cgal-discuss - Re: [cgal-discuss] polygon and polygon spatial relation
  • To:
  • Subject: Re: [cgal-discuss] polygon and polygon spatial relation
  • Date: Thu, 23 Feb 2012 10:21:02 +0100
I think the most efficient way to do it to first construct an
arrangement for the first polygon and check whether any
point of the second polygon is inside the other. If so then use the
do_intersect function with the other polygon as curve (x-monotone curve
will be all segments)
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Function_do_intersect.html
You should be able to use the Arr_polyline_traits_2
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Class_Arr_polyline_traits_2.html#Cross_link_anchor_1234
see also main chapter:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html
Sebastien.
On 02/23/2012 10:06 AM, cnng0315 wrote:
in cgal, there are methods to predicate whether a point is inside a polygon,
But is there any method to check whether a polygon is inside a polygon.
I can use cgal's bool-operation module to solve this, but I believe this is
not effectient, can any one give me some idea?
technology change life!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/polygon-and-polygon-spatial-relation-tp4413255p4413255.html
