- To:
- Subject: Re: [cgal-discuss] sweep line
- Date: Tue, 31 Jan 2012 18:12:23 +0100
On 01/31/2012 05:43 PM, Winnie Hellmann wrote:
Unfortunately this is not that simple because if you change the sweepThe lazy solution is to have a preprocessing stepOk, thank you! I think I'll be even lazier for now and use std::sort().
Maybe I'll try to come up with a new ArrangementTraits_2 model some time
(even though I'm not totally clear about how that should look like). In
general, I'd prefer if the sweep direction would not depend on the
Traits that are used but on a second template parameter - something like
My_sweep_line<Traits, X_direction>.
direction required functors are no longer the same.
For example if you sweep along the x-direction, you then need to be able
to split input curve into x-monotone curves but you don't need to have a
functor to split the curves into y-monotone curves. So in any case,
two concepts would be needed.
Sebastien.
- [cgal-discuss] sweep line, Winnie Hellmann, 01/30/2012
- Re: [cgal-discuss] sweep line, Sebastien Loriot (GeometryFactory), 01/31/2012
- Re: [cgal-discuss] sweep line, Winnie Hellmann, 01/31/2012
