cgal-discuss - Re: [cgal-discuss] configuration cgal
  • To:
  • Subject: Re: [cgal-discuss] configuration cgal
  • Date: Wed, 18 Jan 2012 16:36:38 +0100
Zeineb Abderrahim
writes:
> Good evening,
> I failed to configuration CGAL in Visual C + + please help me because
> I want to use it in my thesis. for exemple, I not understand this
> instruction :
> ( You must pass as argument the root directory of Cgal. For example:
> cd CGAL-3.9
> cmake-gui . # Notice the dot to indicate the current directory. )
It means that you either have to replace the 'dot' with the directory
that contains CGAL or the current directory of your shell (cmd.exe or
Command Prompt) has to be the CGAL directory.
> Thanks
Philipp Moeller, GeometryFactory
