cgal-discuss - Re: [cgal-discuss] Intersection of Iso_rectangle_2 and Ray_2
  • To:
  • Subject: Re: [cgal-discuss] Intersection of Iso_rectangle_2 and Ray_2
  • Date: Fri, 2 Mar 2012 12:25:36 +0400
  • Authentication-results: mr.google.com; spf=pass (google.com: domain of designates 10.236.170.163 as permitted sender) ; dkim=pass
Ok, thanks.
Best regards, Mikhail Matrosov
2012/3/2 Sebastien Loriot (GeometryFactory) <>
On 03/02/2012 09:06 AM, Mikhail Matrosov wrote:
Thank you! And what if I want to consider iso_rectangle as thin, have
starting point of ray inside it and want to find intersection as a point
in this case (see picture)? Should I just take target() of segment found
as an intersection?
Quickly looked at the code and I would say yes.
Sebastien.
<mailto:>>
   The iso_rectangle is considered as full so that what you call
   the two point case is the segment one.
   #include <CGAL/Exact_predicates_exact___constructions_kernel.h>
   int main(){
     typedef CGAL::Exact_predicates_exact___constructions_kernel Kernel;
     typedef Kernel::Point_2 Point_2;
     typedef Kernel::Ray_2 Ray_2;
     typedef Kernel::Iso_rectangle_2 Iso_rectangle_2;
     Ray_2 r(Point_2(0,0),Point_2(1,1));
     Iso_rectangle_2 rect(Point_2(0,0),Point_2(1,1)__);
     CGAL::Object obj=CGAL::intersection(r,rect)__;
     const Kernel::Segment_2* s=CGAL::object_cast<Kernel::__Segment_2>
   (&obj);
     CGAL_assertion(s!=NULL);
     std::cout << *s << std::endl;
   On 03/02/2012 08:55 AM, Mikhail Matrosov wrote:
       There is a function Object intersection(Type1<Kernel> obj1,
       Type2<Kernel> obj2) in CGAL which will return an object,
       representing
       intersection of two given objects of different possible types. It is
       said, that intersection of Iso_rectangle_2 and Ray_2 is either
       Point_2
       or Segment_2.
       And what about the case when ray intersects rectangle in two
       points (see
       attached picture)? Cannot see anything about it in the manual.
   https://lists-sop.inria.fr/__wws/info/cgal-discuss
   <https://lists-sop.inria.fr/wws/info/cgal-discuss>
