cgal-discuss - Re: Re : Re : [cgal-discuss] 3D triangulation
  • To:
  • Subject: Re: Re : Re : [cgal-discuss] 3D triangulation
  • Date: Mon, 05 Mar 2012 12:26:18 +0100
On 03/05/2012 12:11 PM, Ahmed Ben saïd wrote:
Thx a lot.
Actually, I'm following it and sorry if I didn't explain well :
I want to triangulate the 3D model already loaded and display it
triangulated,
it means that I'm trying to add the triangulation code to my source code
if it' possible.
yes it should be possible and the examples and the documentation
mentioned before will help.
Sebastien.
*De :* Sebastien Loriot (GeometryFactory)
*À :*
*Envoyé le :* Lundi 5 mars 2012 14h04
*Objet :* Re: Re : [cgal-discuss] 3D triangulation
On this page:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html
You will find the documentation of the package with few examples.
Sebastien.
On 03/05/2012 11:55 AM, Ahmed Ben saïd wrote:
> I followed tose examples:
> http://openglsamples.sourceforge.net/projects/index.php/blog/index/
> and I loaded a 3D model (.ply file format) but I want now to triangulate
> it with CGAL triangulation algorithm
> but I couldn't. Is there any way to do it?
> *De :* Philipp Moeller
<mailto:>>
> *À :*
<mailto:>
> *Envoyé le :* Lundi 5 mars 2012 13h33
> *Objet :* Re: [cgal-discuss] 3D triangulation
> ahmed
<mailto:>
<mailto:
<mailto:>>>
writes:
> > This post has NOT been accepted by the mailing list yet.
> > Hi,
> > I'm new with CGAL and I want to use the 3D Triangulation algorithm to
> > triangulate a 3D model.
> > I used OPenGL to load the 3D model but I don't know how to use the
> > triangulation algorithm.
> > Can anyone help me.
> > I'll be so grateful
> You need to provide a little more information. In what format is the
> model you load? (OpenGL does not support any object file format so
> you are probably using some library)
> After that you will probably need to convert your model to a data
> structure suitable for CGAL Triangulation_3 and back to something your
> renderer understands.
> Philipp Moeller
> GeometryFactory
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
