cgal-discuss - Re: [cgal-discuss] Data structure for representing orientable 2-manifolds triangle mesh?
  • To:
  • Subject: Re: [cgal-discuss] Data structure for representing orientable 2-manifolds triangle mesh?
  • Date: Wed, 08 Feb 2012 08:25:43 +0100
You can use the combinatorial layer below every 2D-triangulation:
the Triangulation_data_structure_2:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TDS_2/Chapter_main.html
But usually, it is simpler to use Polyhedron as it comes with
high level functionalities.
Sebastien.
On 02/08/2012 03:40 AM, Chris wrote:
I want to find a data structure in CGAL that can represent orientable
2-manifolds triangle mesh.
I mean i can conveniently construct a triangle mesh through inserting
vertices , and the data structure
can maintain the validity of the mesh. I have already known that Polyhedral
2-manifolds surface well , but I prefer to find a data structure like 3D
Triangulations , I find the definition
of SurfaceMeshComplex_2InTriangulation_3 in cgal manual "The concept
SurfaceMeshComplex_2InTriangulation_3 is
particularly suited to handle surface meshes obtained as the restriction to
a surface of a three dimensional
Delaunay triangulation" , so I can't use it directly
Does anyone know or meet this problem before?
Thanks and best regards!
Chris
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Data-structure-for-representing-orientable-2-manifolds-triangle-mesh-tp4367622p4367622.html
