[cgal-discuss] Re: Can Someone Explain the Output of the code(Intersection of two line segments)
- To:
- Subject: [cgal-discuss] Re: Can Someone Explain the Output of the code(Intersection of two line segments)
- Date: Sun, 4 Mar 2012 04:25:10 -0800 (PST)
The output I get from running the above code is:-
Output
Intersection point: -4 0
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Can-Someone-Explain-the-Output-of-the-code-Intersection-of-two-line-segments-tp4443368p4443370.html
- [cgal-discuss] Can Someone Explain the Output of the code(Intersection of two line segments), pgiitu, 03/04/2012
- [cgal-discuss] Re: Can Someone Explain the Output of the code(Intersection of two line segments), pgiitu, 03/04/2012
- Re: [cgal-discuss] Can Someone Explain the Output of the code(Intersection of two line segments), Sebastien Loriot (GeometryFactory), 03/05/2012
