- To:
- Subject: Re: [cgal-discuss] Triangulation of a sphere?
- Date: Mon, 20 Feb 2012 18:00:06 +0100
On 02/20/2012 05:41 PM, Dragan Vidovic wrote:
Hi allA quick way to do it is to take the convex hull of your input points.
Is it possible to construct a triangulation of a spherical surface (or a
topologically equivalent object) using only points that I provide?
If some of your input points does not appear on the convex hull (because
of the rounding of your input points) then you can use a regular
triangulation using as weights for each point p, d(o,p)^2-r^2 where o
is the center of the sphere and r its radius.
More details are provided in this publication:
http://hal.inria.fr/docs/00/40/77/32/PDF/RR-7004.pdf
See this example:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Convex_hull_3/Chapter_main.html#Subsection_16.4.1
Sebastien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulation-of-a-sphere-tp4404518p4404518.html
- [cgal-discuss] Triangulation of a sphere?, Dragan Vidovic, 02/20/2012
- Re: [cgal-discuss] Triangulation of a sphere?, Sebastien Loriot (GeometryFactory), 02/20/2012
- [cgal-discuss] Re: Triangulation of a sphere?, Dragan Vidovic, 02/20/2012
- Re: [cgal-discuss] Re: Triangulation of a sphere?, Sebastien Loriot (GeometryFactory), 02/20/2012
