- To:
- Subject: [cgal-discuss] Convert C3t3 to Polyhedron
- Date: Mon, 12 Mar 2012 12:53:40 -0700 (PDT)
Hi,
I have a defective mesh (triangular surface - polyhedron), which I'd like to
fix by remeshing. I loaded it into Mesh_3 demo, used it as a domain to
construct a tetrahedral mesh (c3t3), and my only option is to save it to
.mesh.
Is there an external app, which can extract the surface from .mesh and save
as .off for example?
I thought to patch Io_c3t3_plugin.cpp to write also a polyhedron.
This guy:
http://cgal-discuss.949826.n4.nabble.com/Contibution-for-CGAL-Complex-3-in-triangulation-3-polyhedron-builder-h-td2307832.html
seems to wrote something that do that. But the interface seems to be wrong
(e.g. Face_iterator should be Facets_in_complex_iterator). I tried to update
the interface, but the output was nonsense.
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Convert-C3t3-to-Polyhedron-tp4467182p4467182.html
- [cgal-discuss] Convert C3t3 to Polyhedron, Zohar, 03/12/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/13/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/20/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/20/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/22/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/23/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/23/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/24/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/25/2012
- Re:Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Yan Shijiang, 03/25/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Philipp Moeller, 03/25/2012
