- To:
- Subject: Re: [cgal-discuss] How to implement topological model in CGAL
- Date: Wed, 18 Jan 2012 09:53:30 +0100
Several way to proceed:
*the lazy one:
put each building blocks in an independent Nef polyhedron and make the
union (join) of all of then. Then you can extract a Polyhedron from it.
see: http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3.html#Function_void_convert_to_polyhedron6Polyhedron__P9_const;
*by hand:
if your blocks shares full edges--if two edges overlap they have the same end points--use Halfedge_DS and Arrangement otherwise to extract
edges common to two blocks. Then using Polyhedron_3 with the incremental
builder, it's simply combinatoric to build the topological consistent buildings.
see:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_incremental_builder_3.html
Sebastien.
sahermurad wrote:
Hi, I am new to CGAl and i want to use B-Rep to extrude building blocks from
building footprints.
I have a .txt file that stores the footprints as follow:
Start
5,10
15,10
15,20
5,20
Height
12
End
Start
15,10
25,10
35,10
45,10
45,20
15,20
Height
15
End
Start
45,20
55,20
55,30
45,30
Height
12
End
My goal is that I have to read the above text file storing building
footprints,
and then store the points in such a way that it should be Topologically
Consistent.
Then I have to use that Topologically consistent dataset to extrude
Buildings which should be topologically as well geometrically consistent.
Thank you!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-implement-topological-model-in-CGAL-tp4298982p4298982.html
- [cgal-discuss] How to implement topological model in CGAL, sahermurad, 01/16/2012
- Re: [cgal-discuss] How to implement topological model in CGAL, Sebastien Loriot (GeometryFactory), 01/18/2012
