Re: [cgal-discuss] How to insert points with info in Periodic_3_Delaunay_triangulation_3?
- To:
- Subject: Re: [cgal-discuss] How to insert points with info in Periodic_3_Delaunay_triangulation_3?
- Date: Thu, 01 Mar 2012 10:38:32 +0100
On 02/29/2012 06:22 PM, Sebastien Loriot (GeometryFactory) wrote:
On 02/29/2012 03:27 PM, Jakob van Bethlehem wrote:
On 02/29/2012 02:21 PM, Sebastien Loriot (GeometryFactory) wrote:
On 02/29/2012 01:58 PM, Jakob van Bethlehem wrote:[..]
Hello,Unfortunately, this is not working for periodic triangulations.
As a new subscriber to this list, I'm not exactly sure if this is the
right place to pose my question, but if not, maybe someone can
redirect me.
What I'm basically trying to achieve is the procedure described in
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_38.5.3
Your typedefs are correct, but you need to insert points one by one and
set the info after.
Vertex_handle v=pdt.insert(pt);
v->info()=Info();
Sebastien.
Hej,
That was a very quick response. Thanks for that, although the outcome is
kind of frustrating, since I need to insert lots and lots of points this
way and using this method I don't have access to the optimizations that
are available to do that :( I'll try to refactor the code a bit to see
if I can circumvent this.
Sincerely,
Jakob
Well, that should not be hard to do because the mechanism is already here for
the spatial sorting algorithm.
If you look in Delaunay_triangulation_3.h and all parts surrounded by
#ifdef/#ifndef CGAL_TRIANGULATION_3_DONT_INSERT_RANGE_OF_POINTS_WITH_INFO
you can easily adapt that to the periodic insert.
I don't have time to do it these days but if you provide a patch, I'll be
glad to review it and submit it to CGAL.
Sebastien.
Hej,
That actually is probably the quickest way. What is the common method of
submitting such a patch?
- through this list, or some other list?
- format: hg/git/bzr diff format or standard *nix diff?
Jakob
- Re: [cgal-discuss] How to insert points with info in Periodic_3_Delaunay_triangulation_3?, Jakob van Bethlehem, 03/01/2012
- Re: [cgal-discuss] How to insert points with info in Periodic_3_Delaunay_triangulation_3?, Sebastien Loriot (GeometryFactory), 03/01/2012
