cgal-discuss - Re: [cgal-discuss] Complex geometries creation from VRML file with Nef polyhedra
  • To:
  • Subject: Re: [cgal-discuss] Complex geometries creation from VRML file with Nef polyhedra
  • Date: Tue, 21 Feb 2012 16:30:01 +0100
On 02/21/2012 03:48 PM, Helmi Ben Hmida wrote:
Hi all,
I´m trying to create Nef polyhedra from the different geometries already
exist in a VRML file. Some of theses geometries is composed by 20 3D
point (x,y,z) with a Double values and not an Integer one in order to
apply some Boolean operation on them.
Do any one has an Idea how is it possible to proceed.
Thanks in advance for u re help
If you convert you VRML file into a Polyhedron or to an off file, then
you can directly use import functions.
About your points with floating point coordinates, Nef expects that if
you give it a face, all its points are coplanar. If this is not your
case, then a simple solution is to triangulate all faces.
Sebastien.
