cgal-discuss - Re: [cgal-discuss] cygCGAL-8.dll error on Cygwin
  • To:
  • Subject: Re: [cgal-discuss] cygCGAL-8.dll error on Cygwin
  • Date: Wed, 25 Jan 2012 16:11:45 +0100
Le mercredi 25 janvier 2012 06:58:24 slaughter a écrit :
> I am trying to run the examples in the examples/Mesh_2 directory using a
> build of the CGAL libraries on cygwin. I was able build the libraries and
> compile the examples in this directory. But, when I try to execute the *.exe
> files I recieve the following error.
> $ ./conforming.exe
> /packages/CGAL-3.9/examples/Mesh_2/conforming.exe: error while loading
> shared libraries: cygCGAL-8.dll: cannot open shared object file: No such
> file or directory
> The file, cygCGAL-8.dll, exists in the /usr/local/lib directory in my Cygwin
> root directory.
> What is causing this error?
/usr/local/lib must in the PATH environment variable.
Use:
PATH=$PATH:/usr/local/lib
export PATH
It is the first I see somebody using Cygwin and its compiler to build CGAL
shared libraries. In my opinion there is a bug in the CGAL installation
process: the .dll files should have been installed into /usr/local/bin, and
not in /usr/local/lib/.
Laurent Rineau, PhD
