruction requires a deque of Point_with_normal. How can I convert the these lists ? Is there a simpler way to do that ?
Thanks !
KHAO Jonathan, Ph.D.
Aix-Marseille Université
Assemblage et dynamique des protéines membranaires
Laboratoire d'Ingenierie des Systèmes Macromoléculaires
UPR9027 CNRS
- [cgal-discuss] Converting pair<Point,Vector> to Point_with_normal, jonathan KHAO, 01/17/2012
- Re: [cgal-discuss] Converting pair<Point,Vector> to Point_with_normal, Sebastien Loriot (GeometryFactory), 01/18/2012
- Re: [cgal-discuss] Converting pair<Point,Vector> to Point_with_normal, jonathan KHAO, 01/18/2012
