- To:
- Subject: Re: [cgal-discuss] Re: Triangulaing a polyhedron
- Date: Thu, 16 Feb 2012 07:57:55 +0100
On 02/15/2012 07:13 PM, Zohar wrote:
Remeshing does not necessarily mean adding vertices.
What do you mean by remesh? The original mesh has M>>N vertices.
You can directly remeshing it using Surface_mesher package
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesher/Chapter_main.html (take a look at 47.6)
or you can simplify your mesh:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesh_simplification/Chapter_main.html
Sebastien
Thanks for the AABB tree.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulaing-a-polyhedron-tp4390780p4391429.html
- [cgal-discuss] Triangulaing a polyhedron, Zohar, 02/15/2012
- Re: [cgal-discuss] Triangulaing a polyhedron, Andreas Fabri, 02/15/2012
- [cgal-discuss] Re: Triangulaing a polyhedron, Zohar, 02/15/2012
- Re: [cgal-discuss] Re: Triangulaing a polyhedron, Sebastien Loriot (GeometryFactory), 02/16/2012
- [cgal-discuss] Re: Triangulaing a polyhedron, Zohar, 02/16/2012
- Re: [cgal-discuss] Re: Triangulaing a polyhedron, Sebastien Loriot (GeometryFactory), 02/17/2012
- [cgal-discuss] Re: Triangulaing a polyhedron, Zohar, 02/17/2012
- Re: [cgal-discuss] Re: Triangulaing a polyhedron, Mariette Yvinec, 02/17/2012
- [cgal-discuss] Re: Triangulaing a polyhedron, Zohar, 02/23/2012
- Re: [cgal-discuss] Re: Triangulaing a polyhedron, Sebastien Loriot (GeometryFactory), 02/23/2012
- [cgal-discuss] Re: Triangulaing a polyhedron, Zohar, 02/24/2012
- Re: [cgal-discuss] Re: Triangulaing a polyhedron, Sebastien Loriot (GeometryFactory), 02/24/2012
- [cgal-discuss] Re: Triangulaing a polyhedron, Zohar, 02/26/2012
