- To:
- Subject: Re: [cgal-discuss] Calculating position of point in space ?
- Date: Fri, 03 Feb 2012 11:40:51 +0100
You can compute the intersection of 4 spheres centered at your 4 points with radius being the distance to the points you are looking for.
Note that in general you have two such points (in degenerate cases you
can have a sphere, a circle or a single point).
You'll need to use the Spherical_kernel_3.
Have a look at:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Circular_kernel_3_ref/FunctionObjectConcept_SphericalKernel--Intersect_3.html#Cross_link_anchor_902
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Circular_kernel_3_ref/Class_Exact_spherical_kernel_3.html#Cross_link_anchor_863
Sebastien.
On 02/03/2012 08:54 AM, Adam wrote:
Hello All !!!
I’m new here and I lack knowledge so please bear with me.
I have a problem. I have to calculate position of point in space having
distance from 4 known points.
Is it possible to calculate this position in use of CGAL library?
If not, may be some knowledgeable users can point me in the right direction.
Regards,
Adam
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Calculating-position-of-point-in-space-tp4353924p4353924.html
- [cgal-discuss] Calculating position of point in space ?, Adam, 02/03/2012
- Re: [cgal-discuss] Calculating position of point in space ?, Sebastien Loriot (GeometryFactory), 02/03/2012
- [cgal-discuss] Re: Calculating position of point in space ?, Adam, 02/03/2012
- Re: [cgal-discuss] Re: Calculating position of point in space ?, Sebastien Loriot (GeometryFactory), 02/03/2012
