cgal-discuss - [cgal-discuss] Re: visual studio 2010: void __cdecl CGAL::assertion_fail(char const *,char const *,int,char const *)
  • To:
  • Subject: [cgal-discuss] Re: visual studio 2010: void __cdecl CGAL::assertion_fail(char const *,char const *,int,char const *)
  • Date: Tue, 21 Feb 2012 01:39:14 -0800 (PST)
The CMakeCache.txt that was generated during the configuration of the CGAL
libraries was the following:
# This is the CMakeCache file.
# For build in directory: c:/Project_2
# It was generated by CMake: C:/Program Files (x86)/CMake 2.8/bin/cmake.exe
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Value Computed by CMake
AABB_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/AABB_tree
AABB_demo_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo/AABB_tree
AABB_examples_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/AABB_tree
AABB_examples_SOURCE_DIR:STATIC=C:/Program Files
Algebraic_foundations_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Algebraic_foundations
Algebraic_foundations_example_SOURCE_DIR:STATIC=C:/Program Files
Algebraic_kernel_d_test_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Algebraic_kernel_d
Algebraic_kernel_d_test_SOURCE_DIR:STATIC=C:/Program Files
Alpha_shape_3_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Alpha_shapes_3
Alpha_shape_3_SOURCE_DIR:STATIC=C:/Program Files
Alpha_shapes_2_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Alpha_shapes_2
Alpha_shapes_2_demo_SOURCE_DIR:STATIC=C:/Program Files
Alpha_shapes_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Alpha_shapes_2
Alpha_shapes_2_example_SOURCE_DIR:STATIC=C:/Program Files
Alpha_shapes_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Alpha_shapes_3
Alpha_shapes_3_example_SOURCE_DIR:STATIC=C:/Program Files
Apollonius_graph_2_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Apollonius_graph_2
Apollonius_graph_2_demo_SOURCE_DIR:STATIC=C:/Program Files
Apollonius_graph_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Apollonius_graph_2
Apollonius_graph_2_example_SOURCE_DIR:STATIC=C:/Program Files
Approximate_min_ellipsoid_d_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Approximate_min_ellipsoid_d
Approximate_min_ellipsoid_d_example_SOURCE_DIR:STATIC=C:/Program Files
Arrangement_2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Arrangement_on_surface_2
Arrangement_2_SOURCE_DIR:STATIC=C:/Program Files
Arrangement_on_surface_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Arrangement_on_surface_2
Arrangement_on_surface_2_example_SOURCE_DIR:STATIC=C:/Program Files
BGL_arrangement_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/BGL_arrangement_2
BGL_arrangement_2_example_SOURCE_DIR:STATIC=C:/Program Files
BGL_polyhedron_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/BGL_polyhedron_3
BGL_polyhedron_3_example_SOURCE_DIR:STATIC=C:/Program Files
BGL_triangulation_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/BGL_triangulation_2
BGL_triangulation_2_example_SOURCE_DIR:STATIC=C:/Program Files
//Compilation options to use BLAS
BLAS_DEFINITIONS:STRING=
//Directories containing the BLAS header files
BLAS_INCLUDE_DIR:PATH=C:/Program Files
(x86)/CGAL-3.9/auxiliary/taucs/include
//BLAS libraries name
BLAS_LIBRARIES:FILEPATH=
//Directories containing the BLAS libraries
BLAS_LIBRARIES_DIR:PATH=C:/Program Files (x86)/CGAL-3.9/auxiliary/taucs/lib
//Linker flags to use BLAS
BLAS_LINKER_FLAGS:STRING=
Boolean_operations_2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Boolean_set_operations_2
Boolean_operations_2_SOURCE_DIR:STATIC=C:/Program Files
Boolean_set_operations_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Boolean_set_operations_2
Boolean_set_operations_2_example_SOURCE_DIR:STATIC=C:/Program Files
//Path to a file.
Boost_INCLUDE_DIR:PATH=C:/boost_1_48_0
//Boost library directory
Boost_LIBRARY_DIRS:FILEPATH=C:/boost_1_48_0/stage/lib;C:/boost_1_48_0/stage/lib
//Boost diagnostic define
Boost_LIB_DIAGNOSTIC_DEFINITIONS:STRING=-DBOOST_LIB_DIAGNOSTIC
//The Boost PROGRAM_OPTIONS library
Boost_PROGRAM_OPTIONS_LIBRARY:FILEPATH=optimized;C:/boost_1_48_0/stage/lib/libboost_program_options-vc100-mt-1_48.lib;debug;C:/boost_1_48_0/stage/lib/libboost_program_options-vc100-mt-gd-1_48.lib
//Path to a library.
Boost_PROGRAM_OPTIONS_LIBRARY_DEBUG:FILEPATH=C:/boost_1_48_0/stage/lib/libboost_program_options-vc100-mt-gd-1_48.lib
Boost_PROGRAM_OPTIONS_LIBRARY_RELEASE:FILEPATH=C:/boost_1_48_0/stage/lib/libboost_program_options-vc100-mt-1_48.lib
//The Boost THREAD library
Boost_THREAD_LIBRARY:FILEPATH=optimized;C:/boost_1_48_0/stage/lib/libboost_thread-vc100-mt-1_48.lib;debug;C:/boost_1_48_0/stage/lib/libboost_thread-vc100-mt-gd-1_48.lib
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=C:/boost_1_48_0/stage/lib/libboost_thread-vc100-mt-gd-1_48.lib
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=C:/boost_1_48_0/stage/lib/libboost_thread-vc100-mt-1_48.lib
Bounding_volumes_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Bounding_volumes
Bounding_volumes_SOURCE_DIR:STATIC=C:/Program Files
Box_intersection_d_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Box_intersection_d
Box_intersection_d_example_SOURCE_DIR:STATIC=C:/Program Files
CGALImageIO_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/CGALimageIO
CGALImageIO_example_SOURCE_DIR:STATIC=C:/Program Files
//Enable/Disable auto-linking for the external library GMP
CGAL_AUTO_LINK_GMP:BOOL=ON
//Enable/Disable auto-linking for the external library MPFR
CGAL_AUTO_LINK_MPFR:BOOL=ON
CGAL_BINARY_DIR:STATIC=C:/Project_2
//Directory containing the Core package
CGAL_CORE_PACKAGE_DIR:PATH=C:/Program Files (x86)/CGAL-3.9
//User-defined flags
CGAL_CXX_FLAGS:STRING= -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except-
CGAL_Core_BINARY_DIR:STATIC=C:/Project_2/src/Core
//Dependencies for target
CGAL_Core_LIB_DEPENDS:STATIC=
CGAL_Core_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/src/CGALCore
CGAL_DEMOS_BINARY_DIR:STATIC=C:/Project_2/demo
CGAL_DEMOS_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo
//Set this to TRUE if you want to define or modify any of CMAKE_*_FLAGS.
// When this is FALSE, all the CMAKE_*_FLAGS flags are overriden
// with the values used when building the CGAL libs. For CGAL_*_flags
// (used for ADDITIONAL flags) , there is no need to set this to
// TRUE.
CGAL_DONT_OVERRIDE_CMAKE_FLAGS:BOOL=TRUE
CGAL_EXAMPLES_BINARY_DIR:STATIC=C:/Project_2/examples
CGAL_EXAMPLES_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/examples
//Directory containing the Installation package
CGAL_INSTALLATION_PACKAGE_DIR:PATH=C:/Program Files (x86)/CGAL-3.9
//The folder where CGAL user-side scripts will be installed, relative
// to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_BIN_DIR:STRING=bin
//The folder where CGAL CMake modules will be installed, relative
CGAL_INSTALL_CMAKE_DIR:STRING=lib/CGAL
//The folder where CGAL documentation and license files will be
// installed, relative to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_DOC_DIR:STRING=share/doc/CGAL-3.9
//The folder where CGAL header files will be installed, relative
CGAL_INSTALL_INC_DIR:STRING=include
//The folder where CGAL libraries will be installed, relative to
// CMAKE_INSTALL_PREFIX
CGAL_INSTALL_LIB_DIR:STRING=lib
//The folder where manual pages for CGAL scripts will be installed,
// relative to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_MAN_DIR:STRING=share/man/man1
CGAL_ImageIO_BINARY_DIR:STATIC=C:/Project_2/src/ImageIO
//Dependencies for the target
CGAL_ImageIO_LIB_DEPENDS:STATIC=general;glu32;general;opengl32;
CGAL_ImageIO_SOURCE_DIR:STATIC=C:/Program Files
(x86)/CGAL-3.9/src/CGALImageIO
//The CGAL library
CGAL_LIBRARY:STRING=
CGAL_LIB_DEPENDS:STATIC=
//Directory containing the Maintenance package
CGAL_MAINTENANCE_PACKAGE_DIR:PATH=C:/Program Files (x86)/CGAL-3.9
CGAL_Qt3_BINARY_DIR:STATIC=C:/Project_2/src/Qt3
CGAL_Qt3_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/src/CGALQt3
CGAL_Qt4_BINARY_DIR:STATIC=C:/Project_2/src/Qt4
CGAL_Qt4_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/src/CGALQt4
CGAL_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9
//Directory containing BLAS, LAPACK and TAUCS
CGAL_TAUCS_DIR:PATH=
CGAL_ipelets_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/CGAL_ipelets
CGAL_ipelets_example_SOURCE_DIR:STATIC=C:/Program Files
//Build type: Release or Debug
CMAKE_BUILD_TYPE:STRING=Debug
//Semicolon separated list of supported configuration types, only
// supports Debug, Release, MinSizeRel, and RelWithDebInfo, anything
// else will be ignored.
CMAKE_CONFIGURATION_TYPES:STRING=Debug;Release;MinSizeRel;RelWithDebInfo
//C++ compiler
CMAKE_CXX_COMPILER:FILEPATH=cl
//Path to a program.
CMAKE_CXX_COMPILER_WITH_PATH:FILEPATH=CMAKE_CXX_COMPILER_WITH_PATH-NOTFOUND
CMAKE_CXX_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
//Flags used by the compiler during release minsize builds.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
//Flags used by the compiler during release builds (/MD /Ob1 /Oi
// /Ot /Oy /Gs will produce slightly less optimized but smaller
// files).
CMAKE_CXX_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
//Flags used by the compiler during Release with Debug Info builds.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by defalut with all C++ applications.
CMAKE_CXX_STANDARD_LIBRARIES:STRING='kernel32.lib user32.lib gdi32.lib
winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib
advapi32.lib '
//C compiler
CMAKE_C_COMPILER:FILEPATH=cl
CMAKE_C_COMPILER_WITH_PATH:FILEPATH=CMAKE_C_COMPILER_WITH_PATH-NOTFOUND
//Flags used by the compiler during all build types.
CMAKE_C_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /Zm1000
CMAKE_C_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
CMAKE_C_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
// files).
CMAKE_C_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by defalut with all C applications.
CMAKE_C_STANDARD_LIBRARIES:STRING='kernel32.lib user32.lib gdi32.lib
advapi32.lib '
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING=' /STACK:10000000 /machine:x64 '
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=C:/Program Files/CGAL
CMAKE_LINKER:FILEPATH=CMAKE_LINKER-NOTFOUND
//make program
CMAKE_MAKE_PROGRAM:FILEPATH=C:/PROGRA~2/MICROS~2.0/Common7/IDE/devenv.com
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING=' /STACK:10000000 /machine:x64 '
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
CMAKE_PROJECT_NAME:STATIC=CGAL
//RC compiler
CMAKE_RC_COMPILER:FILEPATH=rc
//Flags for Fortran compiler.
CMAKE_RC_FLAGS:STRING=' '
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING=' /STACK:10000000 /machine:x64 '
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=OFF
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make. This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=OFF
Circular_kernel_2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Circular_kernel_2
Circular_kernel_2_SOURCE_DIR:STATIC=C:/Program Files
Circular_kernel_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Circular_kernel_2
Circular_kernel_2_example_SOURCE_DIR:STATIC=C:/Program Files
Circular_kernel_3_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Circular_kernel_3
Circular_kernel_3_SOURCE_DIR:STATIC=C:/Program Files
Circular_kernel_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Circular_kernel_3
Circular_kernel_3_example_SOURCE_DIR:STATIC=C:/Program Files
Circulator_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Circulator
Circulator_example_SOURCE_DIR:STATIC=C:/Program Files
Combinatorial_map_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Combinatorial_map
Combinatorial_map_example_SOURCE_DIR:STATIC=C:/Program Files
Convex_decomposition_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Convex_decomposition_3
Convex_decomposition_3_example_SOURCE_DIR:STATIC=C:/Program Files
Convex_hull_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Convex_hull_2
Convex_hull_2_example_SOURCE_DIR:STATIC=C:/Program Files
Convex_hull_3_Demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Convex_hull_3
Convex_hull_3_Demo_SOURCE_DIR:STATIC=C:/Program Files
Convex_hull_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Convex_hull_3
Convex_hull_3_example_SOURCE_DIR:STATIC=C:/Program Files
Convex_hull_d_example_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Convex_hull_d
Convex_hull_d_example_SOURCE_DIR:STATIC=C:/Program Files
Core_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Core
Core_example_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/examples/Core
Developers_manual_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Developers_manual
Developers_manual_example_SOURCE_DIR:STATIC=C:/Program Files
//The directory containing the ESBTL header files WITHOUT the ESBTL
// prefix
ESBTL_INCLUDE_DIR:PATH=ESBTL_INCLUDE_DIR-NOTFOUND
Envelope_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Envelope_2
Envelope_2_example_SOURCE_DIR:STATIC=C:/Program Files
Envelope_3_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Envelope_3
Envelope_3_demo_SOURCE_DIR:STATIC=C:/Program Files
Envelope_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Envelope_3
Envelope_3_example_SOURCE_DIR:STATIC=C:/Program Files
Filtered_kernel_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Filtered_kernel
Filtered_kernel_example_SOURCE_DIR:STATIC=C:/Program Files
GLEW_GLEW_LIBRARY:FILEPATH=GLEW_GLEW_LIBRARY-NOTFOUND
//Path to a file.
GLEW_INCLUDE_DIR:PATH=GLEW_INCLUDE_DIR-NOTFOUND
//The directory containing the GMP header files
GMP_INCLUDE_DIR:PATH=C:/Program Files (x86)/CGAL-3.9/auxiliary/gmp/include
//Path to the GMP library
GMP_LIBRARIES:FILEPATH=C:/Program Files
(x86)/CGAL-3.9/auxiliary/gmp/lib/libgmp-10.lib
GMP_LIBRARIES_DIR:FILEPATH=C:/Program Files (x86)/CGAL-3.9/auxiliary/gmp/lib
GeneratorDemo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Generator
GeneratorDemo_SOURCE_DIR:STATIC=C:/Program Files
Generator_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Generator
Generator_example_SOURCE_DIR:STATIC=C:/Program Files
Geomview_Demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Geomview
Geomview_Demo_SOURCE_DIR:STATIC=C:/Program Files
GraphicsView_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Polygon
GraphicsView_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo/Polygon
HalfedgeDS_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/HalfedgeDS
HalfedgeDS_example_SOURCE_DIR:STATIC=C:/Program Files
//Path to a file.
IPE_INCLUDE_DIR:PATH=IPE_INCLUDE_DIR-NOTFOUND
IPE_LIBRARY:FILEPATH=IPE_LIBRARY-NOTFOUND
//The version of Ipe. Only 6 and 7 are supported.
IPE_VERSION:STRING=AUTODETECT
Interpolation_Demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Interpolation
Interpolation_Demo_SOURCE_DIR:STATIC=C:/Program Files
Interpolation_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Interpolation
Interpolation_example_SOURCE_DIR:STATIC=C:/Program Files
Interval_skip_list_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Interval_skip_list
Interval_skip_list_example_SOURCE_DIR:STATIC=C:/Program Files
Jet_fitting_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Jet_fitting_3
Jet_fitting_3_example_SOURCE_DIR:STATIC=C:/Program Files
Kernel_23_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Kernel_23
Kernel_23_example_SOURCE_DIR:STATIC=C:/Program Files
Kinetic_data_structures_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program
Files (x86)/CGAL-3.9/demo/Kinetic_data_structures
Kinetic_data_structures_demo_SOURCE_DIR:STATIC=C:/Program Files
Kinetic_data_structures_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Kinetic_data_structures
Kinetic_data_structures_example_SOURCE_DIR:STATIC=C:/Program Files
Kinetic_framework_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Kinetic_framework
Kinetic_framework_example_SOURCE_DIR:STATIC=C:/Program Files
L1_voronoi_diagram_2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/L1_Voronoi_diagram_2
L1_voronoi_diagram_2_SOURCE_DIR:STATIC=C:/Program Files
//Compilation options to use LAPACK
LAPACK_DEFINITIONS:STRING=
//Directories containing the LAPACK header files
LAPACK_INCLUDE_DIR:PATH=C:/Program Files
//LAPACK libraries name
LAPACK_LIBRARIES:FILEPATH=
//Directories containing the LAPACK libraries
LAPACK_LIBRARIES_DIR:PATH=C:/Program Files
//Linker flags to use LAPACK
LAPACK_LINKER_FLAGS:STRING=
Largest_empty_rect_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Largest_empty_rect_2
Largest_empty_rect_2_example_SOURCE_DIR:STATIC=C:/Program Files
Largest_empty_rectangleDemo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program
Files (x86)/CGAL-3.9/demo/Largest_empty_rect_2
Largest_empty_rectangleDemo_SOURCE_DIR:STATIC=C:/Program Files
//Compilation options to use MKL
MKL_DEFINITIONS:STRING=
//Directories containing the MKL header files
MKL_INCLUDE_DIR:PATH=MKL_INCLUDE_DIR-NOTFOUND
//MKL libraries name
MKL_LIBRARIES:FILEPATH=FALSE
MKL_mkl_solver_LIBRARY:FILEPATH=MKL_mkl_solver_LIBRARY-NOTFOUND
MKL_mkl_solver_lp64_LIBRARY:FILEPATH=MKL_mkl_solver_lp64_LIBRARY-NOTFOUND
//The directory containing the MPFI header files
MPFI_INCLUDE_DIR:PATH=MPFI_INCLUDE_DIR-NOTFOUND
//Directory containing the MPFI library
MPFI_LIBRARIES:FILEPATH=MPFI_LIBRARIES-NOTFOUND
//The directory containing the MPFR header files
MPFR_INCLUDE_DIR:PATH=C:/Program Files (x86)/CGAL-3.9/auxiliary/gmp/include
//Path to the MPFR library
MPFR_LIBRARIES:FILEPATH=C:/Program Files
(x86)/CGAL-3.9/auxiliary/gmp/lib/libmpfr-4.lib
MPFR_LIBRARIES_DIR:FILEPATH=C:/Program Files
Matrix_search_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Matrix_search
Matrix_search_example_SOURCE_DIR:STATIC=C:/Program Files
Mesh_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Mesh_2
Mesh_2_example_SOURCE_DIR:STATIC=C:/Program Files
Mesh_3_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Mesh_3
Mesh_3_demo_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo/Mesh_3
Mesh_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Mesh_3
Mesh_3_example_SOURCE_DIR:STATIC=C:/Program Files
Min_annulus_d_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Min_annulus_d
Min_annulus_d_example_SOURCE_DIR:STATIC=C:/Program Files
Min_circle_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Min_circle_2
Min_circle_2_example_SOURCE_DIR:STATIC=C:/Program Files
Min_ellipse_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Min_ellipse_2
Min_ellipse_2_example_SOURCE_DIR:STATIC=C:/Program Files
Min_quadrilateral_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Min_quadrilateral_2
Min_quadrilateral_2_example_SOURCE_DIR:STATIC=C:/Program Files
Min_sphere_d_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Min_sphere_d
Min_sphere_d_example_SOURCE_DIR:STATIC=C:/Program Files
Min_sphere_of_spheres_d_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Min_sphere_of_spheres_d
Min_sphere_of_spheres_d_example_SOURCE_DIR:STATIC=C:/Program Files
Minkowski_sum_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Minkowski_sum_2
Minkowski_sum_2_example_SOURCE_DIR:STATIC=C:/Program Files
Minkowski_sum_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Minkowski_sum_3
Minkowski_sum_3_example_SOURCE_DIR:STATIC=C:/Program Files
Modular_arithmetic_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Modular_arithmetic
Modular_arithmetic_example_SOURCE_DIR:STATIC=C:/Program Files
Nef_2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Nef_2
Nef_2_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo/Nef_2
Nef_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Nef_2
Nef_2_example_SOURCE_DIR:STATIC=C:/Program Files
Nef_3_Demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Nef_3
Nef_3_Demo_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo/Nef_3
Nef_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Nef_3
Nef_3_example_SOURCE_DIR:STATIC=C:/Program Files
Nef_S2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Nef_S2
Nef_S2_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo/Nef_S2
Nef_S2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Nef_S2
Nef_S2_example_SOURCE_DIR:STATIC=C:/Program Files
//OpenGL library for win32
OPENGL_gl_LIBRARY:STRING=opengl32
//GLU library for win32
OPENGL_glu_LIBRARY:STRING=glu32
PCA_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Principal_component_analysis
PCA_demo_SOURCE_DIR:STATIC=C:/Program Files
//Activate the use of Qt Script Debugger in Polyhedron_3 demo
POLYHEDRON_QTSCRIPT_DEBUGGER:BOOL=OFF
Partition_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Partition_2
Partition_2_example_SOURCE_DIR:STATIC=C:/Program Files
Periodic_3_triangulation_3_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program
Files (x86)/CGAL-3.9/demo/Periodic_3_triangulation_3
Periodic_3_triangulation_3_demo_SOURCE_DIR:STATIC=C:/Program Files
Periodic_3_triangulation_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Periodic_3_triangulation_3
Periodic_3_triangulation_3_example_SOURCE_DIR:STATIC=C:/Program Files
Periodic_Lloyd_3_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Periodic_Lloyd_3
Periodic_Lloyd_3_SOURCE_DIR:STATIC=C:/Program Files
Point_set_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Point_set_2
Point_set_2_example_SOURCE_DIR:STATIC=C:/Program Files
Point_set_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Surface_reconstruction_points_3
Point_set_demo_SOURCE_DIR:STATIC=C:/Program Files
Point_set_processing_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Point_set_processing_3
Point_set_processing_3_example_SOURCE_DIR:STATIC=C:/Program Files
Polygon_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Polygon
Polygon_example_SOURCE_DIR:STATIC=C:/Program Files
Polyhedron_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Polyhedron
Polyhedron_IO_Demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Polyhedron_IO
Polyhedron_IO_Demo_SOURCE_DIR:STATIC=C:/Program Files
Polyhedron_IO_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Polyhedron_IO
Polyhedron_IO_example_SOURCE_DIR:STATIC=C:/Program Files
Polyhedron_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo/Polyhedron
Polyhedron_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
Polyhedron_example_SOURCE_DIR:STATIC=C:/Program Files
Polynomial_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Polynomial
Polynomial_example_SOURCE_DIR:STATIC=C:/Program Files
Polynomial_kernel_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Polynomial_kernel
Polynomial_kernel_example_SOURCE_DIR:STATIC=C:/Program Files
Polytope_distance_d_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Polytope_distance_d
Polytope_distance_d_example_SOURCE_DIR:STATIC=C:/Program Files
Principal_component_analysis_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Principal_component_analysis
Principal_component_analysis_example_SOURCE_DIR:STATIC=C:/Program Files
Profiling_tools_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Profiling_tools
Profiling_tools_example_SOURCE_DIR:STATIC=C:/Program Files
//Path to a file.
QGLVIEWER_INCLUDE_DIR:PATH=QGLVIEWER_INCLUDE_DIR-NOTFOUND
QGLVIEWER_LIBRARY_DEBUG:FILEPATH=QGLVIEWER_LIBRARY_DEBUG-NOTFOUND
QGLVIEWER_LIBRARY_RELEASE:FILEPATH=QGLVIEWER_LIBRARY_RELEASE-NOTFOUND
QP_solver_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/QP_solver
QP_solver_example_SOURCE_DIR:STATIC=C:/Program Files
//path to qt3 include directory
QT3_INCLUDE_DIR:PATH=QT3_INCLUDE_DIR-NOTFOUND
QT3_MOC_EXECUTABLE:FILEPATH=QT3_MOC_EXECUTABLE-NOTFOUND
QT3_QASSISTANTCLIENT_LIBRARY:FILEPATH=QT3_QASSISTANTCLIENT_LIBRARY-NOTFOUND
//This Library is only needed by and included with Qt3 on MSWindows.
// It should be NOTFOUND, undefined or IGNORE otherwise.
QT3_QTMAIN_LIBRARY:FILEPATH=QT3_QTMAIN_LIBRARY-NOTFOUND
QT3_QT_LIBRARY:FILEPATH=QT3_QT_LIBRARY-NOTFOUND
QT3_UIC_EXECUTABLE:FILEPATH=QT3_UIC_EXECUTABLE-NOTFOUND
//The qmake executable for the Qt installation to use
QT_QMAKE_EXECUTABLE:FILEPATH=QT_QMAKE_EXECUTABLE-NOTFOUND
RangeSegmentTrees_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/RangeSegmentTrees
RangeSegmentTrees_example_SOURCE_DIR:STATIC=C:/Program Files
Ridges_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Ridges_3
Ridges_3_example_SOURCE_DIR:STATIC=C:/Program Files
STL_Extension_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/STL_Extension
STL_Extension_example_SOURCE_DIR:STATIC=C:/Program Files
Segment_Delaunay_graph_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Segment_Delaunay_graph_2
Segment_Delaunay_graph_2_example_SOURCE_DIR:STATIC=C:/Program Files
Segment_voronoi_2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Segment_Delaunay_graph_2
Segment_voronoi_2_SOURCE_DIR:STATIC=C:/Program Files
Skin_surface_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Skin_surface_3
Skin_surface_3_example_SOURCE_DIR:STATIC=C:/Program Files
Snap_rounding_2_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Snap_rounding_2
Snap_rounding_2_demo_SOURCE_DIR:STATIC=C:/Program Files
Snap_rounding_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Snap_rounding_2
Snap_rounding_2_example_SOURCE_DIR:STATIC=C:/Program Files
Spatial_searchingDemo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Spatial_searching_2
Spatial_searchingDemo_SOURCE_DIR:STATIC=C:/Program Files
Spatial_searching_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Spatial_searching
Spatial_searching_example_SOURCE_DIR:STATIC=C:/Program Files
Spatial_sorting_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Spatial_sorting
Spatial_sorting_example_SOURCE_DIR:STATIC=C:/Program Files
Straight_skeleton_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Straight_skeleton_2
Straight_skeleton_2_example_SOURCE_DIR:STATIC=C:/Program Files
Stream_lines_2_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Stream_lines_2
Stream_lines_2_demo_SOURCE_DIR:STATIC=C:/Program Files
Stream_lines_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Stream_lines_2
Stream_lines_2_example_SOURCE_DIR:STATIC=C:/Program Files
Subdivision_method_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Subdivision_method_3
Subdivision_method_3_example_SOURCE_DIR:STATIC=C:/Program Files
Surface_mesh_parameterization_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Surface_mesh_parameterization
Surface_mesh_parameterization_example_SOURCE_DIR:STATIC=C:/Program Files
Surface_mesh_simplification_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Surface_mesh_simplification
Surface_mesh_simplification_example_SOURCE_DIR:STATIC=C:/Program Files
Surface_mesher_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Surface_mesher
Surface_mesher_SOURCE_DIR:STATIC=C:/Program Files
Surface_mesher_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Surface_mesher
Surface_mesher_example_SOURCE_DIR:STATIC=C:/Program Files
Surface_reconstruction_points_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Surface_reconstruction_points_3
Surface_reconstruction_points_3_example_SOURCE_DIR:STATIC=C:/Program Files
//Compilation options to use TAUCS
TAUCS_DEFINITIONS:STRING=
//Directories containing the TAUCS header files
TAUCS_INCLUDE_DIR:PATH=C:/Program Files
//TAUCS libraries name
TAUCS_LIBRARIES:FILEPATH=
//Directories containing the TAUCS libraries
TAUCS_LIBRARIES_DIR:PATH=C:/Program Files (x86)/CGAL-3.9/auxiliary/taucs/lib
Triangulation_2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Triangulation_2
Triangulation_2_SOURCE_DIR:STATIC=C:/Program Files
Triangulation_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Triangulation_2
Triangulation_2_example_SOURCE_DIR:STATIC=C:/Program Files
Triangulation_3_Demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Triangulation_3_Geomview_demos
Triangulation_3_Demo_SOURCE_DIR:STATIC=C:/Program Files
Triangulation_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Triangulation_3
Triangulation_3_example_SOURCE_DIR:STATIC=C:/Program Files
Triangulation_demo_3_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
Triangulation_demo_3_SOURCE_DIR:STATIC=C:/Program Files
Voronoi_diagram_2_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program
Files (x86)/CGAL-3.9/examples/Voronoi_diagram_2
Voronoi_diagram_2_example_SOURCE_DIR:STATIC=C:/Program Files
//Enable CGAL component Core
WITH_CGAL_Core:BOOL=ON
//Enable CGAL component ImageIO
WITH_CGAL_ImageIO:BOOL=ON
//Enable CGAL component Qt3
WITH_CGAL_Qt3:BOOL=ON
//Enable CGAL component Qt4
WITH_CGAL_Qt4:BOOL=ON
//Use the GMP number types if available.
WITH_GMP:BOOL=ON
//Use the LEDA number types if available.
WITH_LEDA:BOOL=OFF
//Use MPFI if available.
WITH_MPFI:BOOL=OFF
//Use NTL if available.
WITH_NTL:BOOL=OFF
//Use RS if available.
WITH_RS:BOOL=OFF
//Select demos
WITH_demos:BOOL=OFF
//Select examples
WITH_examples:BOOL=ON
Width_3_example_BINARY_DIR:STATIC=C:/Project_2/examples/C:/Program Files
(x86)/CGAL-3.9/examples/Width_3
Width_3_example_SOURCE_DIR:STATIC=C:/Program Files
//Path to a file.
ZLIB_INCLUDE_DIR:PATH=ZLIB_INCLUDE_DIR-NOTFOUND
ZLIB_LIBRARY:FILEPATH=ZLIB_LIBRARY-NOTFOUND
mesh_2_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Mesh_2
mesh_2_demo_SOURCE_DIR:STATIC=C:/Program Files (x86)/CGAL-3.9/demo/Mesh_2
mesh_2_qt3_demo_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Mesh_2/Qt3
mesh_2_qt3_demo_SOURCE_DIR:STATIC=C:/Program Files
straight_skeleton_2_BINARY_DIR:STATIC=C:/Project_2/demo/C:/Program Files
(x86)/CGAL-3.9/demo/Straight_skeleton_2
straight_skeleton_2_SOURCE_DIR:STATIC=C:/Program Files
# INTERNAL cache entries
//Stored GUID
AABB_custom_example_GUID_CMAKE:INTERNAL=FA8E912D-C231-4B55-8C06-3785032CFC86
//Stored GUID
AABB_custom_indexed_triangle_set_example_GUID_CMAKE:INTERNAL=4FC9771F-8BB4-48DE-838E-9F87225E0ABE
//Stored GUID
AABB_custom_triangle_soup_example_GUID_CMAKE:INTERNAL=B5A90249-EC00-4234-B46B-AF9FEBC411A0
//Stored GUID
AABB_insertion_example_GUID_CMAKE:INTERNAL=076005B5-7D5B-45EA-8A82-8730930877D0
//Stored GUID
AABB_polyhedron_edge_example_GUID_CMAKE:INTERNAL=C37E765A-5873-4131-8B42-073710310160
//Stored GUID
AABB_polyhedron_facet_distance_example_GUID_CMAKE:INTERNAL=1E2545B3-D658-4118-9EF4-E49464B317B2
//Stored GUID
AABB_polyhedron_facet_intersection_example_GUID_CMAKE:INTERNAL=62CD6917-467C-4DF6-BEB9-F716A51DC1C8
//Stored GUID
AABB_segment_3_example_GUID_CMAKE:INTERNAL=010044A0-FF24-472E-99F2-08A6807024A0
//Stored GUID
AABB_triangle_3_example_GUID_CMAKE:INTERNAL=DF7CE72F-7F29-4D55-8039-4802015ABF51
//Stored GUID
ALL_BUILD_GUID_CMAKE:INTERNAL=0DA79116-61C3-48F0-A913-66EE9E63753A
//Stored GUID
Authalic_parameterization_GUID_CMAKE:INTERNAL=364056CC-D89E-4280-8383-B03BE605DC66
//Stored GUID
Bezier_curves_GUID_CMAKE:INTERNAL=54BA268A-E8FF-4CE7-83E6-A61637855D91
//ADVANCED property for variable: Boost_INCLUDE_DIR
Boost_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_LIBRARY_DIRS
Boost_LIBRARY_DIRS-ADVANCED:INTERNAL=1
//The library version string for boost libraries
Boost_LIB_VERSION:INTERNAL=1_48
//Whether the Boost PROGRAM_OPTIONS library found
Boost_PROGRAM_OPTIONS_FOUND:INTERNAL=ON
//ADVANCED property for variable: Boost_PROGRAM_OPTIONS_LIBRARY
Boost_PROGRAM_OPTIONS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_PROGRAM_OPTIONS_LIBRARY_DEBUG
Boost_PROGRAM_OPTIONS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_PROGRAM_OPTIONS_LIBRARY_RELEASE
Boost_PROGRAM_OPTIONS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//Whether the Boost THREAD library found
Boost_THREAD_FOUND:INTERNAL=ON
//ADVANCED property for variable: Boost_THREAD_LIBRARY
Boost_THREAD_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_THREAD_LIBRARY_DEBUG
Boost_THREAD_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_THREAD_LIBRARY_RELEASE
Boost_THREAD_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//The version number for boost libraries
Boost_VERSION:INTERNAL=104800
CGAL_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_3RD_PARTY_INCLUDE_DIRS:INTERNAL=C:/Program Files
(x86)/CGAL-3.9/auxiliary/gmp/include;C:/Program Files
(x86)/CGAL-3.9/auxiliary/gmp/include;C:/boost_1_48_0
CGAL_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=C:/Program Files
(x86)/CGAL-3.9/auxiliary/gmp/lib;C:/Program Files
(x86)/CGAL-3.9/auxiliary/gmp/lib;C:/boost_1_48_0/stage/lib;C:/boost_1_48_0/stage/lib;C:/boost_1_48_0/stage/lib;C:/boost_1_48_0/stage/lib
//ADVANCED property for variable: CGAL_AUTO_LINK_GMP
CGAL_AUTO_LINK_GMP-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CGAL_AUTO_LINK_MPFR
CGAL_AUTO_LINK_MPFR-ADVANCED:INTERNAL=1
CGAL_CFG_ARRAY_MEMBER_INITIALIZATION_BUG:INTERNAL=1
//Result of TRY_COMPILE
CGAL_CFG_ARRAY_MEMBER_INITIALIZATION_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_DENORMALS_COMPILE_BUG:INTERNAL=0
CGAL_CFG_DENORMALS_COMPILE_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG:INTERNAL=1
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_IEEE_754_BUG:INTERNAL=0
CGAL_CFG_IEEE_754_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_ISTREAM_INT_BUG:INTERNAL=0
CGAL_CFG_ISTREAM_INT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_LONGNAME_BUG:INTERNAL=1
CGAL_CFG_LONGNAME_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_MATCHING_BUG_5:INTERNAL=0
CGAL_CFG_MATCHING_BUG_5_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_6:INTERNAL=1
CGAL_CFG_MATCHING_BUG_6_COMPILED:INTERNAL=FALSE
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG:INTERNAL=1
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_ARRAY:INTERNAL=0
CGAL_CFG_NO_CPP0X_ARRAY_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_AUTO:INTERNAL=0
CGAL_CFG_NO_CPP0X_AUTO_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_DECLTYPE:INTERNAL=0
CGAL_CFG_NO_CPP0X_DECLTYPE_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES:INTERNAL=1
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS:INTERNAL=1
CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS:INTERNAL=1
CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_INITIALIZER_LISTS:INTERNAL=1
CGAL_CFG_NO_CPP0X_INITIALIZER_LISTS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_ISFINITE:INTERNAL=1
CGAL_CFG_NO_CPP0X_ISFINITE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_CPP0X_LAMBDAS:INTERNAL=0
CGAL_CFG_NO_CPP0X_LAMBDAS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_LONG_LONG:INTERNAL=0
CGAL_CFG_NO_CPP0X_LONG_LONG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE:INTERNAL=0
CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_STATIC_ASSERT:INTERNAL=0
CGAL_CFG_NO_CPP0X_STATIC_ASSERT_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_TUPLE:INTERNAL=0
CGAL_CFG_NO_CPP0X_TUPLE_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES:INTERNAL=1
CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_LIMITS:INTERNAL=0
CGAL_CFG_NO_LIMITS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_LOGICAL_OPERATORS_ALTERNATIVES:INTERNAL=1
CGAL_CFG_NO_LOGICAL_OPERATORS_ALTERNATIVES_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_MESSAGE_PRAGMA_BUG:INTERNAL=0
CGAL_CFG_NO_MESSAGE_PRAGMA_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_NEXTAFTER:INTERNAL=1
CGAL_CFG_NO_NEXTAFTER_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_STATEMENT_EXPRESSIONS:INTERNAL=1
CGAL_CFG_NO_STATEMENT_EXPRESSIONS_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_STL:INTERNAL=0
CGAL_CFG_NO_STL_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TMPL_IN_TMPL_PARAM:INTERNAL=0
CGAL_CFG_NO_TMPL_IN_TMPL_PARAM_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_TR1_ARRAY:INTERNAL=1
CGAL_CFG_NO_TR1_ARRAY_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_TR1_TUPLE:INTERNAL=1
CGAL_CFG_NO_TR1_TUPLE_COMPILED:INTERNAL=FALSE
CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG:INTERNAL=1
CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_NUMERIC_LIMITS_BUG:INTERNAL=0
CGAL_CFG_NUMERIC_LIMITS_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG:INTERNAL=0
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG:INTERNAL=0
CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG:INTERNAL=0
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_USING_BASE_MEMBER_BUG_2:INTERNAL=0
CGAL_CFG_USING_BASE_MEMBER_BUG_2_COMPILED:INTERNAL=TRUE
//Variable hidden from user
CGAL_CGAL_LIBRARY:INTERNAL=
CGAL_CGAL_LIBRARY_NAME:INTERNAL=
CGAL_CONFIGURED_LIBRARIES:INTERNAL=CGAL;Core;ImageIO;Qt3;Qt4
CGAL_Core_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Core_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_Core_GUID_CMAKE:INTERNAL=6A631A28-77AE-46B7-9AC9-1C3B681EB815
CGAL_Core_LIBRARY:INTERNAL=
CGAL_Core_LIBRARY_NAME:INTERNAL=
CGAL_EXECUTABLE_TARGETS:INTERNAL=
//Stored GUID
CGAL_GUID_CMAKE:INTERNAL=C502C147-18E2-41EF-BD22-A8B92A1DC5DF
CGAL_ImageIO_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_LIBRARIES:INTERNAL=glu32;opengl32
CGAL_ImageIO_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//Stored GUID
CGAL_ImageIO_GUID_CMAKE:INTERNAL=372BCCD9-059B-451A-968D-809ECAD3100E
CGAL_ImageIO_LIBRARY:INTERNAL=
CGAL_ImageIO_LIBRARY_NAME:INTERNAL=
CGAL_Qt3_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Qt3_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
CGAL_Qt3_LIBRARY:INTERNAL=
CGAL_Qt3_LIBRARY_NAME:INTERNAL=
CGAL_Qt4_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Qt4_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Qt4_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Qt4_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
CGAL_Qt4_LIBRARY:INTERNAL=
CGAL_Qt4_LIBRARY_NAME:INTERNAL=
//ADVANCED property for variable: CMAKE_BUILD_TOOL
CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1
//What is the target build tool cmake is generating for.
CMAKE_BUILD_TOOL:INTERNAL=C:/PROGRA~2/MICROS~2.0/Common7/IDE/devenv.com
//This is the directory where this CMakeCache.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=c:/Project_2
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=8
//Patch version of cmake used to create the current loaded cache
CMAKE_CACHE_PATCH_VERSION:INTERNAL=7
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.8/bin/cmake.exe
//ADVANCED property for variable: CMAKE_CONFIGURATION_TYPES
CMAKE_CONFIGURATION_TYPES-ADVANCED:INTERNAL=1
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.8/bin/cpack.exe
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=C:/Program Files (x86)/CMake 2.8/bin/ctest.exe
//ADVANCED property for variable: CMAKE_CXX_COMPILER
CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_COMPILER_WITH_PATH
CMAKE_CXX_COMPILER_WITH_PATH-ADVANCED:INTERNAL=1
CMAKE_CXX_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_STANDARD_LIBRARIES
CMAKE_CXX_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_COMPILER_WITH_PATH
CMAKE_C_COMPILER_WITH_PATH-ADVANCED:INTERNAL=1
CMAKE_C_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_STANDARD_LIBRARIES
CMAKE_C_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE
CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE
//Path to cache edit program executable.
CMAKE_EDIT_COMMAND:INTERNAL=C:/Program Files (x86)/CMake
2.8/bin/cmake-gui.exe
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Name of generator.
CMAKE_GENERATOR:INTERNAL=Visual Studio 10 Win64
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=C:/Program Files (x86)/CGAL-3.9
//ADVANCED property for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=91
//ADVANCED property for variable: CMAKE_RC_COMPILER
CMAKE_RC_COMPILER-ADVANCED:INTERNAL=1
CMAKE_RC_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_RC_FLAGS
CMAKE_RC_FLAGS-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=C:/Program Files (x86)/CMake 2.8/share/cmake-2.8
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//Suppress Warnings that are meant for the author of the CMakeLists.txt
// files.
CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE
CMAKE_UNAME:INTERNAL=CMAKE_UNAME-NOTFOUND
//ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
CONFIG_CXX_FLAGS:INTERNAL= /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
//Stored GUID
CatmullClark_subdivision_GUID_CMAKE:INTERNAL=08794D97-D8EE-471E-829E-85636C5C8A19
//Stored GUID
Compare_1_GUID_CMAKE:INTERNAL=36A9FA5D-5CAF-48BC-8F2A-0CFF9AD38870
//Stored GUID
Complete_parameterization_example_GUID_CMAKE:INTERNAL=72F2DCE0-D99E-4202-8166-3EB31C0C4307
//Stored GUID
Compute_Ridges_Umbilics_GUID_CMAKE:INTERNAL=9E4CF849-A0C8-4613-BBE1-1D71C615D584
//Stored GUID
Construct_algebraic_real_1_GUID_CMAKE:INTERNAL=BB987B47-B369-4CDE-B87D-A5CC5249D8C4
//Stored GUID
Create_offset_polygons_2_GUID_CMAKE:INTERNAL=9C21A884-61ED-4FC1-B704-F8480817B10B
//Stored GUID
Create_saop_from_polygon_with_holes_2_GUID_CMAKE:INTERNAL=8551A4A4-E4C9-4144-B860-245C0FBE68D1
//Stored GUID
Create_skeleton_and_offset_polygons_2_GUID_CMAKE:INTERNAL=636DBD0E-AC76-4BA9-BAE9-03B819895F9A
//Stored GUID
Create_skeleton_and_offset_polygons_with_holes_2_GUID_CMAKE:INTERNAL=B843EFE1-DAEF-407D-A1EA-BCF93EED9882
//Stored GUID
Create_straight_skeleton_2_GUID_CMAKE:INTERNAL=41BFEE62-3271-41F9-B9A9-D426118F7B96
//Stored GUID
Create_straight_skeleton_from_polygon_with_holes_2_GUID_CMAKE:INTERNAL=18584C63-CF70-4EE6-B29C-2B9077772F4B
//Stored GUID
Customized_subdivision_GUID_CMAKE:INTERNAL=D4B388E7-96DA-4295-B13C-3A902D67A5D9
//Stored GUID
Default_GUID_CMAKE:INTERNAL=7FD810D5-4C08-4C74-B3F5-2AF2EEA845CD
//Stored GUID
DooSabin_subdivision_GUID_CMAKE:INTERNAL=E3233CE0-EC40-476C-AF26-0A2B14C4DB86
EXECUTABLE_OUTPUT_PATH:INTERNAL=
//Stored GUID
Example_GUID_CMAKE:INTERNAL=5CB5E7E9-ED44-485A-B9C2-A11CD871FF15
//Details about finding OpenGL
FIND_PACKAGE_MESSAGE_DETAILS_OpenGL:INTERNAL=[opengl32][v()]
//Stored GUID
Filtered_predicate_GUID_CMAKE:INTERNAL=BE00E8C1-7952-4D6F-A06A-60A6A202EC55
//ADVANCED property for variable: GLEW_GLEW_LIBRARY
GLEW_GLEW_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: GLEW_INCLUDE_DIR
GLEW_INCLUDE_DIR-ADVANCED:INTERNAL=1
GMP_COMPILE_RES:INTERNAL=TRUE
GMP_IN_CGAL_AUXILIARY:INTERNAL=TRUE
//Result of TRY_RUN
GMP_RUN_RES:INTERNAL=0
//Generator uses intermediate configuration directory
HAS_CFG_INTDIR:INTERNAL=TRUE
//Stored GUID
INSTALL_GUID_CMAKE:INTERNAL=B3886A04-CAB2-44E7-899E-2BF27E4D404C
//Stored GUID
Isolate_1_GUID_CMAKE:INTERNAL=7BC71648-AC48-4045-940A-3C12E4BAA41C
//Stored GUID
Kinetic_Delaunay_triangulation_2_GUID_CMAKE:INTERNAL=6D9D959D-3613-4521-8D6C-CB984D98997F
//Stored GUID
Kinetic_Delaunay_triangulation_3_GUID_CMAKE:INTERNAL=F8E7968B-CA05-4968-9069-7E6FDC23C94E
//Stored GUID
Kinetic_insert_event_GUID_CMAKE:INTERNAL=855099B2-F068-4B4B-A8B6-FA9BF717BE85
//Stored GUID
Kinetic_regular_triangulation_3_GUID_CMAKE:INTERNAL=4EF33ACA-A107-4568-AAEA-3031F69A6D01
//Stored GUID
Kinetic_sort_GUID_CMAKE:INTERNAL=479BB9AC-A6CB-41A4-8EAD-B0DA4C5E66F9
//Stored GUID
Kinetic_sweepline_GUID_CMAKE:INTERNAL=B09CC350-D54D-404D-8236-38032F2B5B26
LIBRARY_OUTPUT_PATH:INTERNAL=C:/Project_2/lib
//Stored GUID
Loop_subdivision_GUID_CMAKE:INTERNAL=92CFBD94-524E-4F4C-BF09-CB43689504A8
//Stored GUID
Low_level_API_GUID_CMAKE:INTERNAL=46D8AB8B-11EF-4287-9FD5-2A63556FAFEA
//ADVANCED property for variable: MKL_mkl_solver_LIBRARY
MKL_mkl_solver_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: MKL_mkl_solver_lp64_LIBRARY
MKL_mkl_solver_lp64_LIBRARY-ADVANCED:INTERNAL=1
MPFR_COMPILE_RES:INTERNAL=TRUE
MPFR_IN_CGAL_AUXILIARY:INTERNAL=TRUE
//Result of TRY_RUN
MPFR_RUN_RES:INTERNAL=0
//Stored GUID
Mesh_cutting_parameterization_GUID_CMAKE:INTERNAL=4371CB8F-BCD0-435E-806F-B1847EE45D1D
//Stored GUID
Mesh_estimation_GUID_CMAKE:INTERNAL=62514A80-7087-4CCF-A127-8AE130A400B7
//Stored GUID
MyKernel_GUID_CMAKE:INTERNAL=6490FD6C-39CD-4B9E-AF3B-8E299E8C97A6
//ADVANCED property for variable: OPENGL_gl_LIBRARY
OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_glu_LIBRARY
OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1
//Stored GUID
Polygon_GUID_CMAKE:INTERNAL=638A9B1D-C13E-4746-B490-F52CD7AC25DD
//Stored GUID
Profile_counter_GUID_CMAKE:INTERNAL=AB646C2F-1BD5-41E8-B5BA-FE0258D77891
//Stored GUID
Profile_histogram_counter_GUID_CMAKE:INTERNAL=C71C5972-31C3-4EB6-B783-029B03834A34
//Stored GUID
Profile_timer_GUID_CMAKE:INTERNAL=E55AA8D9-4905-4554-850D-25CC610DAC9B
//ADVANCED property for variable: QT3_INCLUDE_DIR
QT3_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_MOC_EXECUTABLE
QT3_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QASSISTANTCLIENT_LIBRARY
QT3_QASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QTMAIN_LIBRARY
QT3_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QT_LIBRARY
QT3_QT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_UIC_EXECUTABLE
QT3_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
//Stored GUID
SG_Filter_CMake
Rules_GUID_CMAKE:INTERNAL=54D0F8CF-2092-44EF-8B80-D2BCCF7455DC
//Stored GUID
SG_Filter_Header
Files_GUID_CMAKE:INTERNAL=455AB88C-D388-4DA0-BCBE-D9F69E112096
//Stored GUID
SG_Filter_Resources_GUID_CMAKE:INTERNAL=CA266017-1331-46CE-93C4-BABBFCD9C9E0
//Stored GUID
SG_Filter_Source
Files_GUID_CMAKE:INTERNAL=A9571844-2D24-4806-B9EB-7B215D9BC0C1
//Stored GUID
Show_offset_polygon_GUID_CMAKE:INTERNAL=BF0E5272-EBFA-4BCA-8520-B25D82A807A1
//Stored GUID
Show_straight_skeleton_GUID_CMAKE:INTERNAL=98AD6CEA-087B-4842-BC6E-0BAAFD0C90F1
//Stored GUID
Sign_at_1_GUID_CMAKE:INTERNAL=8DEDB2C4-A844-4037-96D6-BBD605BCA793
//Stored GUID
Simple_parameterization_GUID_CMAKE:INTERNAL=B23D15C1-0EB9-4A0B-9560-BFC48FD95A2F
//Stored GUID
Single_estimation_GUID_CMAKE:INTERNAL=A061B6B2-8FAE-4C10-AD19-EA0090E49030
//Stored GUID
Solve_1_GUID_CMAKE:INTERNAL=1C10CAA7-1B58-47A9-9F4E-C352572A67FB
//Stored GUID
Square_border_parameterization_GUID_CMAKE:INTERNAL=57EA120A-B0B0-4AEE-9AFA-096BA26C305A
//Stored GUID
Taucs_parameterization_GUID_CMAKE:INTERNAL=40460CE5-7F6E-4D26-B528-1A6136E323EE
//Stored GUID
Triangulation_3_color_demo_GUID_CMAKE:INTERNAL=93833539-E81C-4E88-BC8E-BDD8F9B248B9
//Stored GUID
Triangulation_3_demo_GUID_CMAKE:INTERNAL=A3B2CB3B-2FAE-48C7-B7B3-2FDF9F7DCF94
//Stored GUID
Triangulation_3_remove_demo_GUID_CMAKE:INTERNAL=B23C2C70-0925-4AEF-9689-01310B5424CB
//Stored GUID
Triangulation_3_voronoi_demo_GUID_CMAKE:INTERNAL=7886C747-7321-40FC-A4A6-E6B7ECBBB249
//Stored GUID
ZERO_CHECK_GUID_CMAKE:INTERNAL=8504C8E0-4506-4164-AF6C-F441311794E8
//ADVANCED property for variable: ZLIB_INCLUDE_DIR
ZLIB_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: ZLIB_LIBRARY
ZLIB_LIBRARY-ADVANCED:INTERNAL=1
//Stored GUID
adding_a_certificate_GUID_CMAKE:INTERNAL=7065ABBD-351C-43CD-A8A6-B6B8ABD63DA0
//Stored GUID
adding_handles_3_GUID_CMAKE:INTERNAL=8F56F95A-ACE6-4EBD-8211-98589ED9DD0D
//Stored GUID
adding_handles_GUID_CMAKE:INTERNAL=1E0BAE96-A816-4706-9B10-FC935C76CEA1
//Stored GUID
ag2_exact_traits_GUID_CMAKE:INTERNAL=88006983-21A2-4B42-83ED-AA55CD635E71
//Stored GUID
ag2_exact_traits_sqrt_GUID_CMAKE:INTERNAL=1F6269AA-1B1A-49EB-80DB-7470BFF73949
//Stored GUID
ag2_filtered_traits_no_hidden_GUID_CMAKE:INTERNAL=360E7F97-E7F3-4BF1-8196-40E2F4C887AC
//Stored GUID
ag2_hierarchy_GUID_CMAKE:INTERNAL=D5E3A32E-AF32-4871-9C0C-C75AF7A469B2
//Stored GUID
aggregated_insertion_GUID_CMAKE:INTERNAL=5BAC62CE-355D-48B4-915C-E336220B1695
//Stored GUID
algebraic_curves_GUID_CMAKE:INTERNAL=8A6B8D51-D729-4C3E-8293-58B3F8ECC0BE
//Stored GUID
algebraic_segments_GUID_CMAKE:INTERNAL=6B03C332-621C-4202-A467-EB962AE258E1
//Stored GUID
algebraic_structure_dispatch_GUID_CMAKE:INTERNAL=7DE9520F-5ADC-41F3-9212-0143D8BAA157
//Stored GUID
all_furthest_neighbors_2_GUID_CMAKE:INTERNAL=5DEEA633-EEAD-4581-9874-63B7E923B778
//Stored GUID
approx_convex_partition_2_GUID_CMAKE:INTERNAL=3753D53A-C51A-470B-9456-019573267F62
//Stored GUID
approx_inset_GUID_CMAKE:INTERNAL=957BDDFA-A1D1-4078-9453-7C57DA21CDCA
//Stored GUID
approx_offset_GUID_CMAKE:INTERNAL=35ADD3EE-0811-4D05-8D60-0EF73E4D2229
//Stored GUID
array_convex_hull_2_GUID_CMAKE:INTERNAL=D949D8E6-1256-4AB2-8FC0-80B71819E939
//Stored GUID
average_spacing_example_GUID_CMAKE:INTERNAL=B0DB0523-2AB2-42E0-9B48-FD82501674FE
//Stored GUID
ball_d_GUID_CMAKE:INTERNAL=CEC82D30-07F1-449E-BEBD-C8BED91EA76D
//Stored GUID
barycenter_GUID_CMAKE:INTERNAL=C422469D-6485-4D81-A4D8-06C8C3F68A34
//Stored GUID
batched_point_location_GUID_CMAKE:INTERNAL=5AB897B5-2EA5-42F3-A661-A8F4162B937A
//Stored GUID
benchmark_GUID_CMAKE:INTERNAL=6A0A5909-7714-4146-8798-9DA0359C923C
//Stored GUID
bezier_traits_adapter2_GUID_CMAKE:INTERNAL=64FB2C18-D73C-4711-86DB-E0221C38E677
//Stored GUID
bezier_traits_adapter_GUID_CMAKE:INTERNAL=D6039F6C-22BA-46A9-8FA1-56E103AB579B
//Stored GUID
bgl_dual_adapter_GUID_CMAKE:INTERNAL=3B93102B-F4C7-44ED-A903-0CEE8EF5D608
//Stored GUID
bgl_primal_adapter_GUID_CMAKE:INTERNAL=8E2A86B0-25CA-488E-8F06-E9D3E9CC68DB
//Stored GUID
bounded_planar_vertical_decomposition_GUID_CMAKE:INTERNAL=B02B0CD4-CCFA-4422-8257-2FF60B29799D
//Stored GUID
bounding_box_GUID_CMAKE:INTERNAL=27DF001C-7DF2-4346-976C-3A23E128745F
//Stored GUID
box_grid_GUID_CMAKE:INTERNAL=2F893FC3-1044-4D50-8A11-EEC183CA1B9F
//Stored GUID
cartesian_converter_GUID_CMAKE:INTERNAL=6F425ECD-97C3-4967-9C49-8415E49E241A
//Stored GUID
centroid_GUID_CMAKE:INTERNAL=093B36A5-CFBB-41A0-A3D1-727F85962EF6
//Stored GUID
ch_from_cin_to_cout_GUID_CMAKE:INTERNAL=57AA7063-D97D-4439-B58A-468DF40C2329
//Stored GUID
ch_graham_anderson_GUID_CMAKE:INTERNAL=ACCC53BE-798F-4A3E-85DD-1E4DAD1857E3
//Stored GUID
ch_timing_GUID_CMAKE:INTERNAL=1FA742FD-2CC0-43F9-A40D-5B4489DF71B1
//Stored GUID
chull_3d-geomview-demo_GUID_CMAKE:INTERNAL=F671119C-A1BF-4EB9-9DF4-024DB1F57E6F
//Stored GUID
chull_dd-geomview-demo_GUID_CMAKE:INTERNAL=9C763873-F24E-43D3-81E9-3EE951ED7C5B
//Stored GUID
chull_dd-runtime_GUID_CMAKE:INTERNAL=39A667E6-263A-4A17-8C56-335EA82085D2
//Stored GUID
circle_segment_GUID_CMAKE:INTERNAL=4B761D11-8AC3-40C2-8E09-0E8A5BCE195C
//Stored GUID
circles_GUID_CMAKE:INTERNAL=1F43FF7A-249C-4463-B467-563D899B7AEE
//Stored GUID
circular_arcs_GUID_CMAKE:INTERNAL=AE2E1046-8048-4D72-BF51-F57B402C1FDD
//Stored GUID
circular_line_arcs_GUID_CMAKE:INTERNAL=03686A43-FDAA-4CFD-A6D7-07914BE9554E
//Stored GUID
circular_query_GUID_CMAKE:INTERNAL=37B99701-B4D0-427B-B7E4-14A058DE5140
//Stored GUID
circulator_prog1_GUID_CMAKE:INTERNAL=E52E2333-DBA1-46F0-8B7A-975CBBC9E0CD
//Stored GUID
circulator_prog2_GUID_CMAKE:INTERNAL=9CD18D46-9A9E-40D8-80C8-A1BACFFEAB3A
//Stored GUID
circulator_prog3_GUID_CMAKE:INTERNAL=98872F64-996F-4B32-BC00-3CC7BA13CFEF
//Stored GUID
coefficient_access_GUID_CMAKE:INTERNAL=28B4FAA3-3AB0-4A52-9859-DEBD67136A94
//Stored GUID
color_GUID_CMAKE:INTERNAL=81A04FB7-7828-4425-9AE8-A51AA3CEF439
//Stored GUID
colored_face_GUID_CMAKE:INTERNAL=81C4D6A9-6092-4015-B595-B12F9BB1B968
//Stored GUID
colored_vertices_GUID_CMAKE:INTERNAL=DEAD4FBF-3FAC-4656-8667-1D7B5AF15656
//Stored GUID
comparison_GUID_CMAKE:INTERNAL=9507CFF9-2829-4DB4-A5A2-F83C019A17E6
//Stored GUID
complex_construction_GUID_CMAKE:INTERNAL=ED9FBD61-E16E-4081-B6D2-B51AF4B99579
//Stored GUID
conform_GUID_CMAKE:INTERNAL=7BDBB043-60DC-41E8-9BEE-923B4B7AE4E2
//Stored GUID
conforming_GUID_CMAKE:INTERNAL=62A298F4-6C74-464C-80F6-D7931D2F561E
//Stored GUID
conic_multiplicities_GUID_CMAKE:INTERNAL=FD8EF9D6-E19F-4DBF-A48F-7493F241BC33
//Stored GUID
conic_traits_adapter_GUID_CMAKE:INTERNAL=0D3027DF-AC86-48D6-9488-2979FEDF55C6
//Stored GUID
conics_GUID_CMAKE:INTERNAL=9E399CC9-380B-4666-98B8-B31CF3B2365F
//Stored GUID
connect_polygon_GUID_CMAKE:INTERNAL=CA7E50E9-CFFD-4716-8524-9E33E469F4D0
//Stored GUID
consolidated_curve_data_GUID_CMAKE:INTERNAL=D21DF569-5C11-4781-9696-10D2C2C3742E
//Stored GUID
constrained_GUID_CMAKE:INTERNAL=238CE4B7-12DF-4907-90EB-E5F8F13E9C09
//Stored GUID
constrained_hierarchy_plus_GUID_CMAKE:INTERNAL=285FEFE1-45F6-4B50-A82E-AE38D509D821
//Stored GUID
constrained_plus_GUID_CMAKE:INTERNAL=5E366B23-3198-475B-B68F-C48EF05C4677
//Stored GUID
construction_GUID_CMAKE:INTERNAL=AB748F73-B4CD-40CA-8E81-D3892303255F
//Stored GUID
convert_raw_image_to_inr_GUID_CMAKE:INTERNAL=80D1DD38-181A-4630-B8D1-D7EF8A72425D
//Stored GUID
convex_hull_GUID_CMAKE:INTERNAL=F518EB8B-D07C-4725-B322-A54DDADB2583
//Stored GUID
convex_hull_containment2_GUID_CMAKE:INTERNAL=7418E98B-B89B-40C8-9848-9DC1E5BF059A
//Stored GUID
convex_hull_containment_GUID_CMAKE:INTERNAL=6C47F0FE-ABF8-4E09-9C89-49F8E67A1C55
//Stored GUID
convex_hull_containment_benchmarks_GUID_CMAKE:INTERNAL=16364D46-7A6D-415B-A931-4A3BA6402115
//Stored GUID
covering_GUID_CMAKE:INTERNAL=597DD118-EBED-43C7-A8BE-833A7979D22E
//Stored GUID
cube_d_GUID_CMAKE:INTERNAL=5CA413E9-6748-43B6-A074-BD0A8FA9D54D
//Stored GUID
cube_offset_GUID_CMAKE:INTERNAL=6FC9DC9A-1446-4E17-A636-F025C5946C90
//Stored GUID
curve_history_GUID_CMAKE:INTERNAL=22EAD7CD-C957-4B85-AE91-19C0425F68B2
//Stored GUID
custom_box_grid_GUID_CMAKE:INTERNAL=7C40A688-7CA6-47F9-8E30-CEA5B1C85755
//Stored GUID
cycling_GUID_CMAKE:INTERNAL=B8AFF329-1645-4F2E-BF1C-DF8171E2278D
//Stored GUID
dcel_extension_GUID_CMAKE:INTERNAL=FF9CADD2-A03B-4E9B-8322-10E5C02645DF
//Stored GUID
dcel_extension_io_GUID_CMAKE:INTERNAL=BF6403FF-5835-4FF3-AF0F-403C8D868A91
//Stored GUID
defining_a_simulation_traits_GUID_CMAKE:INTERNAL=5C98DCB3-BD64-4FED-83B7-84D2CF306583
//Stored GUID
degree_GUID_CMAKE:INTERNAL=5AAEDC8D-DD3B-41B5-AD5E-368F67997972
//Stored GUID
delaunay_GUID_CMAKE:INTERNAL=EEB78D2D-107B-431C-B579-FAEAB553D136
//Stored GUID
delaunay_dd-runtime_GUID_CMAKE:INTERNAL=8567693C-D36C-4C24-8426-C771F71FD24F
//Stored GUID
demos_GUID_CMAKE:INTERNAL=8BD10E59-E3FF-47FB-B9E7-878F2376A8C3
//Stored GUID
dijkstra_GUID_CMAKE:INTERNAL=D600E28C-8F78-4737-9294-1D393D44BE19
//Stored GUID
dijkstra_with_internal_properties_GUID_CMAKE:INTERNAL=3B6CFC5B-D8FD-414D-B713-8630E00728F8
//Stored GUID
distance_GUID_CMAKE:INTERNAL=E83B5A69-8253-4036-94FC-911F3195A431
//Stored GUID
distance_browsing_GUID_CMAKE:INTERNAL=1106416D-E9BF-4FE9-BBFA-D23D7C7D56EE
//Stored GUID
do_intersect_GUID_CMAKE:INTERNAL=734FCADA-8F65-40A7-BA28-2E7E3A9171AA
//Stored GUID
dual_GUID_CMAKE:INTERNAL=E6F6F2B7-BC71-44FE-9300-B75C8A60FE01
//Stored GUID
dual_lines_GUID_CMAKE:INTERNAL=27D0DFB2-8428-47F2-8BCE-F7BD1C9E9B79
//Stored GUID
dual_with_data_GUID_CMAKE:INTERNAL=1B78B44B-37C2-45F4-BD3C-4C28CDBB164A
//Stored GUID
dxf_union_GUID_CMAKE:INTERNAL=A459E226-8B1A-4E25-81AF-8243D8DA9E59
//Stored GUID
dynamic_hull_3_GUID_CMAKE:INTERNAL=27703604-C21C-431F-938A-F09CF7445B0B
//Stored GUID
edge_collapse_constrained_polyhedron_GUID_CMAKE:INTERNAL=369C105E-C5A1-41C7-8565-5C3DF5F6FF05
//Stored GUID
edge_collapse_enriched_polyhedron_GUID_CMAKE:INTERNAL=F240D454-919B-4294-959D-8E47516152D3
//Stored GUID
edge_collapse_polyhedron_GUID_CMAKE:INTERNAL=EB2E2D6F-0544-465F-8C70-4B0A361E220E
//Stored GUID
edge_insertion_GUID_CMAKE:INTERNAL=FA768A7E-E138-4C04-AE7E-1C1ADB7C6EA0
//Stored GUID
edge_manipulation_GUID_CMAKE:INTERNAL=1FBF3C4F-355B-40E0-95DB-A69D4F1D7ED2
//Stored GUID
edge_manipulation_curve_history_GUID_CMAKE:INTERNAL=BB9B7592-54D4-41C1-A0FC-F1678BA96C8F
//Stored GUID
ellipsoid_GUID_CMAKE:INTERNAL=CE63561F-0B9E-4B1B-8E24-51D8C4BD2E6B
//Stored GUID
ellipsoid_for_maple_GUID_CMAKE:INTERNAL=527E9470-A926-4588-B9E7-D92DE4345E95
//Stored GUID
emst_GUID_CMAKE:INTERNAL=5A42E59A-7C36-4711-AE1E-A18921B8DA73
//Stored GUID
envelope_circles_GUID_CMAKE:INTERNAL=325CD778-3A36-4094-A014-93F4E3021562
//Stored GUID
envelope_planes_GUID_CMAKE:INTERNAL=DA88981A-3D13-4E49-B594-E28ACCB44523
//Stored GUID
envelope_segments_GUID_CMAKE:INTERNAL=083EE1C2-BF6C-4EBB-92EC-5558B5D1F74C
//Stored GUID
envelope_spheres_GUID_CMAKE:INTERNAL=973CBA60-7CC7-4EB2-9E7B-25982D2EAF36
//Stored GUID
envelope_triangles_GUID_CMAKE:INTERNAL=6D1AF0A2-0E14-48E5-85E1-CFF8D65220CB
//Stored GUID
ex_alpha_shapes_2_GUID_CMAKE:INTERNAL=5CFE959C-F691-4B68-8439-106DE11CCABB
//Stored GUID
ex_alpha_shapes_3_GUID_CMAKE:INTERNAL=11E2461A-3C45-4AD1-ABF5-2C002C88C475
//Stored GUID
ex_alpha_shapes_with_fast_location_3_GUID_CMAKE:INTERNAL=1155CB07-1885-400C-BCB8-1D79FC9535E6
//Stored GUID
ex_fixed_weighted_alpha_shapes_3_GUID_CMAKE:INTERNAL=D24F8158-7580-4E7E-B9E3-9C619213CF3A
//Stored GUID
ex_periodic_alpha_shapes_3_GUID_CMAKE:INTERNAL=1CA01B18-1C46-4B45-88DA-525736E8C71F
//Stored GUID
ex_weighted_alpha_shapes_2_GUID_CMAKE:INTERNAL=506128B7-928A-4148-B594-4AECE1B12085
//Stored GUID
ex_weighted_alpha_shapes_3_GUID_CMAKE:INTERNAL=B659BA90-4E79-4BF4-8881-6BDFE27CB21C
//Stored GUID
exact_inset_GUID_CMAKE:INTERNAL=E21A0B68-6ADA-48B9-88D5-E068AD29F349
//Stored GUID
exact_offset_GUID_CMAKE:INTERNAL=C0CD0D33-ECF2-49C3-9DA5-744788C6B663
//Stored GUID
example_delaunay_2_GUID_CMAKE:INTERNAL=6AC7B8B5-7A23-416E-9E68-43E5E86F7851
//Stored GUID
examples_GUID_CMAKE:INTERNAL=ECCB4163-82ED-4B91-80A9-F9E1C80EB023
//Stored GUID
exploration_SM_GUID_CMAKE:INTERNAL=44D64CAA-4A73-44B9-A903-C45430AC2339
//Stored GUID
extended_kernel_GUID_CMAKE:INTERNAL=663D00C0-770C-41B2-8A4F-ABF876FAEC8B
//Stored GUID
extremal_polygon_2_area_GUID_CMAKE:INTERNAL=2DB9C44A-D2C7-466D-8B6C-9B43DEF6AC05
//Stored GUID
extremal_polygon_2_perimeter_GUID_CMAKE:INTERNAL=7194985B-5C02-4CAA-B6E1-43303B166B02
//Stored GUID
face_extension_GUID_CMAKE:INTERNAL=80A7FCF7-EFA1-48D6-BD67-BF0C043D66A8
//Stored GUID
face_extension_overlay_GUID_CMAKE:INTERNAL=1B9EB643-31C8-4BB1-B736-60D14A0512EA
//Stored GUID
fast_location_3_GUID_CMAKE:INTERNAL=8D9D5176-A519-40A6-BA2A-D165A82ECD3A
//Stored GUID
find_conflicts_3_GUID_CMAKE:INTERNAL=B54F3E7A-5787-4733-A39B-C92EDDBFB6AC
//Stored GUID
find_conflicts_GUID_CMAKE:INTERNAL=5C906923-87DC-4236-AA62-CCCD2B4DD73E
//Stored GUID
first_lp_GUID_CMAKE:INTERNAL=E3588D5B-7121-417C-94F9-CD9AB11A40E3
//Stored GUID
first_lp_from_iterators_GUID_CMAKE:INTERNAL=33E457EC-E1D7-4533-B798-30D027733C63
//Stored GUID
first_lp_from_mps_GUID_CMAKE:INTERNAL=C50209C4-5360-45D5-A5BE-C1F3C73795C5
//Stored GUID
first_nonnegative_lp_GUID_CMAKE:INTERNAL=BA40EB91-0B6F-4293-A039-4EAEC0803EDD
//Stored GUID
first_nonnegative_lp_from_iterators_GUID_CMAKE:INTERNAL=7526B81F-7A6A-4863-A866-A81729330C40
//Stored GUID
first_nonnegative_lp_from_mps_GUID_CMAKE:INTERNAL=1C5A91CB-B304-47DF-BD8E-388738C19D33
//Stored GUID
first_nonnegative_qp_GUID_CMAKE:INTERNAL=2E2BAC8D-7281-464E-8B3F-F41C920C24C9
//Stored GUID
first_nonnegative_qp_from_iterators_GUID_CMAKE:INTERNAL=ECA21EE3-A28B-46E2-8FA7-63C27E32C1C8
//Stored GUID
first_nonnegative_qp_from_mps_GUID_CMAKE:INTERNAL=C7A6EE33-DA96-4B2D-83E8-E49D08DAB825
//Stored GUID
first_qp_GUID_CMAKE:INTERNAL=97809722-9080-42D8-A12E-5B7E2BBDBA95
//Stored GUID
first_qp_basic_constraints_GUID_CMAKE:INTERNAL=49F699A1-0CE6-42CE-9D6C-03CC3725262E
//Stored GUID
first_qp_from_iterators_GUID_CMAKE:INTERNAL=F8AA8E7F-2D08-4E50-A8FB-81014F09EB0D
//Stored GUID
first_qp_from_mps_GUID_CMAKE:INTERNAL=E7268CA2-1E91-4894-8B3A-8407C867CE74
//Stored GUID
fraction_traits_GUID_CMAKE:INTERNAL=D2B84FE4-413E-41DD-ADB0-B24B9416FE88
//Stored GUID
functor_compare_theta_3_GUID_CMAKE:INTERNAL=6CF054DC-CFB5-42F1-B08D-5796E298C6A1
//Stored GUID
functor_has_on_2_GUID_CMAKE:INTERNAL=AD718A05-2768-4FE8-A5E7-6EFDA45F8249
//Stored GUID
functor_has_on_3_GUID_CMAKE:INTERNAL=847E0644-F995-4D31-A059-26B1C44C71A3
//Stored GUID
fuzzy_range_query_GUID_CMAKE:INTERNAL=D3521D7E-6E05-4C05-92DC-9894EE6E8A00
//Stored GUID
gcd_up_to_constant_factor_GUID_CMAKE:INTERNAL=86D0ED6E-C92D-4D7E-BC83-CF6195612EF1
//Stored GUID
general_neighbor_searching_GUID_CMAKE:INTERNAL=7F6E4BDC-7ED3-46D7-9ED1-314DF799101E
//Stored GUID
generic_curve_data_GUID_CMAKE:INTERNAL=60A93457-1986-442A-8D81-3EB9D6B41D5C
//Stored GUID
geometric_access_GUID_CMAKE:INTERNAL=CE1E11AE-992C-45F4-B37C-38D54386D36F
//Stored GUID
geomview_demo_GUID_CMAKE:INTERNAL=ADF41BB6-21CA-4ADE-AAD3-A94D1DB937C1
//Stored GUID
glide_GUID_CMAKE:INTERNAL=E1425057-08D8-44E6-BFBF-8BD200B966DC
//Stored GUID
global_insertion_GUID_CMAKE:INTERNAL=B5E2A589-6E13-49F1-A3DF-EE5E1EB15978
//Stored GUID
global_removal_GUID_CMAKE:INTERNAL=43C1A361-5F8F-485C-A4F1-88F075367E06
//Stored GUID
greene_approx_convex_partition_2_GUID_CMAKE:INTERNAL=2A7B1096-2CB5-43D8-8D86-777B6E8AAE24
//Stored GUID
grid_d_GUID_CMAKE:INTERNAL=49D56102-BF92-4B4D-98ED-E720D71B18B8
//Stored GUID
grid_simplification_example_GUID_CMAKE:INTERNAL=201283E9-DAA9-431C-9E52-E30282B4901E
//Stored GUID
gv_terrain_GUID_CMAKE:INTERNAL=F67DA560-C680-442E-9F4C-2ECF4ABB1BCD
//Stored GUID
handling_double_coordinates_GUID_CMAKE:INTERNAL=A102E7A6-93D8-4B52-A156-631F4A14A473
//Stored GUID
hds_prog_color_GUID_CMAKE:INTERNAL=006CB902-431C-4AB1-8FF9-2C5655D9B8F8
//Stored GUID
hds_prog_compact2_GUID_CMAKE:INTERNAL=CE9034E4-DBAC-4056-8CB5-18774AD9BC96
//Stored GUID
hds_prog_compact_GUID_CMAKE:INTERNAL=FCCACC77-E053-4B06-8C54-D4B8B4C07B02
//Stored GUID
hds_prog_default_GUID_CMAKE:INTERNAL=1D1EB249-6976-49FA-80D1-12F9BB21DA1D
//Stored GUID
hds_prog_edge_iterator_GUID_CMAKE:INTERNAL=2769192E-0921-4AA4-89D6-ED4A39BAE2EB
//Stored GUID
hds_prog_graph2_GUID_CMAKE:INTERNAL=7903AA7F-43B5-4DFD-90E4-55BAA1881936
//Stored GUID
hds_prog_graph_GUID_CMAKE:INTERNAL=79EBA520-E894-4D42-8E4B-F259B378397F
//Stored GUID
hds_prog_halfedge_iterator_GUID_CMAKE:INTERNAL=65DF8DBE-7277-47B6-9A24-C35E01ECCB24
//Stored GUID
hds_prog_vector_GUID_CMAKE:INTERNAL=8D6B6515-AF22-44C6-B358-F671B2FFC003
//Stored GUID
hierarchy_GUID_CMAKE:INTERNAL=2646B060-552E-4EDE-B873-887E07630CDA
//Stored GUID
hilbert_GUID_CMAKE:INTERNAL=C494EAA4-1BCF-4DF1-A87D-F5C977B5C682
//Stored GUID
hilbert_policies_GUID_CMAKE:INTERNAL=A77C380C-0A07-4253-97DA-65737E6B4E4D
//Stored GUID
implicit_interoperable_dispatch_GUID_CMAKE:INTERNAL=37375657-7BB6-4409-89C8-290BA0DFC400
//Stored GUID
important_variables_GUID_CMAKE:INTERNAL=922C616A-060A-4CA8-ABEB-FBD767338375
//Stored GUID
in_place_list_prog_GUID_CMAKE:INTERNAL=5EFFE1F2-867F-4FB3-9F48-4A4D081C5B66
//Stored GUID
incremental_hull_3_GUID_CMAKE:INTERNAL=4A75EB94-0A2F-4DDF-A59F-AB2D3BF18432
//Stored GUID
incremental_hull_3_demo_GUID_CMAKE:INTERNAL=134394DE-9518-4B00-97E7-EAB46A5DF3E2
//Stored GUID
incremental_hull_class_3_GUID_CMAKE:INTERNAL=F581AF1D-30EF-4BC6-85EB-51B93D69A708
//Stored GUID
incremental_insertion_GUID_CMAKE:INTERNAL=2BBF7B4B-34AD-42CD-BB23-12E501155CE6
//Stored GUID
infeasibility_certificate_GUID_CMAKE:INTERNAL=B373F70C-472D-46B5-AF6D-A08386EE588A
//Stored GUID
info_insert_with_pair_iterator_2_GUID_CMAKE:INTERNAL=467DD363-BA7E-485C-A7A8-5E25D3B408D5
//Stored GUID
info_insert_with_pair_iterator_GUID_CMAKE:INTERNAL=C8DD97E2-631E-43E8-88B9-9A51002738A7
//Stored GUID
info_insert_with_pair_iterator_regular_2_GUID_CMAKE:INTERNAL=AA531026-26EA-4357-9E50-C43375F47BD4
//Stored GUID
info_insert_with_pair_iterator_regular_GUID_CMAKE:INTERNAL=8B976003-ED0F-4B5F-A7CF-1AA80270B321
//Stored GUID
info_insert_with_transform_iterator_2_GUID_CMAKE:INTERNAL=8E2658BF-E1F7-4A91-9EF5-391CA301B4B8
//Stored GUID
info_insert_with_transform_iterator_GUID_CMAKE:INTERNAL=6BE44C74-1ACA-4FA5-8327-4E7C876574B4
//Stored GUID
info_insert_with_zip_iterator_2_GUID_CMAKE:INTERNAL=B08CDF5C-DAED-45CD-A5CC-17C20E80FCCD
//Stored GUID
info_insert_with_zip_iterator_GUID_CMAKE:INTERNAL=D280E630-6277-45B8-84E2-FC7B5A65A7C7
//Stored GUID
input_GUID_CMAKE:INTERNAL=7CA3F278-8359-427D-99DA-330DD683698A
//Stored GUID
install_FindCGAL_GUID_CMAKE:INTERNAL=3B1431BE-BA8C-40D2-A553-422FF2D48317
//Stored GUID
integralize_GUID_CMAKE:INTERNAL=D9EFD086-7F6D-476D-823F-3799E7170142
//Stored GUID
interface_polyhedron_GUID_CMAKE:INTERNAL=AEAD0F8C-9365-46F8-B9E5-E4AB9CF3596A
//Stored GUID
interoperable_GUID_CMAKE:INTERNAL=1A9E39BF-960E-4ED2-847A-C2597EA01433
//Stored GUID
interpolation_2_GUID_CMAKE:INTERNAL=1B0B0957-8A88-4F35-B499-2961E5411E8F
//Stored GUID
intersecting_arcs_GUID_CMAKE:INTERNAL=8F2293B3-EBD8-4AC4-847F-1DA67F2F9865
//Stored GUID
intersecting_spheres_GUID_CMAKE:INTERNAL=6EE04637-692A-4C6B-8BD2-FBCB9789A28E
//Stored GUID
intervals_GUID_CMAKE:INTERNAL=F71C228D-11F2-41E7-A744-9F58C6020677
//Stored GUID
invert_matrix_GUID_CMAKE:INTERNAL=03A2B899-2EE5-4BE4-A46D-374D3B11E153
//Stored GUID
io_GUID_CMAKE:INTERNAL=BFD8587D-E55A-487B-A9B6-D1B586CB47A5
//Stored GUID
io_curve_history_GUID_CMAKE:INTERNAL=88C939FB-A608-4305-A778-89D1BAF367EE
//Stored GUID
io_unbounded_GUID_CMAKE:INTERNAL=4A183C5E-7633-4AA0-8EFF-C881AAA3DE65
//Stored GUID
iostream_convex_hull_2_GUID_CMAKE:INTERNAL=41F21358-9D26-48AD-B65A-3DEFF0BB110A
//Stored GUID
isl_terrain_GUID_CMAKE:INTERNAL=B899BE8B-7456-48E5-8524-0B29CA9E67A6
//Stored GUID
iso_rectangle_2_query_GUID_CMAKE:INTERNAL=A4E33977-DF40-4DAD-8869-B742705452BD
//Stored GUID
isolated_vertices_GUID_CMAKE:INTERNAL=23B03CFC-987D-4EE8-971C-DE3D4C8B07CC
//Stored GUID
iv2off_GUID_CMAKE:INTERNAL=9357DE93-C90B-4D0E-BB1D-6E62F4D861D9
//Stored GUID
jet_smoothing_example_GUID_CMAKE:INTERNAL=5527B655-6ED1-4A0D-95E1-FDF53AF5EAE1
//Stored GUID
kernel_GUID_CMAKE:INTERNAL=3D3D5311-5588-4836-95AF-3D79F59D9EAC
//Stored GUID
kruskal_GUID_CMAKE:INTERNAL=505E45BF-21F8-41F7-B27A-00EF1DB969BE
//Stored GUID
kruskal_with_stored_id_GUID_CMAKE:INTERNAL=B6B72B5C-4087-4A28-B4B7-492F299318A0
//Stored GUID
large_point_set_GUID_CMAKE:INTERNAL=F34D9AC9-F3F6-4BA8-AEE4-38AEAB8D7CB9
//Stored GUID
largest_empty_rectangle_GUID_CMAKE:INTERNAL=E3EDE454-BE20-433F-96A4-3E610375819F
//Stored GUID
linear_interpolation_2_GUID_CMAKE:INTERNAL=6D16E62E-503A-4A20-8D59-53C58F555991
//Stored GUID
linear_least_squares_fitting_points_2_GUID_CMAKE:INTERNAL=A5C70860-05DF-4E55-BA49-FBAF54A163E8
//Stored GUID
linear_least_squares_fitting_triangles_3_GUID_CMAKE:INTERNAL=2BF357D0-E861-4412-B5BB-E0CC6265CFCD
//Stored GUID
linking_2d_and_3d_GUID_CMAKE:INTERNAL=AE870CF6-3660-4677-98CE-3B280AFAFFF1
//Stored GUID
list_of_convex_parts_GUID_CMAKE:INTERNAL=5D545C9D-40BD-405B-A729-997A38F8D79D
//Stored GUID
listener_GUID_CMAKE:INTERNAL=E56D6706-5C6C-4CE3-B84B-3C1FEA350A07
//Stored GUID
map_3_marks_GUID_CMAKE:INTERNAL=964B9763-E95B-4AF0-9994-4C1AC18C1348
//Stored GUID
map_3_operations_GUID_CMAKE:INTERNAL=CA407432-F9B4-47A5-9C19-4EF9EEBED93A
//Stored GUID
map_3_simple_example_GUID_CMAKE:INTERNAL=14DCE01E-6940-4A3A-9735-31ACE20460AE
//Stored GUID
map_3_with_colored_facets_GUID_CMAKE:INTERNAL=6A5FFA1C-7A95-4216-99D2-F20B096C3409
//Stored GUID
map_4_simple_example_GUID_CMAKE:INTERNAL=B5BDF587-C81A-4FA4-B0D0-22B8F16F48C9
//Stored GUID
mesh_GUID_CMAKE:INTERNAL=92BACFC9-52D0-4CA9-A67E-A9D8226D1E65
//Stored GUID
mesh_a_3d_gray_image_GUID_CMAKE:INTERNAL=B453A1FF-C2A3-4AAE-BA2F-C6DDE481A386
//Stored GUID
mesh_an_implicit_function_GUID_CMAKE:INTERNAL=FDAADB37-41AB-405A-B9C5-2352B8198A4F
//Stored GUID
mesh_class_GUID_CMAKE:INTERNAL=3A2FF831-E2E0-42D9-A9F1-8B6477CCF98F
//Stored GUID
mesh_global_GUID_CMAKE:INTERNAL=73637C52-9E50-4A69-98A6-BC8669966E68
//Stored GUID
mesh_implicit_sphere_GUID_CMAKE:INTERNAL=BFE21A3C-E408-402B-AA76-510EBD0EA7C3
//Stored GUID
mesh_implicit_sphere_variable_size_GUID_CMAKE:INTERNAL=7A1BD735-BC65-483E-B354-8A24D8FDD401
//Stored GUID
mesh_optimization_example_GUID_CMAKE:INTERNAL=153EDC2F-17D5-41E0-BAF2-E93862C4EDCF
//Stored GUID
mesh_optimization_lloyd_example_GUID_CMAKE:INTERNAL=1E5AFC5C-5993-4A3F-980D-6F61D15212F0
//Stored GUID
mesh_polyhedral_domain_GUID_CMAKE:INTERNAL=6B5156A5-1ECA-42E9-ADAB-3EB48E8A5F06
//Stored GUID
mesh_polyhedral_domain_with_features_GUID_CMAKE:INTERNAL=4A6AD90D-0BF6-43CA-A8FB-7025F44C769D
//Stored GUID
mesh_two_implicit_spheres_with_balls_GUID_CMAKE:INTERNAL=59D8FEF1-2781-4B2B-A24F-3A482AA13707
//Stored GUID
mesh_with_seeds_GUID_CMAKE:INTERNAL=6E559EB6-F5FD-4F31-9232-9358516C0768
//Stored GUID
min_annulus_d_GUID_CMAKE:INTERNAL=D6A8AB98-4BCB-465D-B7A3-2610720D4D4C
//Stored GUID
min_annulus_d_fast_exact_GUID_CMAKE:INTERNAL=9756F463-39A7-4DCF-9551-22FF6C87ADD2
//Stored GUID
min_circle_2_GUID_CMAKE:INTERNAL=2873330C-60E5-4E65-AD3F-8C19ADF862C0
//Stored GUID
min_element_if_example_GUID_CMAKE:INTERNAL=CE0D79CB-533F-43AB-AFE8-B13314168D0F
//Stored GUID
min_ellipse_2_GUID_CMAKE:INTERNAL=6C7819DB-59B2-44A9-AB2D-C11E5AC1366E
//Stored GUID
min_max_element_example_GUID_CMAKE:INTERNAL=CAA1B581-0BD7-485E-830E-17FC9083010B
//Stored GUID
min_sphere_d_GUID_CMAKE:INTERNAL=29F71017-EC82-4F44-826B-110638170932
//Stored GUID
min_sphere_of_spheres_d_2_GUID_CMAKE:INTERNAL=ACB58098-313D-4D91-9B61-D6F47E62D355
//Stored GUID
min_sphere_of_spheres_d_3_GUID_CMAKE:INTERNAL=9DC08303-8FCD-4234-AE03-05B11610DE56
//Stored GUID
min_sphere_of_spheres_d_d_GUID_CMAKE:INTERNAL=121FCCB1-81B8-49DA-B5BA-135C9C352975
//Stored GUID
minimal_GUID_CMAKE:INTERNAL=4B837AAD-B981-4051-B934-FCAF2C6EB459
//Stored GUID
minimal_self_GUID_CMAKE:INTERNAL=F7C37A5D-6FB5-48E7-9E0B-1BDEC3215A13
//Stored GUID
minimum_enclosing_parallelogram_2_GUID_CMAKE:INTERNAL=A5AD7B42-DEB2-4AB7-ADD4-53C84A9C134D
//Stored GUID
minimum_enclosing_rectangle_2_GUID_CMAKE:INTERNAL=46B2B23A-6044-45B7-B2A4-059AB806E87F
//Stored GUID
minimum_enclosing_strip_2_GUID_CMAKE:INTERNAL=20C03EFA-ED80-4EC4-AD7B-932E0A787E28
//Stored GUID
modular_filter_GUID_CMAKE:INTERNAL=F79B2D34-4A16-441B-8715-999A07F7A435
//Stored GUID
myPoint_GUID_CMAKE:INTERNAL=6490F7B6-AA43-4C8C-861F-A7BFEB82BE74
//Stored GUID
nearest_neighbor_GUID_CMAKE:INTERNAL=E04E9FD5-0095-423E-ACA6-99FA61275C5E
//Stored GUID
nearest_neighbor_searching_GUID_CMAKE:INTERNAL=9BAFBA7B-1564-4799-B7AA-DCA0AD079D4D
//Stored GUID
nefIO_GUID_CMAKE:INTERNAL=0406BACD-CD35-45F3-9FE2-08A9296128EA
//Stored GUID
nef_2_construction_GUID_CMAKE:INTERNAL=C71751E9-CB1E-4944-8206-361F0D3FFB30
//Stored GUID
nef_2_intersection_GUID_CMAKE:INTERNAL=41EB00E7-4B9A-49EF-A50F-FD69C829D84D
//Stored GUID
nef_2_polylines_GUID_CMAKE:INTERNAL=B39E953C-531F-4AB3-A906-4265A5BB8BCD
//Stored GUID
nef_3_construction_GUID_CMAKE:INTERNAL=2DBCD70B-816C-468C-ACBA-DD89F412FB57
//Stored GUID
nef_3_point_location_GUID_CMAKE:INTERNAL=ED962C26-672B-43F4-8012-D037B93DF484
//Stored GUID
nef_3_simple_GUID_CMAKE:INTERNAL=0B46D6BB-15A0-4A76-A9F0-98E33C11DFC6
//Stored GUID
nef_s2_construction_GUID_CMAKE:INTERNAL=2127EF1A-276F-4CD4-B473-F29852FD383C
//Stored GUID
nef_s2_exploration_GUID_CMAKE:INTERNAL=C2E1B27A-DBAB-40B5-8F7C-B748DC24409F
//Stored GUID
nef_s2_point_location_GUID_CMAKE:INTERNAL=3A3F3FC0-4B2A-486D-BDC6-760E8D6D05A6
//Stored GUID
nef_s2_simple_GUID_CMAKE:INTERNAL=505E9C5E-AD12-4D86-8AFD-66DE9C41B88D
//Stored GUID
nn_coordinates_2_GUID_CMAKE:INTERNAL=2F73B74C-4448-4EAD-AFB8-B5549BB705B3
//Stored GUID
nn_coordinates_3_GUID_CMAKE:INTERNAL=0CA18FC1-69D4-44DF-9653-299032A23F61
//Stored GUID
normal_estimation_GUID_CMAKE:INTERNAL=65B5024B-A2B8-4484-9876-98C7EF7424C2
//Stored GUID
normals_example_GUID_CMAKE:INTERNAL=0AC0EA1F-D4DF-4293-8D3D-45A33CC07C91
//Stored GUID
observer_GUID_CMAKE:INTERNAL=FA88DB78-4757-428D-BE31-8D8147231525
//Stored GUID
off2iv_GUID_CMAKE:INTERNAL=23B8FBB4-F4B0-47D6-98EB-FA1BBAE96C8E
//Stored GUID
off2off_GUID_CMAKE:INTERNAL=DBA4508F-80D4-49CC-84BF-3A0B9706D577
//Stored GUID
off2stl_GUID_CMAKE:INTERNAL=81C62285-A1B4-478B-8D0B-59F1AC62E904
//Stored GUID
off2vrml_GUID_CMAKE:INTERNAL=60E73F03-F78A-4D47-BA48-5520D9E64147
//Stored GUID
off2wav_GUID_CMAKE:INTERNAL=610F7B1B-8D46-47D8-9F72-97CCCF412592
//Stored GUID
offIO_GUID_CMAKE:INTERNAL=740C86AF-E724-411D-802B-2253D8C856E2
//Stored GUID
off_bbox_GUID_CMAKE:INTERNAL=E2135526-0705-4869-A91D-85BC71114A4F
//Stored GUID
off_glue_GUID_CMAKE:INTERNAL=F4FA7C42-2CE7-4D2D-BEDC-A521D2F298C7
//Stored GUID
off_transform_GUID_CMAKE:INTERNAL=6FC2FB3A-4F4C-44A6-ACF1-CE43B8963484
//Stored GUID
optimal_convex_partition_2_GUID_CMAKE:INTERNAL=DE232326-23FE-4B7E-A369-81F6D088C21E
//Stored GUID
optimality_certificate_GUID_CMAKE:INTERNAL=8DC4D647-D42C-4003-A3E0-855917EF7648
//Stored GUID
overlay_GUID_CMAKE:INTERNAL=03F9ED1A-8633-4060-9A7D-F6209B634D7D
//Stored GUID
overlay_unbounded_GUID_CMAKE:INTERNAL=384486BE-3C18-44A2-80AE-3F7EDC7EB5AD
//Stored GUID
periodic_adding_handles_GUID_CMAKE:INTERNAL=11CF0BAF-340E-4894-B6D1-5ADFC25B7196
//Stored GUID
poi_GUID_CMAKE:INTERNAL=F4719D37-4D5A-41F4-8C1C-9F40E9C9FAAF
//Stored GUID
point_location_GUID_CMAKE:INTERNAL=8E1915D8-8A07-49F5-956F-2838A584E3F3
//Stored GUID
point_set_operations_GUID_CMAKE:INTERNAL=0CEE2905-772A-4723-8CAA-52A4047A5FEA
//Stored GUID
pointer_queue_GUID_CMAKE:INTERNAL=B3E940E4-AF74-491A-84FD-2944A86E0FEB
//Stored GUID
poisson_reconstruction_example_GUID_CMAKE:INTERNAL=82834B63-CD32-4D86-A415-2CE28A2A5197
//Stored GUID
polygon_algorithms_GUID_CMAKE:INTERNAL=578DE017-C2A4-41FA-8561-674B934D60AC
//Stored GUID
polyhedron2vrml_GUID_CMAKE:INTERNAL=4F7AFDD6-4B75-4685-A209-BE90C2E83DBE
//Stored GUID
polyhedron_copy_GUID_CMAKE:INTERNAL=3E901132-157E-4ECE-B19A-84BA88988D02
//Stored GUID
polyhedron_ex_parameterization_GUID_CMAKE:INTERNAL=52F28A9E-985B-4A73-BD3E-013D7C272647
//Stored GUID
polyhedron_prog_color_GUID_CMAKE:INTERNAL=027D5A84-B920-4040-8B01-81084AB3D642
//Stored GUID
polyhedron_prog_cube_GUID_CMAKE:INTERNAL=A7872E1D-526A-4A78-B0A1-0F8FD831D508
//Stored GUID
polyhedron_prog_cut_cube_GUID_CMAKE:INTERNAL=D0435148-6DBD-46A4-B4DA-B67F7F41E841
//Stored GUID
polyhedron_prog_incr_builder_GUID_CMAKE:INTERNAL=FCDA6116-AE1D-4B7D-9367-F81A6116EEB8
//Stored GUID
polyhedron_prog_normals_GUID_CMAKE:INTERNAL=CAB1A469-A343-4B43-9C99-AD2400C7B8AE
//Stored GUID
polyhedron_prog_off_GUID_CMAKE:INTERNAL=B76E3C2A-1137-4BCA-8EEB-9E63C2089728
//Stored GUID
polyhedron_prog_planes_GUID_CMAKE:INTERNAL=31847DBB-F4EA-410F-9C08-D93F2AA8B2F7
//Stored GUID
polyhedron_prog_simple_GUID_CMAKE:INTERNAL=E6D20C1C-7794-4512-93B3-90F0176FD1A7
//Stored GUID
polyhedron_prog_subdiv_GUID_CMAKE:INTERNAL=A591F778-2CB9-4DA7-9EB5-F438B5410512
//Stored GUID
polyhedron_prog_subdiv_with_boundary_GUID_CMAKE:INTERNAL=2A6856DD-936A-43C0-B3BB-4077356897A4
//Stored GUID
polyhedron_prog_tetra_GUID_CMAKE:INTERNAL=DD74889E-4187-42AE-AC0E-B66E45F16387
//Stored GUID
polyhedron_prog_traits_GUID_CMAKE:INTERNAL=342DDFE1-2EA7-491B-A161-AB88F0D14466
//Stored GUID
polyhedron_prog_vector_GUID_CMAKE:INTERNAL=EB22D0AD-C701-4BCE-B287-F035F7555F03
//Stored GUID
polyhedron_prog_vertex_color_GUID_CMAKE:INTERNAL=DB8478F4-4471-4D0A-90F9-B7E6C53620BF
//Stored GUID
polyhedron_prog_vertex_normal_GUID_CMAKE:INTERNAL=1A852931-B716-486F-BD39-CB3850D3BF7E
//Stored GUID
polyhedron_self_intersection_GUID_CMAKE:INTERNAL=629BBA2E-AA58-41CC-85F7-83263609DFBB
//Stored GUID
polyline_construction_GUID_CMAKE:INTERNAL=63DFA2C3-FB9E-4E8F-A5DA-86F06A4DF2AA
//Stored GUID
polylines_GUID_CMAKE:INTERNAL=14D7C94A-2B1E-41E6-8336-507F4AB17EC3
//Stored GUID
polytope_distance_d_GUID_CMAKE:INTERNAL=5BFEA2ED-374B-4036-B90A-8BB46D06B8D7
//Stored GUID
polytope_distance_d_fast_exact_GUID_CMAKE:INTERNAL=E1F2F6EE-04D7-44A4-B366-7E781B835681
//Stored GUID
predefined_kernel_GUID_CMAKE:INTERNAL=27F96FDC-3F5B-4489-8C62-09800D284915
//Stored GUID
predefined_kernel_non_intersecting_GUID_CMAKE:INTERNAL=BFA8CB2B-68D2-4548-BD5C-1E7D717C01D8
//Stored GUID
primal_GUID_CMAKE:INTERNAL=48A45860-C994-44B9-8786-07AFFEB3B2E8
//Stored GUID
print_first_lp_GUID_CMAKE:INTERNAL=F86710BC-FE06-4A03-939D-9C50101E50FC
//Stored GUID
print_first_nonnegative_lp_GUID_CMAKE:INTERNAL=A749747F-B084-40DA-8026-65AF01483B8D
//Stored GUID
print_first_nonnegative_qp_GUID_CMAKE:INTERNAL=58CBF866-69D8-4EBE-8898-EC88A68A5008
//Stored GUID
print_first_qp_GUID_CMAKE:INTERNAL=678C5BB7-59E5-4D68-87D4-C34042899C07
//Stored GUID
projected_polygon_GUID_CMAKE:INTERNAL=443B1C70-E7DE-440A-BBED-0AA49EF96F0B
//Stored GUID
property_map_GUID_CMAKE:INTERNAL=92BE2E17-5095-4EEE-9B83-2B83C5EBEE93
//Stored GUID
proximity_custom_box_traits_GUID_CMAKE:INTERNAL=B561C27A-0396-44FE-8F82-3D1EA6DD1013
//Stored GUID
quickhull_3_GUID_CMAKE:INTERNAL=FF2EB4F5-4762-4E28-9261-7D77A65DDFF0
//Stored GUID
quickhull_3_demo_GUID_CMAKE:INTERNAL=B9EC1E2A-7B52-47C7-B8F3-02C4EDC87475
//Stored GUID
random_convex_set_GUID_CMAKE:INTERNAL=A0068722-6753-495A-B8DB-0A19E8D468F1
//Stored GUID
random_degenerate_point_set_GUID_CMAKE:INTERNAL=4C95E38B-C629-4F3B-8C55-6F9E7F1A93B5
//Stored GUID
random_grid_GUID_CMAKE:INTERNAL=D8B14FA1-382D-42BB-BBAD-39023D739837
//Stored GUID
random_polygon2_GUID_CMAKE:INTERNAL=A1EB56DE-1203-4B83-B4EB-E781867EF620
//Stored GUID
random_polygon_GUID_CMAKE:INTERNAL=B0B8BA8E-E739-400E-A5E7-E57E1A4E4AA0
//Stored GUID
random_segments1_GUID_CMAKE:INTERNAL=127AC4EA-E6F9-4047-95BD-7919E142410C
//Stored GUID
random_segments2_GUID_CMAKE:INTERNAL=A3920127-ABA8-4CE9-A484-2516B48DAD0A
//Stored GUID
random_simplification_example_GUID_CMAKE:INTERNAL=4B044D5F-E858-4127-9490-26322FB46A50
//Stored GUID
range_search_GUID_CMAKE:INTERNAL=36855A41-52FE-4A96-800C-F1FF0EEBD107
//Stored GUID
range_tree_1_GUID_CMAKE:INTERNAL=E1EF154F-AD5C-4ED1-99B7-6A83083C34D9
//Stored GUID
range_tree_2_GUID_CMAKE:INTERNAL=0660146D-4B3A-469F-B52C-336A6ABAF470
//Stored GUID
range_tree_3_GUID_CMAKE:INTERNAL=302DD36C-32AC-4A8A-955E-C3BD1112693D
//Stored GUID
range_tree_4_GUID_CMAKE:INTERNAL=30A80C67-B979-495F-A272-61C332FAEE10
//Stored GUID
range_tree_map_2_GUID_CMAKE:INTERNAL=9FBFE4EA-4CD1-45C0-BFFC-9B181B730078
//Stored GUID
range_tree_set_2_GUID_CMAKE:INTERNAL=5EC60687-2E55-422E-9630-D87FB6F03C03
//Stored GUID
rational_functions_GUID_CMAKE:INTERNAL=085B71E4-7DDE-4535-80BC-38E07710FBF6
//Stored GUID
rational_functions_rational_coefficients_GUID_CMAKE:INTERNAL=027BD37A-A275-4215-966D-4AFB94E3883A
//Stored GUID
read_write_xyz_point_set_example_GUID_CMAKE:INTERNAL=CF4B8102-7CFC-4C6B-B7F9-DD32C7821217
//Stored GUID
rectangular_p_center_2_GUID_CMAKE:INTERNAL=17DC0D0B-0F5A-424E-AC6B-B73AA98D8F3D
//Stored GUID
ref_counted_GUID_CMAKE:INTERNAL=B9CF783E-F9F2-4542-901E-3A8945E87DC6
//Stored GUID
regular_3_GUID_CMAKE:INTERNAL=D42BB44F-9D36-48BD-8AD3-70B844942DE2
//Stored GUID
regular_GUID_CMAKE:INTERNAL=E2A47B92-3D5C-4E75-947A-276FD1E35636
//Stored GUID
remove_outliers_example_GUID_CMAKE:INTERNAL=A7A2BFF7-790C-49AD-80B3-2CB9F9BD940D
//Stored GUID
rn_coordinates_2_GUID_CMAKE:INTERNAL=BB47E713-F9DE-4455-8516-DD32CC3750CC
//Stored GUID
sdg-count-sites_GUID_CMAKE:INTERNAL=EAEC322C-A5C2-4134-B8F8-3CF71D1C4461
//Stored GUID
sdg-filtered-traits_GUID_CMAKE:INTERNAL=5107FC22-B63E-4E95-A87D-0DCB8742AA42
//Stored GUID
sdg-info-set_GUID_CMAKE:INTERNAL=B4A2463D-CC46-44A2-95BF-D9A2902576F8
//Stored GUID
sdg-red-blue-info_GUID_CMAKE:INTERNAL=56566105-D6E1-4544-9FB1-913E7D2160AD
//Stored GUID
sdg-voronoi-edges_GUID_CMAKE:INTERNAL=AB38D566-BA28-435A-9614-1E82D7A43205
//Stored GUID
searching_with_circular_query_GUID_CMAKE:INTERNAL=47CF966D-724A-4E61-8436-606EC6948764
//Stored GUID
searching_with_point_with_info_GUID_CMAKE:INTERNAL=84BA7E75-314A-4F7F-B0B7-195F0E8C626B
//Stored GUID
searching_with_point_with_info_inplace_GUID_CMAKE:INTERNAL=F0AE4B21-F8D1-4718-A8A7-2CCB35EABCE6
//Stored GUID
searching_with_point_with_info_pmap_GUID_CMAKE:INTERNAL=21CEC6C8-D745-4C85-BB2D-48E567551B0D
//Stored GUID
segment_tree_1_GUID_CMAKE:INTERNAL=50997D06-60FC-457E-89D2-C81F30B63812
//Stored GUID
segment_tree_2_GUID_CMAKE:INTERNAL=16A8602B-16BC-400F-B3F9-E4118C133B7C
//Stored GUID
segment_tree_3_GUID_CMAKE:INTERNAL=A02E650E-935C-4BC0-A2F5-6329BBF9834D
//Stored GUID
segment_tree_4_GUID_CMAKE:INTERNAL=46F062F9-F4F0-4FB7-B897-698CF8AF5896
//Stored GUID
segment_tree_map_2_GUID_CMAKE:INTERNAL=5F0B95AA-4794-4DFB-B507-C7757DF9E0FC
//Stored GUID
segment_tree_set_2_GUID_CMAKE:INTERNAL=707B8432-22CE-4B1C-8D00-049CF75E5399
//Stored GUID
segment_tree_set_3_GUID_CMAKE:INTERNAL=409DC52A-1F20-4344-86E7-0401AD818FE1
//Stored GUID
sequence_GUID_CMAKE:INTERNAL=4B7FE626-3D19-4582-9CF8-4C6F51B7867A
//Stored GUID
set_operations_GUID_CMAKE:INTERNAL=2E3AF9B5-3666-4B5A-AE1E-9B560FE4CFFB
//Stored GUID
set_union_GUID_CMAKE:INTERNAL=A4088A0E-8149-45D7-A978-D9EC80CE8033
//Stored GUID
shell_exploration_GUID_CMAKE:INTERNAL=ECC11725-516D-42FB-A8C5-30B8898AED23
//Stored GUID
sibson_interpolation_2_GUID_CMAKE:INTERNAL=FA929924-9D4A-476A-9ADA-D5F2C7E44166
//Stored GUID
simple_example_GUID_CMAKE:INTERNAL=6582E8CB-84B7-4357-9855-023DBF87E775
//Stored GUID
simple_join_intersect_GUID_CMAKE:INTERNAL=2456BB45-90E7-48DA-AE45-25EBFD54D37E
//Stored GUID
simple_triangulation_3_GUID_CMAKE:INTERNAL=3B7FA13D-73A3-4CB3-9299-CF31A4C50D56
//Stored GUID
simplex_GUID_CMAKE:INTERNAL=3675C661-564B-431F-BE43-BC425CAD6679
//Stored GUID
skin_surface_simple_GUID_CMAKE:INTERNAL=0E4F1054-D276-4667-B3AE-0D688DD6360E
//Stored GUID
skin_surface_subdiv_GUID_CMAKE:INTERNAL=6F276F44-44C8-406D-82E2-FCD62DECB95E
//Stored GUID
skin_surface_subdiv_with_normals_GUID_CMAKE:INTERNAL=89996A83-BBBB-4DBF-9935-5D98E90F80D6
//Stored GUID
small_example_delaunay_2_GUID_CMAKE:INTERNAL=0668DB21-6FF6-4036-BC86-3B43A965BA86
//Stored GUID
snap_rounding_GUID_CMAKE:INTERNAL=7FB98E18-2735-480D-8AE1-F8D2C4782017
//Stored GUID
snap_rounding_to_integer_GUID_CMAKE:INTERNAL=AAC57067-BDB9-4D91-8FB6-1BF46A73B11B
//Stored GUID
software_design_rgs_GUID_CMAKE:INTERNAL=F9892210-8577-4B9E-ACCC-6B0A0F788231
//Stored GUID
solve_polynomial_GUID_CMAKE:INTERNAL=F41F81E8-5E7F-49F8-A982-344CAEEFE7F4
//Stored GUID
sort_indices_GUID_CMAKE:INTERNAL=3F6FACBA-A33D-4B82-AF62-7327AC18FAF4
//Stored GUID
sorted_matrix_search_GUID_CMAKE:INTERNAL=AB56BF65-DA8F-4B60-ABAD-B41E209284E0
//Stored GUID
sp_sort_using_property_map_2_GUID_CMAKE:INTERNAL=18A28851-3E3B-4808-A25D-563A0B84AE81
//Stored GUID
sp_sort_using_property_map_3_GUID_CMAKE:INTERNAL=7C2C1CF1-2722-472A-82B7-0C1822577C12
//Stored GUID
sp_sort_using_property_map_d_GUID_CMAKE:INTERNAL=A6A91DFF-0C8E-4F41-A79D-D6F83F04C2DA
//Stored GUID
special_edge_insertion_GUID_CMAKE:INTERNAL=75921A1F-6116-403A-821A-9DFE3D00EFBF
//Stored GUID
sphere_d_GUID_CMAKE:INTERNAL=006F8D00-3E3C-44A0-9535-C5805E062A10
//Stored GUID
spherical_insert_GUID_CMAKE:INTERNAL=DD973C34-B8D6-4B47-8D14-FE293584A48B
//Stored GUID
stl_regular_field_GUID_CMAKE:INTERNAL=D160A43D-8723-4119-AC06-91DB19944BE3
//Stored GUID
stl_triangular_field_GUID_CMAKE:INTERNAL=2058E4F6-73D1-4563-ABE7-D548DBA25416
//Stored GUID
subresultants_GUID_CMAKE:INTERNAL=3ADDD81A-6935-4F84-B515-9BB9FB0C4F5B
//Stored GUID
substitute_GUID_CMAKE:INTERNAL=5FE40C15-EA87-4369-9880-B709C2DAFA23
//Stored GUID
sum_by_decomposition_GUID_CMAKE:INTERNAL=3BB18A3E-E1C4-40BB-A35F-E729E8606A15
//Stored GUID
sum_triangles_GUID_CMAKE:INTERNAL=F41D004F-7F5A-4CCB-B556-1CD271C6310F
//Stored GUID
sum_with_holes_GUID_CMAKE:INTERNAL=FFD6E989-1B04-4BB7-AA7E-C4FC6C39B2FA
//Stored GUID
surface_neighbor_coordinates_3_GUID_CMAKE:INTERNAL=96C39C24-5F43-4802-B100-B51658A1FCB7
//Stored GUID
surface_voronoi_GUID_CMAKE:INTERNAL=5D23EA01-C383-455F-8B1F-F0BA2CCA564B
//Stored GUID
swap_move_GUID_CMAKE:INTERNAL=5D4820E4-1A87-499E-883F-BC54C3CE1D52
//Stored GUID
sweep_line_GUID_CMAKE:INTERNAL=50A87A98-2712-4997-90BA-37BBBFF2189D
//Stored GUID
symmetric_difference_GUID_CMAKE:INTERNAL=9F41E32D-8BE3-4AD8-8313-8C540EC775B4
//Stored GUID
tds_GUID_CMAKE:INTERNAL=5FE775F7-06ED-4E50-AAD1-0AF94D140B1D
//Stored GUID
terr_trian_GUID_CMAKE:INTERNAL=6728DA11-1BC2-44EB-9E14-29FA4D75FC31
//Stored GUID
terrain_GUID_CMAKE:INTERNAL=E2FA47AD-5782-4247-8EA4-F33E1DE38CAB
//Stored GUID
test_grabbers_GUID_CMAKE:INTERNAL=D22A897F-8323-4381-A466-529E6B267D24
//Stored GUID
test_imageio_GUID_CMAKE:INTERNAL=0EDA99F7-0874-456D-9320-F6779466006A
//Stored GUID
topological_operations_GUID_CMAKE:INTERNAL=30FAE938-CEB5-48CB-9F73-63DA5A2DA198
//Stored GUID
tracing_counting_GUID_CMAKE:INTERNAL=7176E9CF-C8A4-432F-AC5A-34179499CFAC
//Stored GUID
transformation_GUID_CMAKE:INTERNAL=48B35E68-97FE-4E1F-9E73-641EBD8408BD
//Stored GUID
triangle_self_intersect_GUID_CMAKE:INTERNAL=865C271C-0D1E-4B87-8E4E-652A12066FCD
//Stored GUID
triangle_self_intersect_pointers_GUID_CMAKE:INTERNAL=6327F289-1BC0-45F2-B372-AC1844BFB31C
//Stored GUID
triangulation_prog1_GUID_CMAKE:INTERNAL=7ED0155A-AAF8-49E0-A663-7FECF1A5C0B4
//Stored GUID
trivial_kds_GUID_CMAKE:INTERNAL=FA31BC15-2BBD-4B47-9F01-9A90A01D7683
//Stored GUID
unb_planar_vertical_decomposition_GUID_CMAKE:INTERNAL=17B62D95-65B7-485A-A382-E25DED4084CF
//Stored GUID
unbounded_non_intersecting_GUID_CMAKE:INTERNAL=F4DC5821-3BBC-43D2-BF01-D7D8194AE404
//Stored GUID
unbounded_rational_functions_GUID_CMAKE:INTERNAL=4E17487C-70AC-4426-93E3-2DE75D589CF0
//Stored GUID
unboundedness_certificate_GUID_CMAKE:INTERNAL=7370D019-BB83-4D06-A975-D3337725DC6E
//Stored GUID
union_of_balls_simple_GUID_CMAKE:INTERNAL=B394FF3B-8141-4A1D-AD33-27C180C798B5
//Stored GUID
union_of_balls_subdiv_GUID_CMAKE:INTERNAL=0A1C057B-E7DB-43E7-8190-043F1E28F6DC
//Stored GUID
user_defined_point_and_distance_GUID_CMAKE:INTERNAL=22BF6C65-8693-4F0E-BA0F-455893AE1828
//Stored GUID
using_fair_splitting_rule_GUID_CMAKE:INTERNAL=25BED741-92EE-4A49-B39E-976A94506949
//Stored GUID
vd_2_point_location_GUID_CMAKE:INTERNAL=1E6BDB0B-897F-40F3-90BE-5DC4619E298F
//Stored GUID
vector_convex_hull_2_GUID_CMAKE:INTERNAL=7C2D846F-2BF5-4CDB-B002-F482DE7F99F4
//Stored GUID
vertical_ray_shooting_GUID_CMAKE:INTERNAL=113C985C-570E-4482-8E59-FF502CA76A66
//Stored GUID
viewpoint2off_GUID_CMAKE:INTERNAL=2FB18380-9731-43DE-8EE3-937B2F3E2EAB
//Stored GUID
voronoi_GUID_CMAKE:INTERNAL=2E2D37FA-F53C-4359-B13D-1BBE48085282
//Stored GUID
weighted_Minkowski_distance_GUID_CMAKE:INTERNAL=3930E510-6F12-4AD6-8CF5-F2707551C424
//Stored GUID
width_simplex_GUID_CMAKE:INTERNAL=07E95152-E1F0-45AD-8A29-712EBE44C74D
//Stored GUID
y_monotone_partition_2_GUID_CMAKE:INTERNAL=10882949-836A-4266-9259-897C6ACB7DF7
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/visual-studio-2010-void-cdecl-CGAL-assertion-fail-char-const-char-const-int-char-const-tp4405348p4406482.html
