cgal-discuss - Re: [cgal-discuss] external tetrahedrons
  • To:
  • Subject: Re: [cgal-discuss] external tetrahedrons
  • Date: Tue, 24 Jan 2012 08:52:40 +0100
On this page:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
you have the documentation of the function incident_cells
that you can use like this:
typedef CGAL::Delaunay_triangulation_3 DT;
DT dt;
std::list<DT::Cell_handle> infinite_cells;
dt.incident_cells(dt.infinite_vertex(),std::back_inserter(infinite_cells));
Then for each Cell_handle c in infinite_cells,
c.neighbor(c.index(dt.infinite_vertex())) is one of the tetrahedra
you are looking for.
Sebastien.
On 01/23/2012 08:59 PM, Adam Hopkins wrote:
Hi There:
Could anyone give me suggestions or an example code to solve my problem
which is described below?
Thanks and waiting for help
A.
On Mon, Jan 23, 2012 at 4:48 PM, Adam Hopkins
<mailto:>>
wrote:
Hi Andreas:
Thank you for your answer and your solutions seem perfect. But,
could you send me a short code to see the best way to do this?
because there are different iterators (all_cells_iterator,
finite_cells_iterator, etc) and I do not know how I can implement
your solution (what are the involved methods and what kind of
elements do I need to iterate?). While, on the other hand I also
need to know which are the vertexs of the external faces. Will be
perfect if you can send me an example for solve these problems.
thanks a lot
A.
On Mon, Jan 23, 2012 at 4:03 PM, Andreas Fabri
<mailto:>>
wrote:
On 23/01/2012 15:39, Adam Hopkins wrote:
Hi All:
I have a set of points in the three dimentional space, where a
triangulation using CGAL library was computed. How Can I
know which are
the most external tetrahedrons? is to say, the tetrahedrons
which have
at least one external face. Are there functions or any form
to know
that? Is possible to iterate only these kind of elements?
thanks
A.
Hi Adam,
For all cells incident to the infinite vertex,
take the cell opposite to the infinite vertex.
andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 <tel:%2B33.492.954.912> skype:
andreas.fabri
https://lists-sop.inria.fr/__wws/info/cgal-discuss
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
