- To:
- Subject: Re: [cgal-discuss] C++: "Cannot find or open the PDB file
- Date: Wed, 7 Mar 2012 16:45:00 +0200
without being sure cause i am not so experienced, your program runs normally. the pdb messages just ignore.if you want to stop the screen and see the result of your program you can add a line with scanf before return(for example scanf ("%d",&tmp); ) ..with that way the program will stop before return 0.
Στις 07 Μαρ 2012 4:38 μ.μ., ο χρήστης "Zeineb Abderrahim" <> έγραψε:
Hello,
I try to run a C++ "Win32 Console Application" project. The program runs and prints results, however, i got these messages on the output window:'test.exe': Loaded 'G:\Users\chengtie\Documents\Visual Studio 2010\Projects\test\Debug\test.exe', Symbols loaded.'test.exe': Loaded 'C:\Windows\SysWOW64\ntdll.dll', Cannot find or open the PDB file'test.exe': Loaded 'C:\Windows\SysWOW64\kernel32.dll', Cannot find or open the PDB file'test.exe': Loaded 'C:\Windows\SysWOW64\KernelBase.dll', Cannot find or open the PDB file'test.exe': Loaded 'C:\Windows\SysWOW64\msvcp100d.dll', Symbols loaded.'test.exe': Loaded 'C:\Windows\SysWOW64\msvcr100d.dll', Symbols loaded.The program '[2244] test.exe: Native' has exited with code 0 (0x0).I just installed visual studio 2010 on my machine (windows 7 64 bit).please if you can help me its so importante thanks.
- [cgal-discuss] C++: "Cannot find or open the PDB file, Zeineb Abderrahim, 03/07/2012
- Re: [cgal-discuss] C++: "Cannot find or open the PDB file, Dimitris Sgourdos, 03/07/2012
- Re: [cgal-discuss] C++: "Cannot find or open the PDB file, Laurent Rineau (GeometryFactory), 03/07/2012
- Re : [cgal-discuss] C++: "Cannot find or open the PDB file, Zeineb Abderrahim, 03/07/2012
- Re: Re : [cgal-discuss] C++: "Cannot find or open the PDB file, gwenm, 03/15/2012
- Re : Re : [cgal-discuss] C++: "Cannot find or open the PDB file, Zeineb Abderrahim, 03/15/2012
- Re: Re : Re : [cgal-discuss] C++: "Cannot find or open the PDB file, Zohar, 03/18/2012
- Re : Re : Re : [cgal-discuss] C++: "Cannot find or open the PDB file, Zeineb Abderrahim, 03/18/2012
