cgal-discuss - Re: [cgal-discuss] How to insert points with info in Periodic_3_Delaunay_triangulation_3?
  • To:
  • Subject: Re: [cgal-discuss] How to insert points with info in Periodic_3_Delaunay_triangulation_3?
  • Date: Wed, 29 Feb 2012 14:21:35 +0100
On 02/29/2012 01:58 PM, Jakob van Bethlehem wrote:
Hello,
As a new subscriber to this list, I'm not exactly sure if this is the
right place to pose my question, but if not, maybe someone can redirect me.
What I'm basically trying to achieve is the procedure described in
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_38.5.3
Unfortunately, this is not working for periodic triangulations.
Your typedefs are correct, but you need to insert points one by one and
set the info after.
Vertex_handle v=pdt.insert(pt);
v->info()=Info();
Sebastien.
except that I'm trying for a Periodic_3_Delaunay_triangulation_3. Since
that class derives from this class, I'd expect this to work as well.
Unfortunately the compiler complains with:
[..]/include/c++/4.6.2/bits/stl_construct.h:76: error: no matching
function for call to ‘CGAL::Point_3<CGAL::Cartesian<double>
>::Point_3(std::pair<CGAL::Point_3<CGAL::Cartesian<double> >, Info>&)’
And just before that:
/usr/include/CGAL/Periodic_3_Delaunay_triangulation_3.h:194:
instantiated from ‘std::ptrdiff_t
CGAL::Periodic_3_Delaunay_triangulation_3<Gt,
Tds>::insert(InputIterator, InputIterator, bool) [with InputIterator =
__gnu_cxx::__normal_iterator<std::pair<CGAL::Point_3<CGAL::Cartesian<double>
>, Info>*, std::vector<std::pair<CGAL::Point_3<CGAL::Cartesian<double>
>, Info> > >, [..]
To really spill out all the details, these are my type definitions:
struct Info;
typedef CGAL::Cartesian<double> Kernel3;
typedef CGAL::Periodic_3_triangulation_traits_3<Kernel3> GT;
typedef CGAL::Periodic_3_triangulation_ds_vertex_base_3<> VbDS;
typedef CGAL::Triangulation_vertex_base_3<GT,VbDS> Vb;
typedef CGAL::Periodic_3_triangulation_ds_cell_base_3<> CbDS;
typedef CGAL::Triangulation_cell_base_3<GT,CbDS> Cb;
typedef CGAL::Triangulation_vertex_base_with_info_3<Info, GT, Vb> VbInfo;
typedef CGAL::Triangulation_data_structure_3<VbInfo, Cb> TDS;
typedef CGAL::Periodic_3_Delaunay_triangulation_3<Traits, Tds>
Per_delaunay;
I don't think the exact contents of the 'Info' struct should make a big
difference here, but if it does, I could spill out that one as well on
request. Like in the example I created a vector of pairs of a Point and
Info-objects and then I try to call the 'insert()' member with the
'begin()' and 'end()' iterator of that vector. Apparently in a normal
case the compiler is told to take the 'first' element when constructing
Point_3 objects, but not in the periodic case.
Is there some overloaded version of 'insert()' missing in the periodic
tessellation type, or am I missing something?
(actually I also tried with a vector of std::pair<Periodic_point, Info>
elements, but got the same error about not being able to construct a
Point_3 object from such a pair)
Sincerely,
Jakob van Bethlehem
